FIT image support is used by the upcoming Toradex Easy Installer
and also can be useful for more advanced boot scenarios.
Enable the display driver on Apalis T30. Unfortunately the PWM pin
muxing wasn't any good neither which made that display stay dark.
(cherry picked from commit 2da21c1d130fa11a5bd9876c8e72fa0d57585106)
Device tree overlays might prove useful in the future, enable it
by default on all our modules.
Migrate Apalis/Colibri T30 to U-Boot 2016.11.
(cherry picked from commit 81a38df0631cfa6b3a85c97e631abf73dc0a2226)
All modules use the common g_dnl_bind_fixup implementaton which
calculates the PID according to product id (read from the config
block) plus offset of 0x4000. In case there is no config block
support (e.g. SPL) or in case the config block is not readable,
fall back to a generic product id (product id 0, which can be
interpreted as "Unknown Module").
Basically running the following script:
tools/moveconfig.py CONFIG_TEGRA_MMC
Note that I left the SPL specific handling in
include/configs/tegra-common-post.h unchanged.
Deactivate CONFIG_DISPLAY_BOARDINFO in favour of
CONFIG_DISPLAY_BOARDINFO_LATE which also displays on the LCD.
(cherry picked from commit b05d6806cd6a95d46c22036a684a09501fdb2264)
Add 'PCI' as a menu option and migrate all existing users.
CONFIG_SYS_STDIO_DEREGISTER
This option should never be enabled in SPL, so use
CONFIG_IS_ENABLED(SYS_STDIO_DEREGISTER) when checking the option.
[trini: Re-sync]
CONFIG_SYS_CONSOLE_IS_IN_ENV
CONFIG_CONSOLE_MUX
[trini: Re-order, re-migrate]
These two options go together and it is best to do the conversion in one
step. So enable DM_MMC_OPS by default if DM_MMC is enabled.
To speed up conversion to CONFIG_BLK, enable it by default when DM_MMC is
enabled.
Introduce a hidden USB_FUNCTION_DFU Kconfig option and select it for
CMD_DFU (as we must have the DFU command enabled to do anything DFU).
Make all of the entries in drivers/dfu/Kconfig depend on CMD_DFU and add
options for all of the back end choices that DFU can make use of.
Cc: Lukasz Majewski <l.majewski@samsung.com>
Acked-by: Lukasz Majewski <l.majewski@samsung.com>
In some cases we were missing CONFIG_USB=y so enable that when needed.
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
With updated moveconfig.py and an better default, re-generate
the migration of BOOTDELAY to the defconfig.
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
move CONFIG_BOOTDELAY into a Kconfig option. Used for this
purpose the moveconfig.py tool in tools.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
And also reformat defconfigs using "make savedefconfig" rule.
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
While at it, remove obsolete CONFIG_USBDOWNLOAD_GADGET option from some
config headers. This is also probably fixes am335x_baltos board.
Move CONFIG_USB_GADGET_DUALSPEED option to Kconfig and
make all UDC controllers select USB_GADGET_DUALSPEED:
- add next options to Kconfig selecting USB_GADGET_DUALSPEED:
- USB_GADGET_ATMEL_USBA
- USB_GADGET_DWC2_OTG
- USB_DWC3
- CI_UDC
- make USB_MUSB_GADGET select USB_GADGET_DUALSPEED
While at it, make some related fixes:
- remove DUALSPEED from configs that don't enable gadget support:
- kwb.h
- tseries.h
- add missing USB_GADGET option to next configs:
- novena_defconfig
- pcm051_rev*_defconfig
- xfi3_defconfig
The description was borrowed from kernel. "tristate" type was changed
to "bool" (I believe we don't support modules for u-boot yet, right?).
CONFIG_USB_GADGET requires CONFIG_USB to be defined too, so add it along
as well.
Definitions were added to defconfig files in a way that
"make savedefconfig" generates exactly the same file as used defconfig.
[trini: Add zynq_zc702 conversion]
There are already two FIT options in Kconfig but the CONFIG options are
still in the header files. We need to do a proper move to fix this.
Move these options to Kconfig and tidy up board configuration:
CONFIG_FIT
CONFIG_OF_BOARD_SETUP
CONFIG_OF_SYSTEM_SETUP
CONFIG_FIT_SIGNATURE
CONFIG_FIT_BEST_MATCH
CONFIG_FIT_VERBOSE
CONFIG_OF_STDOUT_VIA_ALIAS
CONFIG_RSA
Unfortunately the first one is a little complicated. We need to make sure
this option is not enabled in SPL by this change. Also this option is
enabled automatically in the host builds by defining CONFIG_FIT in the
image.h file. To solve this, add a new IMAGE_USE_FIT #define which can
be used in files that are built on the host but must also build for U-Boot
and SPL.
Note: Masahiro's moveconfig.py script is amazing.
[trini: Add microblaze change, various configs/ re-applies]
Various boards have the wrong Kconfig ordering now. To avoid a misleading
diff in the next patch, reorder the configuration correctly.
Move this option to Kconfig and fix up all users.
Add CMD_GPIO to Kconfig and run tools/moveconfig.py .
Some boards' defconfigs are disordered. Reorder them.
Move config for the E1000 Ethernet driver to Kconfig and tidy up affected
boards.
Add option to set shell prompt string from menuconfig and migrate
boards globally.
The migration is done as follows:
- Boards that explicitly and unconditionally set CONFIG_SYS_PROMPT had the
entry moved to their defconfig files.
- Boards that defined some kind of #ifdef logic which selects the
CONFIG_SYS_PROMPT (for example qemu-mips) got an #undef CONFIG_SYS_PROMPT
right before the #ifdef logic and were left alone.
- This change forces CONFIG_SYS_PROMPT to be a per board decision, and thus
CONFIG_SYS_PROMPT was removed from all <soc>_common.h and <arch>_common.h
files. This results in a streamlined default value across platforms, and
includes the following files: spear-common, sunxi-common, mv-common,
ti_armv7_common, tegra-common, at91-sama5_common, and zynq-common.
- Boards that relied on <arch/soc>_common.h values of CONFIG_SYS_PROMPT were
not updated in their respective defconfig files under the assumption that
since they did not explicitly define a value, they're fine with whatever
the default is.
- On the other hand, boards that relied on a value defined in some
<boards>_common.h file such as woodburn_common, rpi-common,
bur_am335x_common, ls2085a_common, siemens_am33x_common, and
omap3_evm_common, had their values moved to the respective defconfig files.
- The define V_PROMPT was removed, since it is not used anywhere except for
assigning a value for CONFIG_SYS_PROMPT.
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
Cc: Igor Grinberg <grinberg@compulab.co.il>
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
[trini: Add spring, sniper, smartweb to conversion]
them from include/configs.
Some archs/boards specify their own default by pre-defining the config
which causes the Kconfig system to mix up the order of the configs in
the defconfigs... This will cause merge pain if allowed to proliferate.
Remove the configs that behave this way from the archs.
A few configs still remain, but that is because they only exist as
defaults and do not have a proper Kconfig entry. Those appear to be:
SPIFLASH
DISPLAY_BOARDINFO
[trini: rastaban, am43xx_evm_usbhost_boot, am43xx_evm_ethboot updates,
drop DM_USB from MSI_Primo81 as USB_MUSB_SUNXI isn't converted yet to DM]
This also selects CONFIG_NET for any CONFIG_CMD_NET board.
Remove the imx default for CONFIG_NET.
This moves the config that was defined by 60296a8 (commands: add more
command entries in Kconfig).
Another shell scripting command that has not been moved.
Moved using tools/moveconfig.py using these settings:
CMD_SETEXPR bool n y
Since commit e02ee2548afe (kconfig: switch to single .config
configuration), the prefixes in defconfig files such as "+S:",
"+ST:", etc., are meaningless.
This commit was generated by the following command:
find configs -name '*_defconfig' | xargs sed -i 's/^+*S*T*://'
This patch adds board support for the Toradex Apalis T30 a computer on
module which can be used on different carrier boards.
For the sake of ease of use we do not distinguish between different
carrier boards for now as the base module features are deemed
sufficient enough for regular booting.
The following functionality is working so far:
- eMMC boot and environment storage
- Gigabit Ethernet (once Thierry's PCIe as well as my E1000 resp. i210
fixes hit mainline)
- MMC/SD cards (both 8-bit as well as 4-bit slot)
- USB client/host (dual role port as client e.g. for DFU/UMS, other two
ports as host)
Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
Signed-off-by: Tom Warren <twarren@nvidia.com>
