path: root/configs/amcore_defconfig
2019-05-26configs: Resync with savedefconfigTom Rini
2019-05-24configs: enable use of DT for all m68k boardsAngelo Dureghello
Enable DT usage for all m68k boards. To provide a working single binary, the dts has been kept as embedded. Signed-off-by: Angelo Dureghello <angelo@sysam.it>
2018-02-27Kconfig: cmd: Make networking command dependent on NETMichal Simek
Enable networking command only when NET is enabled. And remove selecting NET for CMD_NET Signed-off-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-30Convert CONFIG_CMD_DIAG to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_DIAG Signed-off-by: Simon Glass <sjg@chromium.org> [trini: imply CMD_DIAG on some keymile configs] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-09-25board: amcore: update to use dm serial driverAngelo Dureghello
Update amcore board to use dm serial driver. Signed-off-by: Angelo Dureghello <angelo@sysam.it> --- Changes for v2: - None
2015-03-05m68k: add amcore board supportangelo@sysam.it
Add Sysam Amcore m68k-based board support. Signed-off-by: Angelo Dureghello <angelo@sysam.it>
