path: root/configs/amcore_defconfig
2017-04-30Convert CONFIG_CMD_DIAG to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_DIAG Signed-off-by: Simon Glass <sjg@chromium.org> [trini: imply CMD_DIAG on some keymile configs] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-09-25board: amcore: update to use dm serial driverAngelo Dureghello
Update amcore board to use dm serial driver. Signed-off-by: Angelo Dureghello <angelo@sysam.it> --- Changes for v2: - None
2015-03-05m68k: add amcore board supportangelo@sysam.it
Add Sysam Amcore m68k-based board support. Signed-off-by: Angelo Dureghello <angelo@sysam.it>
