Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
And also reformat defconfigs using "make savedefconfig" rule.
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
Description was borrowed from kernel dwc3 Kconfig.
While at it, remove obsolete CONFIG_USBDOWNLOAD_GADGET option from some
config headers. This is also probably fixes am335x_baltos board.
Move CONFIG_USB_GADGET_DUALSPEED option to Kconfig and
make all UDC controllers select USB_GADGET_DUALSPEED:
- add next options to Kconfig selecting USB_GADGET_DUALSPEED:
- USB_GADGET_ATMEL_USBA
- USB_GADGET_DWC2_OTG
- USB_DWC3
- CI_UDC
- make USB_MUSB_GADGET select USB_GADGET_DUALSPEED
While at it, make some related fixes:
- remove DUALSPEED from configs that don't enable gadget support:
- kwb.h
- tseries.h
- add missing USB_GADGET option to next configs:
- novena_defconfig
- pcm051_rev*_defconfig
- xfi3_defconfig
The description was borrowed from kernel. "tristate" type was changed
to "bool" (I believe we don't support modules for u-boot yet, right?).
CONFIG_USB_GADGET requires CONFIG_USB to be defined too, so add it along
as well.
Definitions were added to defconfig files in a way that
"make savedefconfig" generates exactly the same file as used defconfig.
[trini: Add zynq_zc702 conversion]
Some boards' defconfig files are out of order. Clean this up.
Various boards have the wrong Kconfig ordering now. To avoid a misleading
diff in the next patch, reorder the configuration correctly.
enable dma driver model for am437x_sk_evm as ti-edma3 supports
driver model
Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
Reviewed-by: Jagan Teki <jteki@openedev.com>
Enable timer driver model for am437x_sk_evm as omap-timer supports
driver model.
enable spi driver model for am437x_sk_evm as ti_qspi supports
driver model
There are already Kconfig options for SPI flash drivers, but we
have not moved them from config.h to defconfig files. This commit
does this in a batch.
There are already Kconfig options for SPI drivers, but we
commit does this in a batch.
Add CMD_GPIO to Kconfig and run tools/moveconfig.py .
Import various DT files for am437x-sk-evm from Linux Kernel v4.2
Add config file for this board, enable DM, DM_GPIO, DM_SERIAL
and DM_MMC.
Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
