In some files, options of CMD_NAND are selected but not the command
itself. Fix this inconsistency.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
Both symbols must be enabled when there is a raw NAND driver
selected. Also enable them when CONFIG_CMD_NAND is selected to avoid
breaking things when we'll further rework the MTD dependency
description.
[trini: Rebase and migrate a few more boards here]
Add more clarity by changing the Kconfig entry name.
[trini: Re-run migration, update a few more cases]
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
Move this symbol to Kconfig. As part of this we can drop a UBI-specific
symbol that was a stop-gap for not having this particular symbol in
Kconfig.
CONFIG_USE_PREBOOT
CONFIG_PREBOOT
Both are together in one commit, since otherwise the former causes kconfig
to define the latter, which gives duplicate symbol errors.
Includes a manual fixup for CONFIG_PREBOOT in ids8313_defconfig since the
backslash lands in the wrong place. Similarly with socfpga_vining_fpga.
Moved CONFIG_SPL_TEXT_BASE to common/spl/Kconfig and migrate existing
values.
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
[trini: Re-run migration]
Now that CMD_UBI does not select CMD_MTDPARTS we need to make platforms
that had been enabling it turn it on by hand. This exposed that we had
not yet migrated CMD_MTDPARTS fully, so do so now.
Fixes: 86dfa556d927 ("cmd: ubi: Remove useless call to mtdparts_init()")
CONFIG_MII
CONFIG_DRIVER_TI_EMAC
Acked-by: Jagan Teki <jagan@amarulasolutions.com>
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
This patch added Kconfig support for FPGA_SPARTAN3 and migrates the
values over to the defconfigs.
Signed-off-by: Vipul Kumar <vipulk@xilinx.com>
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
CONFIG_BOOTP_BOOTPATH
CONFIG_BOOTP_DNS
CONFIG_BOOTP_GATEWAY
CONFIG_BOOTP_HOSTNAME
CONFIG_BOOTP_PXE
CONFIG_BOOTP_SUBNETMASK
CONFIG_CMDLINE_EDITING
CONFIG_AUTO_COMPLETE
CONFIG_SYS_LONGHELP
CONFIG_SUPPORT_RAW_INITRD
CONFIG_ENV_VARS_UBOOT_CONFIG
[trini: Re-run the migration]
Migrate the option CONFIG_SPL_FRAMEWORK and make this gate most of the
current set of options we have in Kconfig. We will need to have some
options available for SPL and !SPL_FRAMEWORK so this is important. In a
few cases we re-order existing options so that we have less escapes from
the SPL_FRAMEWORK guard.
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
CONFIG_MXC_GPIO
These are declared in Kconfig, but some #defines have crept in.
CONFIG_FPGA
CONFIG_FPGA_ALTERA
CONFIG_FPGA_CYCLON2
CONFIG_FPGA_SOCFPGA
CONFIG_FPGA_XILINX
CONFIG_FPGA_ZYNQMPPL
We move all instances of CONFIG_MTDIDS_DEFAULT and
CONFIG_MTDPARTS_DEFAULT from the header files to the defconfig files.
There's a few cases here where we need to expand upon what was in the
header file.
Tested-by: Adam Ford <aford173@gmail.com> #omap3_logic
CONFIG_NAND_MXC
CONFIG_NAND_OMAP_GPMC
CONFIG_NAND_OMAP_GPMC_PREFETCH
CONFIG_NAND_OMAP_ELM
CONFIG_SPL_NAND_AM33XX_BCH
CONFIG_SPL_NAND_SIMPLE
CONFIG_SYS_NAND_BUSWIDTH_16BIT
[trini: Finish migration of CONFIG_SPL_NAND_SIMPLE, fix some build issues,
add CONFIG_NAND_MXC so we can do CONFIG_SYS_NAND_BUSWIDTH_16BIT]
Having this as a 'default y' is rather annoying because it doesn't
actually compile unless other options are defined in the board header:
../cmd/bootm.c: In function 'do_imls_nor':
../cmd/bootm.c:330:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
Make it 'default n' so people who develop new boards that start from a
blank defconfig have one less compilation failure to debug.
Also introduce CONFIG_USE_BOOTARGS option so we can control if
CONFIG_BOOTARGS defined at all.
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
[trini: Resync r8a779[56]_ulcb, various ls10xx targets]
Migrate all remaining instances of CMD_NAND, CMD_NAND_TRIMFFS
CMD_NAND_LOCK_UNLOCK and CMD_NAND_TORTURE from the headers into the
defconfig files.
CONFIG_ENV_IS_IN_MMC
CONFIG_ENV_IS_IN_NAND
CONFIG_ENV_IS_IN_UBI
CONFIG_ENV_IS_NOWHERE
In fact this already exists for sunxi as a 'choice' config. However not
all the choices are available in Kconfig yet so we cannot use that. It
would lead to more than one option being set.
In addition, one purpose of this series is to allow the environment to be
stored in more than one place. So the existing choice is converted to a
normal config allowing each option to be set independently.
There are not many opportunities for Kconfig updates to reduce the size of
this patch. This was tested with
./tools/moveconfig.py -i CONFIG_ENV_IS_IN_MMC
And then manual updates. This is because for CHAIN_OF_TRUST boards they
can only have ENV_IS_NOWHERE set, so we enforce that via Kconfig logic
now.
CONFIG_CMD_EEPROM
CONFIG_CMD_EEPROM_LAYOUT
CONFIG_EEPROM_LAYOUT_HELP_STRING
[trini: Rework Kconfig logic slightly, define EEPROM location on TI eval
platforms]
Signed-off-by: Chris Packham <judge.packham@gmail.com>
[trini: default y if DM_RTC, re-sync]
CONFIG_CMD_BSP
We have long had available optimized versions of the memset and memcpy
functions that are borrowed from the Linux kernel. We should use these
in normal conditions as the speed wins in many workflows outweigh the
relatively minor size increase. However, we have a number of places
where we're simply too close to size limits in SPL and must be able to
make the size vs performance trade-off in those cases.
Cc: Philippe Reynes <tremyfr@yahoo.fr>
Cc: Eric Jarrige <eric.jarrige@armadeus.org>
Cc: Magnus Lilja <lilja.magnus@gmail.com>
Cc: Lokesh Vutla <lokeshvutla@ti.com>
Cc: Chander Kashyap <k.chander@samsung.com>
Cc: Akshay Saraswat <akshay.s@samsung.com>
Cc: Stefan Roese <sr@denx.de>
Move (and rename) the following CONFIG options to Kconfig:
CONFIG_DAVINCI_MMC (renamed to CONFIG_MMC_DAVINCI)
CONFIG_OMAP_HSMMC (renamed to CONFIG_MMC_OMAP_HS)
CONFIG_MXC_MMC (renamed to CONFIG_MMC_MXC)
CONFIG_MXS_MMC (renamed to CONFIG_MMC_MXS)
CONFIG_TEGRA_MMC (renamed to CONFIG_MMC_SDHCI_TEGRA)
CONFIG_SUNXI_MMC (renamed to CONFIG_MMC_SUNXI)
They are the same option names as used in Linux.
This commit was created as follows:
[1] Rename the options with the following command:
find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \
-type f -print | xargs sed -i -e '
s/CONFIG_DAVINCI_MMC/CONFIG_MMC_DAVINCI/g
s/CONFIG_OMAP_HSMMC/CONFIG_MMC_OMAP_HS/g
s/CONFIG_MXC_MMC/CONFIG_MMC_MXC/g
s/CONFIG_MXS_MMC/CONFIG_MMC_MXS/g
s/CONFIG_TEGRA_MMC/CONFIG_MMC_SDHCI_TEGRA/g
s/CONFIG_SUNXI_MMC/CONFIG_MMC_SUNXI/g
[2] Commit the changes
[3] Create entries in driver/mmc/Kconfig.
(copied from Linux)
[4] Move the options with the following command
tools/moveconfig.py -y -r HEAD \
MMC_DAVINCI MMC_OMAP_HS MMC_MXC MMC_MXS MMC_SDHCI_TEGRA MMC_SUNXI
[5] Sort and align drivers/mmc/Makefile for readability
move the UBI config options into Kconfig.
Reviewed-by: Andrew F. Davis <afd@ti.com>
Reviewed by: Evgeni Dobrev <evgeni at studio-punkt.com>
Move the config IDENT_STRING to Kconfig and migrate all boards
[sivadur: Migrate zynq boards]
[trini: Update configs, add some default to sunxi Kconfig]
Move this option to Kconfig and tidy up existing uses.
Move the SPL settings into common/spl where most of the SPL code is kept.
move VERSION_VARIABLE from board config file into a
Kconfig option.
move CONFIG_BOOTDELAY into a Kconfig option. Used for this
purpose the moveconfig.py tool in tools.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
Some boards' defconfigs are disordered. Reorder them.
Add option to set shell prompt string from menuconfig and migrate
boards globally.
The migration is done as follows:
- Boards that explicitly and unconditionally set CONFIG_SYS_PROMPT had the
entry moved to their defconfig files.
- Boards that defined some kind of #ifdef logic which selects the
CONFIG_SYS_PROMPT (for example qemu-mips) got an #undef CONFIG_SYS_PROMPT
right before the #ifdef logic and were left alone.
- This change forces CONFIG_SYS_PROMPT to be a per board decision, and thus
CONFIG_SYS_PROMPT was removed from all <soc>_common.h and <arch>_common.h
files. This results in a streamlined default value across platforms, and
includes the following files: spear-common, sunxi-common, mv-common,
ti_armv7_common, tegra-common, at91-sama5_common, and zynq-common.
- Boards that relied on <arch/soc>_common.h values of CONFIG_SYS_PROMPT were
not updated in their respective defconfig files under the assumption that
since they did not explicitly define a value, they're fine with whatever
the default is.
- On the other hand, boards that relied on a value defined in some
<boards>_common.h file such as woodburn_common, rpi-common,
bur_am335x_common, ls2085a_common, siemens_am33x_common, and
omap3_evm_common, had their values moved to the respective defconfig files.
- The define V_PROMPT was removed, since it is not used anywhere except for
assigning a value for CONFIG_SYS_PROMPT.
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
Cc: Igor Grinberg <grinberg@compulab.co.il>
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
[trini: Add spring, sniper, smartweb to conversion]
