path: root/configs/am65x_hs_evm_a53_defconfig
2019-05-08sysreset: enable driver support in SPL/TPLKever Yang
SPL/TPL also need use sysreset for some feature like panic callback. Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2019-04-26configs: Add configs for AM65x High Security EVMAndrew F. Davis
Add new defconfig files for the AM65x High Security EVM. This defconfigs are the same as for the non-secure part, except for: CONFIG_TI_SECURE_DEVICE option set to 'y' CONFIG_FIT_IMAGE_POST_PROCESS option set to 'y' CONFIG_SPL_FIT_IMAGE_POST_PROCESS option set to 'y' Signed-off-by: Andrew F. Davis <afd@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Andreas Dannenberg <dannenberg@ti.com>
