Releasing the flash into proper state, after the loading completes,
is important for the next stage bootloader/kernel to be able to use
the MTD device. This would enable to reset the device for fresh
use by next boot stage.
Signed-off-by: Apurva Nandan <a-nandan@ti.com>
Enable CONFIG_TI_SECURE_DEVICE to support AM62x LP SK with HS devices.
Signed-off-by: Vignesh Raghavendra <vigneshr@ti.com>
Similar to commit 525f95f8e7f4 ("configs: am62x: Move stack and heap from OC SRAM to HSMRAM")
move stack/heap to HSM SRAM and resize according to available space
AM62x LP SK board has SPI NAND flash and no SPI NOR flash, therefore
drop SPI NOR support in order to reduce R5 SPL memory footprint.
This is pre requisite to add AM62x HS Support
Enable mtd and spi-nand configs to allow spi-nand boot.
Signed-off-by: Anand Gadiyar <gadiyar@ti.com>
The configs are based on the AM62x SK, except for the change in name.
However the configs might diverge later as PMIC and other support are
added.
Due to insufficient space in the R5 SPL to hold both sets of DTBs, it
was not possible to have a single image that would work on both the
AM62x SK and the AM62x LP SK.
Cc: Andrew Davis <afd@ti.com>
