path: root/configs/apalis-tk1_defconfig
2017-07-28dm: power: Convert as3722 to driver modelSimon Glass
Convert this PMIC driver to driver model and fix up other users. The regulator and GPIO functions are now handled by separate drivers. Update nyan-big to work correct. Three boards will need to be updated by the maintainers: apalis-tk1, cei-tk1-som. Also the TODO in the code re as3722_sd_set_voltage() needs to be completed. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Lukasz Majewski <lukma@denx.de> Tested-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Tested-on: Jetson-TK1 Tested-by: Stephen Warren <swarren@nvidia.com>
2017-06-01tegra: Convert MMC to use driver model for operationsSimon Glass
Enable CONFIG_DM_MMC_OPS and CONFIG_BLK for all Tegra devices. This moves Tegra to use driver model fully for MMC. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-30power: Convert CONFIG_PMIC_AS3722 to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_PMIC_AS3722 Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-01apalis-tk1: disable external clock loopback on SDMMC3Marcel Ziswiler
Actually make use of that shiny new CONFIG_TEGRA124_MMC_DISABLE_EXT_LOOPBACK. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2017-04-01arm: tegra: initial support for apalis tk1Marcel Ziswiler
This patch adds board support for the Toradex Apalis TK1 a computer on module which can be used on different carrier boards. The module consists of a Tegra TK1 SoC, a PMIC solution, 2 GB of DDR3L RAM, a bunch of level shifters, an eMMC, a TMP451 temperature sensor chip, an I210 gigabit Ethernet controller and a SGTL5000 audio codec. Furthermore, there is a Kinetis MK20DN512 companion micro controller for analogue, CAN and resistive touch functionality. For the sake of ease of use we do not distinguish between different carrier boards for now as the base module features are deemed sufficient enough for regular booting. The following functionality is working so far: - eMMC boot, environment storage and Toradex factory config block - Gigabit Ethernet - MMC/SD cards (both MMC1 as well as SD1 slot) - USB client/host (dual role OTG port as client e.g. for DFU/UMS or host, other two ports as host) Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
