path: root/configs/am335x_shc_sdboot_prompt_defconfig
2016-09-16Convert CONFIG_SPL_LIBDISK_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_FAT_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_EXT_SUPPORT to KconfigSimon Glass
2016-06-09am335x, shc: add support for the am335x based bosch shc boardHeiko Schocher
U-Boot SPL 2016.03-rc3-00019-g6dfb4c2-dirty (Mar 09 2016 - 07:40:06) SHC C3-Sample MPU reference clock runs at 6 MHz Setting MPU clock to 594 MHz Enabling Spread Spectrum of 18 permille for MPU Trying to boot from MMC reading u-boot.img reading u-boot.img U-Boot 2016.03-rc3-00019-g6dfb4c2-dirty (Mar 09 2016 - 07:05:35 +0100) Watchdog enabled I2C: ready DRAM: 512 MiB reloc off 1f783000 MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1 Net: cpsw U-Boot# Signed-off-by: Heiko Schocher <hs@denx.de>
