path: root/configs/amarula_a64_relic_defconfig
2018-08-20Merge branch 'master' of git://git.denx.de/u-boot-sunxiTom Rini
2018-08-13sunxi: A64: fix default DRAM_ODT_EN symbolAndre Przywara
"default" lines in Kconfig are processed in order, the first hit will stop considering subsequent lines. In the case of the DRAM_ODT_EN symbol that means that everything following the first two lines will never be checked: ------------ config DRAM_ODT_EN bool "sunxi dram odt enable" default n if !MACH_SUN8I_A23 default y if MACH_SUN8I_A23 default y if MACH_SUN8I_R40 default y if MACH_SUN50I ------------ Assuming that the "default y" for the A64 and the R40 were a deliberate choice, fix the Kconfig stanza to take this into account. Also remove the now redundant lines from the respective defconfigs. Signed-off-by: Andre Przywara <andre.przywara@arm.com> [jagan: droped 'default n' on original change] Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com> Tested-by: Jagan Teki <jagan@amarulasolutions.com> # A64, R40 Tested-by: Chen-Yu Tsai <wens@csie.org> # A23
2018-06-04board: sun50i: Add Amarula A64-Relic initial supportJagan Teki
Amarula A64-Relic is A64 based IoT device, which support - Allwinner A64 Cortex-A53 - Mali-400MP2 GPU - AXP803 PMIC - 1GB DDR3 RAM - 8GB eMMC - AP6330 Wifi/BLE - MIPI-DSI - CSI: OV5640 sensor - USB OTG - 12V DC power supply Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com>
