This reverts commit 7d9dbeafe637a25267f0902ead02f61843edb7f3.
commit 7988f626336a ("common: avb_verify: Add CONFIG_AVB_PUBKEY_FILE to specify the root avb public key")
was introduced to support AVB on am62x android. But this broke am57x builds.
Android on am57xx is not validated currently hence reverting the patch
till a right fix is identified that scales to all supported platforms.
Signed-off-by: Praneeth Bajjuri <praneeth@ti.com>
Reported-by: Ryan Eatmon <reatmon@ti.com>
Suggested-by: Andrew Davis <afd@ti.com>
Enable the OPP_HIGH configuration for GPU voltage domain
by default for various TI DRA7xx and AM57xx boards. This
is being done to meet the performance needs of 1080p
GFX/MultiMedia usecases. This domain does not support DVFS
and the kernel will continue to run at the boot OPP chosen
here.
Based on logic similar to that of DSPEVE and IVA voltage
domains in commit 58a8921fe34fd5 ("ARM: DRA7: Enable OPP_HIGH
for DSPEVE and IVA voltage domains")
Signed-off-by: Subhajit Paul <subhajit_paul@ti.com>
Signed-off-by: Suman Anna <s-anna@ti.com>
Enable the OPP_HIGH configuration for DSPEVE and IVA voltage
domains by default for various TI DRA7xx and AM57xx boards. This
is being done to meet the performance needs of 1080p MultiMedia
usecases and other DSP usecases. These domains do not support
DVFS and the kernel will continue to run at the boot OPPs chosen
here.
CONFIG_SYS_MMC_ENV_DEV
CONFIG_SYS_MMC_ENV_PART
Note that with this conversion we now have consistent behavior with
respect to ensuring that we have always selected the correct MMC
device and hardware partition.
At present we use the empty string to indicate that there is no FIT
generator, but this doesn't allow an individual board to undefine it.
Create a separate bool instead.
Update the config of the boards which currently have an empty string.
CONFIG_BOOTP_SEND_HOSTNAME
CONFIG_ENV_OVERWRITE
[trini: Rerun migration, remove some comments]
This change allows more fine tuning of driver model based SPI support in
SPL and TPL. It is now possible to explicitly enable/disable the DM_SPI
support in SPL and TPL via Kconfig option.
Before this change it was necessary to use:
/* SPI Flash Configs */
#if defined(CONFIG_SPL_BUILD)
#undef CONFIG_DM_SPI
#undef CONFIG_DM_SPI_FLASH
#undef CONFIG_SPI_FLASH_MTD
#endif
in the ./include/configs/<board>.h, which is error prone and shall be
avoided when we strive to switch to Kconfig.
The goal of this patch:
Provide distinction for DM_SPI support in both U-Boot proper and SPL (TPL).
Valid use case is when U-Boot proper wants to use DM_SPI, but SPL must
still support non DM driver.
Another use case is the conversion of non DM/DTS SPI driver to support
DM/DTS. When such driver needs to work in both SPL and U-Boot proper, the
distinction is needed in Kconfig (also if SPL version of the driver
supports OF_PLATDATA).
In the end of the day one would have to support following use cases (in
single driver file - e.g. mxs_spi.c):
- U-Boot proper driver supporting DT/DTS
- U-Boot proper driver without DT/DTS support (deprecated)
- SPL driver without DT/DTS support
- SPL (and TPL) driver with DT/DTS (when the SoC has enough resources to
run full blown DT/DTS)
- SPL driver with DT/DTS and SPL_OF_PLATDATA (when one have constrained
environment with no fitImage and OF_LIBFDT support).
Some boards do require SPI support (with DM) in SPL (TPL) and some only
have DM_SPI{_FLASH} defined to allow compiling SPL.
This patch converts #ifdef CONFIG_DM_SPI* to #if CONFIG_IS_ENABLED(DM_SPI)
and provides corresponding defines in Kconfig.
Signed-off-by: Lukasz Majewski <lukma@denx.de>
Tested-by: Adam Ford <aford173@gmail.com> #da850-evm
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com>
[trini: Fixup a few platforms]
Due to how the Makefile logic is we currently get DM_SPI support in SPL
enabled by having DM_SPI enabled for full U-Boot but not having
CONFIG_SPL_DM_SPI set. Add this missing option to boards that were
inadvertently making use of it.
Cc: Adam Ford <aford173@gmail.com>
Cc: Akash Gajjar <akash@openedev.com>
Cc: Andy Yan <andy.yan@rock-chips.com>
Cc: Anup Patel <anup.patel@wdc.com>
Cc: Atish Patra <atish.patra@wdc.com>
Cc: Bin Meng <bmeng.cn@gmail.com>
Cc: Chee Hong Ang <chee.hong.ang@intel.com>
Cc: Chin-Liang See <clsee@altera.com>
Cc: Dalon Westergreen <dwesterg@gmail.com>
Cc: Dinh Nguyen <dinguyen@kernel.org>
Cc: Eugen Hristev <eugen.hristev@microchip.com>
Cc: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
Cc: Jagan Teki <jagan@amarulasolutions.com>
Cc: Klaus Goger <klaus.goger@theobroma-systems.com>
Cc: Levin Du <djw@t-chip.com.cn>
Cc: Ley Foon Tan <ley.foon.tan@intel.com>
Cc: Lokesh Vutla <lokeshvutla@ti.com>
Cc: Luca Ceresoli <luca@lucaceresoli.net>
Cc: Mike Looijmans <mike.looijmans@topic.nl>
Cc: Nicolas Ferre <nicolas.ferre@microchip.com>
Cc: Nikita Kiryanov <nikita@compulab.co.il>
Cc: Palmer Dabbelt <palmer@dabbelt.com>
Cc: Paul Walmsley <paul.walmsley@sifive.com>
Cc: Pavel Machek <pavel@denx.de>
Cc: Peter Robinson <pbrobinson@gmail.com>
Cc: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Suniel Mahesh <sunil@amarulasolutions.com>
Cc: Vitaly Andrianov <vitalya@ti.com>
Cc: Wolfgang Grandegger <wg@aries-embedded.de>
Reviewed-by: Luca Ceresoli <luca@lucaceresoli.net>
CONFIG_BOOTP_DNS2
CONFIG_BOOTP_PXE_CLIENTARCH
Enable Android commands that will be needed for Android 10 boot flow
implementation, for all AM57x variants. Commands enabled:
1. 'abootimg':
- CONFIG_CMD_ABOOTIMG=y
2. 'ab_select':
- CONFIG_ANDROID_AB=y
- CONFIG_CMD_AB_SELECT=y
3. 'avb':
- CONFIG_LIBAVB=y
- CONFIG_AVB_VERIFY=y
- CONFIG_CMD_AVB=y
While at it, resync defconfig files with "make savedefconfig".
Signed-off-by: Sam Protsenko <joe.skb7@gmail.com>
Rename CONFIG_SPL_DMA_SUPPORT to CONFIG_SPL_DMA. This allows to use
macros such as CONFIG_IS_ENABLED() that allow conditional compilation of
code for SPL and U-Boot.
Signed-off-by: Vignesh Raghavendra <vigneshr@ti.com>
Rename the existing 'dtimg' command to 'adtimg', in order to:
- Suggest the Android origins and scope
- Be consistent with the upcoming 'abootimg' command (naming
suggested by Simon [*])
The change in _not_ backward compatible, but its benefits outweigh its
downsides, given that we don't expect active users of 'dtimg' today.
Perform the rename in several steps:
1. Rename *.c file and Kconfig symbol. This should allow
'git log --follow' to properly track the history of 'adtimg.c'
2. 's/dtimg/adtimg/g' in the internal namespace of 'adtimg.c'
ELF comparison [**] before and after shows no functional change.
[*] https://patchwork.ozlabs.org/patch/1182212/#2291600
[**] diff -u <(objdump -d cmd/dtimg.o) <(objdump -d cmd/adtimg.o)
Signed-off-by: Eugeniu Rosca <erosca@de.adit-jv.com>
Reviewed-by: Simon Glass<sjg@chromium.org>
Reviewed-by: Sam Protsenko <semen.protsenko@linaro.org>
MTD must be enabled when there is a SPI NOR flash using the
SPI_FLASH_MTD config entry.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
Move this symbol to Kconfig. As part of this we can drop a UBI-specific
symbol that was a stop-gap for not having this particular symbol in
Kconfig.
CONFIG_SYS_SPI_U_BOOT_OFFS
Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
[trini: Expose this for SPL_SPI_SUNXI for now]
We are going to implement DTBO partition for BeagleBoard X15 further. To
support this, 'dtimg' command must be enabled.
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
It is essential to have an access to BCB area of 'misc' partition on
Android devices [1]. For BeagleBoard X15 the 'bcb' command will be
further used for reboot reason implementation and booting to recovery.
It can be also used for debugging reasons, like checking RescueParty
messages in BCB area.
[1] doc/android/bcb.txt
CONFIG_SUPPORT_EMMC_BOOT
As requested by Michal Simek <michal.simek@xilinx.com>, these boards
have no eMMC so CONFIG_SUPPORT_EMMC_BOOT has not been migrated:
xilinx_zynqmp_zc1275_revB
xilinx_zynqmp_zc1751_xm018_dc4
xilinx_zynqmp_zc1751_xm019_dc5
xilinx_zynqmp_zcu100_revC
xilinx_zynqmp_zcu102_rev1_0
xilinx_zynqmp_zcu102_revA
xilinx_zynqmp_zcu102_revB
xilinx_zynqmp_zcu104_revA
xilinx_zynqmp_zcu104_revC
xilinx_zynqmp_zcu106_revA
xilinx_zynqmp_zcu111_revA
Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
Acked-by: Lukasz Majewski <lukma@denx.de>
Acked-by: Patrick Delaunay <patrick.delaunay@st.com>
Acked-by: Ramon Fried <ramon.fried@gmail.com>
Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Tested-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com>
CONFIG_SF_DEFAULT_BUS
CONFIG_SF_DEFAULT_CS
CONFIG_SF_DEFAULT_MODE
CONFIG_SF_DEFAULT_SPEED
I use moveconfig script and then manual check on generated u-boot.cfg
to solve the remaining issue.
Enable CONFIG_DM_SCSI and CONFIG_BLK.
Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
Additions have been made to the non-HS defconfig without the same
being made to the HS defconfig, sync them.
Signed-off-by: Andrew F. Davis <afd@ti.com>
Now that new SPI NOR layer uses stateless 4 byte opcodes by default,
don't enable SPI_FLASH_BAR. For SPI controllers that cannot support
4-byte addressing, (stm32_qspi.c, fsl_qspi.c, mtk_qspi.c, ich.c,
renesas_rpc_spi.c) add an imply clause to enable SPI_FLASH_BAR so as to
not break functionality.
Signed-off-by: Vignesh R <vigneshr@ti.com>
Tested-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
Tested-by: Stefan Roese <sr@denx.de>
Tested-by: Horatiu Vultur <horatiu.vultur@microchip.com>
Reviewed-by: Jagan Teki <jagan@openedev.com>
Tested-by: Jagan Teki <jagan@amarulasolutions.com> #zynq-microzed
- DM_I2C_COMPAT removal for all ti platforms from Jean-Jacques Hiblot
- Fix in i2c command help output from Chirstoph Muellner.
Those platforms need CONFIG_SPL_DM_SEQ_ALIAS because they enable both
DM_I2C and SPL_DM. Without CONFIG_SPL_DM_SEQ_ALIAS, it is not possible to
get the I2C bus with i2c_get_chip_for_busnum().
Reviewed-by: Felix Brack <fb@ltec.ch>
Tested-by: Felix Brack <fb@ltec.ch>
Enable DM_USB and DM_USB_DEV for AM57xx based boards.
beagleboard x15 is the first supported platform variant of am57xx
in AOSP (android open source project) now.
changing board name to stay in consistent with aosp target name.
CONFIG_MISC_INIT_R
[trini: Update the defaults logic slightly]
CONFIG_MII
CONFIG_DRIVER_TI_EMAC
Acked-by: Jagan Teki <jagan@amarulasolutions.com>
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
Convert USB fastboot code to use shared fastboot protocol.
Separate CMD_FASTBOOT from FASTBOOT and move code and configuration to
drivers/fastboot.
Switch dependencies on FASTBOOT to USB_FUNCTION_FASTBOOT as anyone who wants
FASTBOOT before this series wants USB_FUNCTION_FASTBOOT. Split
USB_FUNCTION_FASTBOOT from FASTBOOT so they retain their existing
behaviour.
CONFIG_SPI
This partly involves updating code that assumes that CONFIG_SPI implies
things that are specific to the MPC8xx SPI driver. For now, just update
the CONFIG tests. This also involves reworking the default for
CONFIG_SYS_DEF_EEPROM_ADDR so that we don't set it when we cannot make a
reasonable default, as it does not cause any compile failures.
Add Kconfig entry for CONFIG_SPL_SPI_LOAD symbol and move all
configurations using it to Kconfig.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
