Move this option to Kconfig and tidy up existing uses.
Move the SPL settings into common/spl where most of the SPL code is kept.
move VERSION_VARIABLE from board config file into a
Kconfig option.
In some cases we were missing CONFIG_USB=y so enable that when needed.
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
With updated moveconfig.py and an better default, re-generate
the migration of BOOTDELAY to the defconfig.
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
move CONFIG_BOOTDELAY into a Kconfig option. Used for this
purpose the moveconfig.py tool in tools.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Create an entry for "config USB_XHCI_DWC3" in Kconfig and
switch over to it for all boards.
Move CONFIG_USB_XHCI to defconfig files for all boards, renaming it
into CONFIG_USB_XHCI_HCD.
As commented in the help of "config USB_XHCI" entry, this has been
a TODO for a long time; now CONFIG_USB_XHCI_HCD and CONFIG_USB_XHCI
have been unified in favor of the former.
Note:
Some boards define CONFIG_USB_XHCI in their headers without
CONFIG_USB, which does not meet the "depends on" in Kconfig.
I added CONFIG_USB=y for those boards when converting.
Otherwise, they would fail to build.
Convert usb host boot defconfig to use DM, DT. Also enable FIT
support.
Updates configs/am43xx_evm.h to use CONFIG options from
SOC specific Kconfig file for various calculations.
On AM43x devices, the address of SPL entry point depends on
the device type, i.e. whether it is secure or non-secure.
Further, for non-secure devices, the SPL entry point is different
between USB HOST boot mode, other "memory" boot modes (MMC, NAND)
and "peripheral" boot modes (UART, USB)
To add to the complexity, on secure devices, in addition to the
above differences, the SPL entry point can change because of the
space occupied by other components (other than u-boot or spl)
that go into a secure boot image.
To prevent the user from having to modify source files every time
any component of the secure image changes, the value of
CONFIG_SPL_TEXT_BASE has been set using a Kconfig option that
is supplied in the am43xx_*_defconfig files
Using the CONFIG options also enables us to do away with some
compile time flags that were used to specify CONFIG_SPL_TEXT_BASE
for different boot modes.
On QSPI devices, the same problem described above occurs w.r.t. the
address of the u-boot entry point in flash, when booting secure
devices. To handle this, CONFIG_SYS_TEXT_BASE is also setup via
a Kconfig option and the defconfig files.
Signed-off-by: Madan Srinivas <madans@ti.com>
Signed-off-by: Daniel Allred <d-allred@ti.com>
Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
Tested-by: Andreas Dannenberg <dannenberg@ti.com>
Adding support for AM43xx secure devices require the addition
of some SOC specific config options like the amount of memory
used by public ROM and the address of the entry point of u-boot
or SPL, as seen by the ROM code, for the image to be built
correctly.
This mandates the addition of am AM43xx CONFIG option and the
ARM Kconfig file has been modified to source this SOC Kconfig
file. Moving the TARGET_AM43XX_EVM config option to the SOC
KConfig and out of the arch/arm/Kconfig.
Updating defconfigs to add the CONFIG_AM43XX=y statement and
removing the #define CONFIG_AM43XX from the header file.
This patch also adds the SPL time VCI string into Kconfig.
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
And also reformat defconfigs using "make savedefconfig" rule.
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
Description was borrowed from kernel dwc3 Kconfig.
While at it, remove obsolete CONFIG_USBDOWNLOAD_GADGET option from some
config headers. This is also probably fixes am335x_baltos board.
Move CONFIG_USB_GADGET_DUALSPEED option to Kconfig and
make all UDC controllers select USB_GADGET_DUALSPEED:
- add next options to Kconfig selecting USB_GADGET_DUALSPEED:
- USB_GADGET_ATMEL_USBA
- USB_GADGET_DWC2_OTG
- USB_DWC3
- CI_UDC
- make USB_MUSB_GADGET select USB_GADGET_DUALSPEED
While at it, make some related fixes:
- remove DUALSPEED from configs that don't enable gadget support:
- kwb.h
- tseries.h
- add missing USB_GADGET option to next configs:
- novena_defconfig
- pcm051_rev*_defconfig
- xfi3_defconfig
The description was borrowed from kernel. "tristate" type was changed
to "bool" (I believe we don't support modules for u-boot yet, right?).
CONFIG_USB_GADGET requires CONFIG_USB to be defined too, so add it along
as well.
Definitions were added to defconfig files in a way that
"make savedefconfig" generates exactly the same file as used defconfig.
[trini: Add zynq_zc702 conversion]
There are already Kconfig options for SPI flash drivers, but we
have not moved them from config.h to defconfig files. This commit
does this in a batch.
There are already Kconfig options for SPI drivers, but we
commit does this in a batch.
Add CMD_GPIO to Kconfig and run tools/moveconfig.py .
them from include/configs.
Some archs/boards specify their own default by pre-defining the config
which causes the Kconfig system to mix up the order of the configs in
the defconfigs... This will cause merge pain if allowed to proliferate.
Remove the configs that behave this way from the archs.
A few configs still remain, but that is because they only exist as
defaults and do not have a proper Kconfig entry. Those appear to be:
SPIFLASH
DISPLAY_BOARDINFO
[trini: rastaban, am43xx_evm_usbhost_boot, am43xx_evm_ethboot updates,
drop DM_USB from MSI_Primo81 as USB_MUSB_SUNXI isn't converted yet to DM]
While booting via usb host mode, ROM uses DMA to copy MLO over USB so
ARM internal RAM cannot be used. Adding USB host boot support by
introducing new config target which sets SPL_TEXT_BASE to OCMC ram.
Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
