path: root/configs/am335x_sl50_defconfig
2019-01-19configs: Resync with savedefconfigTom Rini
2019-01-15am335x: sl50: Add Device Tree Support and DM_MMC driverEnric Balletbo i Serra
This adds device tree and the DM_MMC driver for the SL50 board. Signed-off-by: Enric Balletbo i Serra <enric.balletbo@collabora.com>
2019-01-07configs: Resync with savedefconfigTom Rini
2018-11-13configs: Resync with savedefconfigTom Rini
2018-04-08Migrate CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG to KconfigAlex Kiernan
Convert CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG to Kconfig Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Petr Vorel <petr.vorel@gmail.com> Reviewed-by: Petr Vorel <petr.vorel at gmail.com>
2018-04-08Migrate CONFIG_DRIVER_TI_CPSW to KconfigAlex Kiernan
This converts CONFIG_DRIVER_TI_CPSW to Kconfig Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-02-15Convert CONFIG_BOOTCOUNT_LIMIT to KconfigLukasz Majewski
This converts the following to Kconfig: CONFIG_BOOTCOUNT_LIMIT Signed-off-by: Lukasz Majewski <lukma@denx.de> Tested-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com> Acked-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
2017-10-20Convert CONFIG_NAND_OMAP_GPMC et al and CONFIG_NAND_MXC to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_NAND_MXC CONFIG_NAND_OMAP_GPMC CONFIG_NAND_OMAP_GPMC_PREFETCH CONFIG_NAND_OMAP_ELM CONFIG_SPL_NAND_AM33XX_BCH CONFIG_SPL_NAND_SIMPLE CONFIG_SYS_NAND_BUSWIDTH_16BIT Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> [trini: Finish migration of CONFIG_SPL_NAND_SIMPLE, fix some build issues, add CONFIG_NAND_MXC so we can do CONFIG_SYS_NAND_BUSWIDTH_16BIT] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-09-29TI: ARCH_OMAP2PLUS: Enable SPL_STACK_R and provide default valueTom Rini
On ARCH_OMAP2PLUS platforms we know what the DDR layout is going to be, and that it is safe to use SPL_STACK_R and provide a default value for it. select this and re-sync the defconfigs. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-13Convert CONFIG_OMAP3_SPI to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_OMAP3_SPI Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Minor comment tweaks] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-11Convert CONFIG_CMD_SPL to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_SPL Note that trats does not actually use SPL, so this option can no-longer be set. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-07-24configs: Migrate RBTREE, LZO, CMD_MTDPARTS, CMD_UBI and CMD_UBIFSTom Rini
The above CONFIG options are in Kconfig, and now have correct depends and inter-dependencies. Migrate these to configs/ from include/configs/. In the case of CMD_UBIFS also change it to be a default y if CMD_UBI. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-07-07am335x: sl50: Enable CONFIG_AUTOBOOT_KEYEDEnric Balletbo i Serra
On startup the SL50 board halt at U-Boot prompt. Use CONFIG_AUTOBOOT_KEYED to enable autoboot for this board and define the <SPACE> key to get the U-Boot prompt. Signed-off-by: Enric Balletbo i Serra <enric.balletbo@collabora.com>
2017-06-03Kconfig: Migrate FS_FAT / FAT_WRITETom Rini
Now that these symbols are in Kconfig, migrate all users. Use imply on a number of platforms that default to having this enabled. As part of this we must migrate some straglers for CMD_FAT and DOS_PARTITION. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-22Convert CONFIG_CMD_EEPROM et al to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_EEPROM CONFIG_CMD_EEPROM_LAYOUT CONFIG_EEPROM_LAYOUT_HELP_STRING Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Rework Kconfig logic slightly, define EEPROM location on TI eval platforms] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-27ARM: omap2+: rename config to ARCH_OMAP2PLUS and consolidate KconfigMasahiro Yamada
In Linux, CONFIG_ARCH_OMAP2PLUS is used for OMAP2 or later SoCs. Rename CONFIG_ARCH_OMAP2 to CONFIG_ARCH_OMAP2PLUS to follow this naming. Move the OMAP2+ board/SoC choice down to mach-omap2/Kconfig to slim down the arch/arm/Kconfig level. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-04-27Kconfig: Enable FIT support by default for TI platformsAndrew F. Davis
Almost all TI defconfigs enable this already, add this as a default and remove the explicit assignment. Signed-off-by: Andrew F. Davis <afd@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-01-11mmc: move more driver config options to KconfigMasahiro Yamada
Move (and rename) the following CONFIG options to Kconfig: CONFIG_DAVINCI_MMC (renamed to CONFIG_MMC_DAVINCI) CONFIG_OMAP_HSMMC (renamed to CONFIG_MMC_OMAP_HS) CONFIG_MXC_MMC (renamed to CONFIG_MMC_MXC) CONFIG_MXS_MMC (renamed to CONFIG_MMC_MXS) CONFIG_TEGRA_MMC (renamed to CONFIG_MMC_SDHCI_TEGRA) CONFIG_SUNXI_MMC (renamed to CONFIG_MMC_SUNXI) They are the same option names as used in Linux. This commit was created as follows: [1] Rename the options with the following command: find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \ -type f -print | xargs sed -i -e ' s/CONFIG_DAVINCI_MMC/CONFIG_MMC_DAVINCI/g s/CONFIG_OMAP_HSMMC/CONFIG_MMC_OMAP_HS/g s/CONFIG_MXC_MMC/CONFIG_MMC_MXC/g s/CONFIG_MXS_MMC/CONFIG_MMC_MXS/g s/CONFIG_TEGRA_MMC/CONFIG_MMC_SDHCI_TEGRA/g s/CONFIG_SUNXI_MMC/CONFIG_MMC_SUNXI/g ' [2] Commit the changes [3] Create entries in driver/mmc/Kconfig. (copied from Linux) [4] Move the options with the following command tools/moveconfig.py -y -r HEAD \ MMC_DAVINCI MMC_OMAP_HS MMC_MXC MMC_MXS MMC_SDHCI_TEGRA MMC_SUNXI [5] Sort and align drivers/mmc/Makefile for readability Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Marek Vasut <marex@denx.de>
2016-12-03Enable DISTRO_DEFAULT on platforms that missed it beforeTom Rini
A number of platforms had been using the distro default feature before it was moved to Kconfig but did not enable the new Kconfig option when it was enabled. This caused a regression in terms of features and this introduces breakage when more things move to Kconfig. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-14spl: move SPL_OS_BOOT to KconfigHeiko Schocher
Move SPL_OS_BOOT to Kconfig and cleanup existing uses. Signed-off-by: Heiko Schocher <hs@denx.de>
2016-10-02Kconfig: Separate AM33XX SOC config from target board configAndrew F. Davis
The config option AM33XX is used in several boards and should be defined as a stand-alone option for this SOC. We break this out from target boards that use this SoC and common headers then enable AM33XX on in all the boards that used these targets to eliminate any functional change with this patch. This is similar to what has already been done in 9de852642cae ("arm: Kconfig: Add support for AM43xx SoC specific Kconfig") and is done for the same reasons. Signed-off-by: Andrew F. Davis <afd@ti.com> Acked-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-09-16Convert CONFIG_SPL_YMODEM_SUPPORT to KconfigSimon Glass
Convert CONFIG_SPL_YMODEM_SUPPORT to Kconfig Move this option to Kconfig and tidy up existing uses. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-09-16Convert CONFIG_SPL_WATCHDOG_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_POWER_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_LIBDISK_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_FAT_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_EXT_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_ENV_SUPPORT to KconfigSimon Glass
