Rename these options so that CONFIG_IS_ENABLED can be used with them.
Rename this option so that CONFIG_IS_ENABLED can be used with it.
Remove the environment support for various legacy boot methods. With
this, we will now default to booting any distribution that follows the
generic distro boot framework and no longer attempt to boot various
legacy (to this SoC) scripts/etc.
Link: https://lore.kernel.org/r/20210701132612.7559-1-trini@konsulko.com
At present we use the empty string to indicate that there is no FIT
generator, but this doesn't allow an individual board to undefine it.
Create a separate bool instead.
Update the config of the boards which currently have an empty string.
CONFIG_BOOTP_SEND_HOSTNAME
CONFIG_SPL_NAND_BASE
CONFIG_SPL_NAND_IDENT
CONFIG_SPL_NAND_DRIVERS
CONFIG_SPL_NAND_ECC
CONFIG_SPL_NAND_SIMPLE
CONFIG_ENV_OVERWRITE
[trini: Rerun migration, remove some comments]
Merge all outstanding changes from the current next branch in now that
we have released.
CONFIG_CONS_INDEX
CONFIG_BOOTP_DNS2
CONFIG_BOOTP_PXE_CLIENTARCH
Sync new additions to non-HS defconfig with HS defconfig.
Signed-off-by: Andrew F. Davis <afd@ti.com>
Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
MTD support must be enabled when using mtdparts. Indeed, functions
like get_mtd_info(), get_mtd_device() and put_mtd_device() are in
drivers/mtd/mtd_uboot.c and are built only with CONFIG_MTD.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
Both symbols must be enabled when there is a raw NAND driver
selected. Also enable them when CONFIG_CMD_NAND is selected to avoid
breaking things when we'll further rework the MTD dependency
description.
[trini: Rebase and migrate a few more boards here]
Add more clarity by changing the Kconfig entry name.
[trini: Re-run migration, update a few more cases]
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
Enable CONFIG_DM_USB to remove compile warning for
am43xx based targets:
===================== WARNING ======================
This board does not use CONFIG_DM_USB. Please update
the board to use CONFIG_DM_USB before the v2019.07 release.
Failure to update by the deadline may result in board removal.
See doc/driver-model/MIGRATION.txt for more info.
Signed-off-by: Suniel Mahesh <sunil.m@techveda.org>
CONFIG_ARCH_CPU_INIT
Acked-by: Chris Packham <chris.packham@alliedtelesis.co.nz>
Tested-by: Felix Brack <fb@ltec.ch>
With DM_MMC enabled, enable CONFIG_BLK to remove this
compile warning for am43xx based targets:
This board does not use CONFIG_DM_MMC. Please update
the board to use CONFIG_DM_MMC before the v2019.04 release.
Targets were compile tested, build was clean.
Enable the extended ENV options for AT91 and OMAP2PLUS in order to be
able to use CONFIG_ENV_UBI_* on these architectures.
As this change also makes the configs ENV_SIZE, ENV_SECT_SIZE,
ENV_OFFSET visible to AT91 and OMAP2PLUS, migrate users of these to
KConfig.
This migration was run using an extended moveconfig.py which evaluates
expressions such as "(512 << 10)". See patch ("moveconfig: expand
simple expressions").
All modified boards were built with SOURCE_DATE_EPOCH=0 before and
after the change and successfully confirmed that the identical binary
is generated (the only exception was igep00x0, which does not define
CONFIG_ENV_IS_IN_UBI in the original board header. Once that is
defined, the test passes too).
hs: rebased patch to:
68b90e57bc: "configs: tinker-rk3288 disable CONFIG_SPL_I2C_SUPPORT"
Signed-off-by: Markus Klotzbuecher <markus.klotzbuecher@kistler.com>
Cc: Eugen Hristev <eugen.hristev@microchip.com>
Moved CONFIG_SPL_TEXT_BASE to common/spl/Kconfig and migrate existing
values.
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
[trini: Re-run migration]
CONFIG_SF_DEFAULT_BUS
CONFIG_SF_DEFAULT_CS
CONFIG_SF_DEFAULT_MODE
CONFIG_SF_DEFAULT_SPEED
I use moveconfig script and then manual check on generated u-boot.cfg
to solve the remaining issue.
Since there is the SPL_USB_HOST_SUPPORT for enabling USB support in SPL,
makes more sense to rename the SPL_USB_SUPPORT as SPL_USB_STORAGE.
Everything that is not part of the usb storage support in SPL is now
build under SPL_USB_HOST_SUPPORT.
Signed-off-by: Abel Vesa <abel.vesa@nxp.com>
Reviewed-by: Fabio Estevam <festevam@gmail.com>
Reviewed-by: Lukasz Majewski <lukma@denx.de>
The SPL option for USB gadget should be named after the option for u-boot
(CONFIG_USB_GADGET)
Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
CONFIG_MISC_INIT_R
[trini: Update the defaults logic slightly]
CONFIG_MII
CONFIG_DRIVER_TI_EMAC
Acked-by: Jagan Teki <jagan@amarulasolutions.com>
CONFIG_SPI
This partly involves updating code that assumes that CONFIG_SPI implies
things that are specific to the MPC8xx SPI driver. For now, just update
the CONFIG tests. This also involves reworking the default for
CONFIG_SYS_DEF_EEPROM_ADDR so that we don't set it when we cannot make a
reasonable default, as it does not cause any compile failures.
Convert CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG to Kconfig
Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
Reviewed-by: Petr Vorel <petr.vorel@gmail.com>
Reviewed-by: Petr Vorel <petr.vorel at gmail.com>
This converts CONFIG_DRIVER_TI_CPSW to Kconfig
U-boot CONFIG
Rename CONFIG_SPL_USBETH_SUPPORT to CONFIG_SPL_USB_ETHER.
This enables users to block text using CONFIG_IS_ENABLED() instead
of resorting to #if ladders with SPL and non-SPL cases.
Signed-off-by: Faiz Abbas <faiz_abbas@ti.com>
CONFIG_BOOTP_BOOTPATH
CONFIG_BOOTP_DNS
CONFIG_BOOTP_GATEWAY
CONFIG_BOOTP_HOSTNAME
CONFIG_BOOTP_PXE
CONFIG_BOOTP_SUBNETMASK
CONFIG_CMDLINE_EDITING
CONFIG_AUTO_COMPLETE
CONFIG_SYS_LONGHELP
CONFIG_SUPPORT_RAW_INITRD
CONFIG_ENV_VARS_UBOOT_CONFIG
[trini: Re-run the migration]
A number of platforms include config_distro_defaults.h but do not enable
CONFIG_DISTRO_DEFAULTS. As they plainly intended to, set that flag and
re-sync config files.
CONFIG_OMAP_USB_PHY
