path: root/configs/apalis_imx6_nospl_it_defconfig
2017-03-18arm: Migrate SYS_THUMB_BUILD to Kconfig, introduce SPL_SYS_THUMB_BUILDTom Rini
Today, we have cases where we wish to build all of U-Boot in Thumb2 mode for various reasons. We also have cases where we only build SPL in Thumb2 mode due to size constraints and wish to build the rest of the system in ARM mode. So in this migration we introduce a new symbol as well, SPL_SYS_THUMB_BUILD to control if we build everything or just SPL (or in theory, just U-Boot) in Thumb2 mode. Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Siarhei Siamashka <siarhei.siamashka@gmail.com>
2016-12-16arm: imx: initial support for apalis imx6Max Krummenacher
This adds board support for the Toradex module family Apalis iMX6. The familiy consists of a module with i.MX6 Dual, i.MX6 Quad with commercial and industrial temperature range. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
