path: root/configs/am335x_shc_ict_defconfig
2016-10-14spl: move SPL_OS_BOOT to KconfigHeiko Schocher
Move SPL_OS_BOOT to Kconfig and cleanup existing uses. Signed-off-by: Heiko Schocher <hs@denx.de>
2016-10-02Kconfig: Separate AM33XX SOC config from target board configAndrew F. Davis
The config option AM33XX is used in several boards and should be defined as a stand-alone option for this SOC. We break this out from target boards that use this SoC and common headers then enable AM33XX on in all the boards that used these targets to eliminate any functional change with this patch. This is similar to what has already been done in 9de852642cae ("arm: Kconfig: Add support for AM43xx SoC specific Kconfig") and is done for the same reasons. Signed-off-by: Andrew F. Davis <afd@ti.com> Acked-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-09-16Convert CONFIG_SPL_YMODEM_SUPPORT to KconfigSimon Glass
Convert CONFIG_SPL_YMODEM_SUPPORT to Kconfig Move this option to Kconfig and tidy up existing uses. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-09-16Convert CONFIG_SPL_WATCHDOG_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_POWER_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_LIBDISK_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_FAT_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_EXT_SUPPORT to KconfigSimon Glass
2016-06-09am335x, shc: add support for the am335x based bosch shc boardHeiko Schocher
U-Boot SPL 2016.03-rc3-00019-g6dfb4c2-dirty (Mar 09 2016 - 07:40:06) SHC C3-Sample MPU reference clock runs at 6 MHz Setting MPU clock to 594 MHz Enabling Spread Spectrum of 18 permille for MPU Trying to boot from MMC reading u-boot.img reading u-boot.img U-Boot 2016.03-rc3-00019-g6dfb4c2-dirty (Mar 09 2016 - 07:05:35 +0100) Watchdog enabled I2C: ready DRAM: 512 MiB reloc off 1f783000 MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1 Net: cpsw U-Boot# Signed-off-by: Heiko Schocher <hs@denx.de>
