Move SPL_OS_BOOT to Kconfig and cleanup existing
uses.
The config option AM33XX is used in several boards and should be
defined as a stand-alone option for this SOC. We break this out
from target boards that use this SoC and common headers then enable
AM33XX on in all the boards that used these targets to eliminate any
functional change with this patch.
This is similar to what has already been done in
9de852642cae ("arm: Kconfig: Add support for AM43xx SoC specific Kconfig")
and is done for the same reasons.
Signed-off-by: Andrew F. Davis <afd@ti.com>
Acked-by: Lokesh Vutla <lokeshvutla@ti.com>
Convert CONFIG_SPL_YMODEM_SUPPORT to Kconfig
Move this option to Kconfig and tidy up existing uses.
Move the SPL settings into common/spl where most of the SPL code is kept.
move VERSION_VARIABLE from board config file into a
Kconfig option.
Since commit bb597c0eeb7e ("common: bootdelay: move CONFIG_BOOTDELAY
into a Kconfig option"), CONFIG_BOOTDELAY is defined for all boards.
Prior to that commit, it was allowed to unset CONFIG_BOOTDELAY to
not compile common/autoboot.c, as described in common/Makefile:
# This option is not just y/n - it can have a numeric value
ifdef CONFIG_BOOTDELAY
obj-y += autoboot.o
endif
It was a bit odd to enable/disable code with an integer type option,
but it was how this option worked before that commit, and several
boards actually unset it to opt out of the autoboot feature.
This commit adds a new bool option, CONFIG_AUTOBOOT, and makes
CONFIG_BOOTDELAY depend on it.
I chose "default y" for this option because most boards use the
autoboot. I added "# CONFIG_AUTOBOOT is not set" for the boards that
had not set CONFIG_BOOTDELAY prior to the bad commit.
move CONFIG_BOOTDELAY into a Kconfig option. Used for this
purpose the moveconfig.py tool in tools.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
This patch also adds the SPL time VCI string into Kconfig.
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
There are already two FIT options in Kconfig but the CONFIG options are
still in the header files. We need to do a proper move to fix this.
Move these options to Kconfig and tidy up board configuration:
CONFIG_FIT
CONFIG_OF_BOARD_SETUP
CONFIG_OF_SYSTEM_SETUP
CONFIG_FIT_SIGNATURE
CONFIG_FIT_BEST_MATCH
CONFIG_FIT_VERBOSE
CONFIG_OF_STDOUT_VIA_ALIAS
CONFIG_RSA
Unfortunately the first one is a little complicated. We need to make sure
this option is not enabled in SPL by this change. Also this option is
enabled automatically in the host builds by defining CONFIG_FIT in the
image.h file. To solve this, add a new IMAGE_USE_FIT #define which can
be used in files that are built on the host but must also build for U-Boot
and SPL.
Note: Masahiro's moveconfig.py script is amazing.
[trini: Add microblaze change, various configs/ re-applies]
Add CMD_GPIO to Kconfig and run tools/moveconfig.py .
Some boards' defconfigs are disordered. Reorder them.
Add support for Lightwriter SL50 series board, a small, robust and portable
Voice Output Communication Aids (VOCA) designed to meet the particular and
changing needs of people with speech loss resulting from a wide range of
acquired, progressive and congenital conditions.
Signed-off-by: Enric Balletbo i Serra <enric.balletbo@collabora.com>
