Add configs for voltage switching and UHS modes for the SD card
and HS200 for the eMMC.
Signed-off-by: Faiz Abbas <faiz_abbas@ti.com>
Signed-off-by: Aswath Govindraju <a-govindraju@ti.com>
sequence number
AM65x SoC has two USB subsystems and their corresponding device tree nodes
have the same name but different path. While allocating sequence numbers
for these device tree nodes using alias, phandles can be used to
distinguish them.
Enable config for phandle check while getting sequence number to
distinguish the USB device tree nodes.
By default CONFIG_LOGLEVEL seems to be set to 4 which is
too low and doesn't show dev_info/dev_notice/dev_warn
messages on console. This has been deliberately set low
globally to be conservative setting across the board due to
primary bootloader size limitations. It is best to tune
per board config as per user needs.
On K3 we have separate SPL and u-boot configs so we
can afford to set u-boot CONFIG_LOGLEVEL to 7.
On AM65 this patch causes u-boot.img size to change from
932KB to 940KB with 1 line additional print during
MMC boot. i.e. details of Net subsystem
"Net: K3 CPSW: nuss_ver: 0x6BA00102 cpsw_ver: 0x6BA80102 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000"
Similar 8KB difference was seen on J721E.
Signed-off-by: Roger Quadros <rogerq@ti.com>
Reviewed-by: Nishanth Menon <nm@ti.com>
Enable configs to facilitate booting from USB Mass Storage devices
as well as USB peripheral boot
CONFIG_SYS_MMC_ENV_DEV
CONFIG_SYS_MMC_ENV_PART
Note that with this conversion we now have consistent behavior with
respect to ensuring that we have always selected the correct MMC
device and hardware partition.
At present we use the empty string to indicate that there is no FIT
generator, but this doesn't allow an individual board to undefine it.
Create a separate bool instead.
Update the config of the boards which currently have an empty string.
CONFIG_ENV_OVERWRITE
[trini: Rerun migration, remove some comments]
Enable CONFIG_SOC_DEVICE and CONFIG_SOC_DEVICE_TI_K3 so the TI K3 SoC
driver can be used for SoC detection.
Signed-off-by: Dave Gerlach <d-gerlach@ti.com>
This reverts commit 5d3a21df6694ebd66d5c34c9d62a26edc7456fc7, reversing
changes made to 56d37f1c564107e27d873181d838571b7d7860e7.
Unfortunately this is causing CI failures:
https://travis-ci.org/github/trini/u-boot/jobs/711313649
Merge all outstanding changes from the current next branch in now that
we have released.
This change allows more fine tuning of driver model based SPI support in
SPL and TPL. It is now possible to explicitly enable/disable the DM_SPI
support in SPL and TPL via Kconfig option.
Before this change it was necessary to use:
/* SPI Flash Configs */
#if defined(CONFIG_SPL_BUILD)
#undef CONFIG_DM_SPI
#undef CONFIG_DM_SPI_FLASH
#undef CONFIG_SPI_FLASH_MTD
#endif
in the ./include/configs/<board>.h, which is error prone and shall be
avoided when we strive to switch to Kconfig.
The goal of this patch:
Provide distinction for DM_SPI support in both U-Boot proper and SPL (TPL).
Valid use case is when U-Boot proper wants to use DM_SPI, but SPL must
still support non DM driver.
Another use case is the conversion of non DM/DTS SPI driver to support
DM/DTS. When such driver needs to work in both SPL and U-Boot proper, the
distinction is needed in Kconfig (also if SPL version of the driver
supports OF_PLATDATA).
In the end of the day one would have to support following use cases (in
single driver file - e.g. mxs_spi.c):
- U-Boot proper driver supporting DT/DTS
- U-Boot proper driver without DT/DTS support (deprecated)
- SPL driver without DT/DTS support
- SPL (and TPL) driver with DT/DTS (when the SoC has enough resources to
run full blown DT/DTS)
- SPL driver with DT/DTS and SPL_OF_PLATDATA (when one have constrained
environment with no fitImage and OF_LIBFDT support).
Some boards do require SPI support (with DM) in SPL (TPL) and some only
have DM_SPI{_FLASH} defined to allow compiling SPL.
This patch converts #ifdef CONFIG_DM_SPI* to #if CONFIG_IS_ENABLED(DM_SPI)
and provides corresponding defines in Kconfig.
Signed-off-by: Lukasz Majewski <lukma@denx.de>
Tested-by: Adam Ford <aford173@gmail.com> #da850-evm
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com>
[trini: Fixup a few platforms]
Due to how the Makefile logic is we currently get DM_SPI support in SPL
enabled by having DM_SPI enabled for full U-Boot but not having
CONFIG_SPL_DM_SPI set. Add this missing option to boards that were
inadvertently making use of it.
Cc: Adam Ford <aford173@gmail.com>
Cc: Akash Gajjar <akash@openedev.com>
Cc: Andy Yan <andy.yan@rock-chips.com>
Cc: Anup Patel <anup.patel@wdc.com>
Cc: Atish Patra <atish.patra@wdc.com>
Cc: Bin Meng <bmeng.cn@gmail.com>
Cc: Chee Hong Ang <chee.hong.ang@intel.com>
Cc: Chin-Liang See <clsee@altera.com>
Cc: Dalon Westergreen <dwesterg@gmail.com>
Cc: Dinh Nguyen <dinguyen@kernel.org>
Cc: Eugen Hristev <eugen.hristev@microchip.com>
Cc: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
Cc: Jagan Teki <jagan@amarulasolutions.com>
Cc: Klaus Goger <klaus.goger@theobroma-systems.com>
Cc: Levin Du <djw@t-chip.com.cn>
Cc: Ley Foon Tan <ley.foon.tan@intel.com>
Cc: Lokesh Vutla <lokeshvutla@ti.com>
Cc: Luca Ceresoli <luca@lucaceresoli.net>
Cc: Mike Looijmans <mike.looijmans@topic.nl>
Cc: Nicolas Ferre <nicolas.ferre@microchip.com>
Cc: Nikita Kiryanov <nikita@compulab.co.il>
Cc: Palmer Dabbelt <palmer@dabbelt.com>
Cc: Paul Walmsley <paul.walmsley@sifive.com>
Cc: Pavel Machek <pavel@denx.de>
Cc: Peter Robinson <pbrobinson@gmail.com>
Cc: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Suniel Mahesh <sunil@amarulasolutions.com>
Cc: Vitaly Andrianov <vitalya@ti.com>
Cc: Wolfgang Grandegger <wg@aries-embedded.de>
Reviewed-by: Luca Ceresoli <luca@lucaceresoli.net>
ti_phy_init function was allocated to the DP83867 PHY. This function
name is to generic for a specific PHY. The function can be moved to a
TI specific file that can register all TI PHYs that are defined in the
defconfig. The ti_phy_init file will contain all TI PHYs initialization
so that only phy_ti_init can be called from the framework.
In addition to the above the config flag for the DP83867 needs to be changed
in the Kconfig and dependent defconfig files. The config flag that was
used for the DP83867 was also generic in nature so a more specific
config flag for the DP83867 was created.
Acked-by: Michal Simek <michal.simek@xilinx.com>
Signed-off-by: Dan Murphy <dmurphy@ti.com>
https://gitlab.denx.de/u-boot/custodians/u-boot-ti into next
K3 J721E:
* OSPI boot support
* Support for loading remote cores in R5 SPL
* PMIC ESM Support
* Minor fixes for R5F and C7x remoteproc drivers
K3 AM654:
* Update AVS class 0 voltages.
* Add I2C nodes
DRA7xx/AM57xx:
* Fixed Android boot on AM57xx
AM33/AM43/Davinci:
* switch to driver model for the net and mdio driver for baltos
* Add DM/DTS support for omap video driver
* Enable fastboot on am335x-evm
With CONFIG_SUPPORT_EMMC_BOOT moved to Kconfig, move it to defconfig
files.
Enable OSPI related defconfigs. Also enable SPL_DMA so that DMA is used
during OSPI boot
Signed-off-by: Vignesh Raghavendra <vigneshr@ti.com>
Enable USB keyboard to be used as input device at U-Boot prompt. Both
serial and USB keyboard will be active inputs simultaneously.
Enable configs related to USB Host mode, Peripheral mode and DFU.
Add Support for ADMA in a53 and r5 defconfigs.
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
Move this symbol to Kconfig. As part of this we can drop a UBI-specific
symbol that was a stop-gap for not having this particular symbol in
Kconfig.
Enable CONFIG_DISPLAY_CPUINFO so that cpuinfo is printed during boot.
AM65x uses TISCI protocol to reset the device and does not
support PSCI reset. So disable PSCI reset.
The A53 U-boot can support early booting of the MCU R5F remote processor(s)
from U-boot prompt to achieve various system usecases before booting the
Linux kernel. Update the default BOOTCOMMAND to provide an automatic and
easier way to start the MCU R5F cores through added environment variables.
Signed-off-by: Suman Anna <s-anna@ti.com>
Enable the R5F remoteproc driver for the AM65x GP EVM so that the
MCU domain R5F cores can be booted from A53 U-boot.
Enable support for Intel E1000 based PCIe ethernet cards that
can be used to test PCIe RC functionality on AM65x EVM.
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
Enable support for PCIe and related configurations
on AM654 EVM platform.
The K3 System Controller driver is used for loading and starting
the System Firmware, and is used only on R5 SPL. It need not be
enabled and built for the A53 U-Boot and SPL, so disable it from
both the GP and HS AM65x A53 defconfigs.
While at this, also remove the unneeded CONFIG_SPL_REMOTEPROC and
CONFIG_CMD_REMOTEPROC as no remoteprocs are now loaded from A53 SPL.
Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
k3_rproc driver is specifically meant for controlling an arm64
core using TISCI protocol. So rename the driver, Kconfig symbol,
compatible and functions accordingly.
While at it drop this remoteproc selection for a53 defconfig.
This will allow for downloading and applying overlays from an MMC/SD
boot media based on the overlay_files ENV variable containing a list
of overlay files.
Signed-off-by: Andreas Dannenberg <dannenberg@ti.com>
The malloc pool used before relocation is getting tight leading to
out of memory errors doing certain DM-related calls. Since we are
running the A53 SPL out of DDR let's just go ahead and bump its size
as used in U-Boot proper as well as SPL (via Kconfig default value)
from 8KB to 32KB.
Enable GPIO driver for PCA953X-compatible I2C-based I/O expander
which includes support for the TCA9554/PCA9554-type expander found
on the AM654 EVM base board.
Enable I2C via driver model as well as the associated set of U-Boot
commands to allow us interacting with various I2C slave devices.
Signed-off-by: Vignesh R <vigneshr@ti.com>
Add configs to support RAW boot mode in eMMC.
Add Support for creating GPT partitions in U-boot.
Add configs such that U-boot environment is in eMMC by default.
