CONFIG_BOOTP_SEND_HOSTNAME
CONFIG_SPL_NAND_BASE
CONFIG_SPL_NAND_IDENT
CONFIG_SPL_NAND_DRIVERS
CONFIG_SPL_NAND_ECC
CONFIG_SPL_NAND_SIMPLE
CONFIG_ENV_OVERWRITE
[trini: Rerun migration, remove some comments]
Enable DM_SPI for am355x igep003x board.
Build is fine, but not tested.
Cc: Javier MartÃnez Canillas <javier@dowhile0.org>
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
CONFIG_BOOTP_DNS2
CONFIG_BOOTP_PXE_CLIENTARCH
CONFIG_PHYLIB
CONFIG_BITBANGMII
CONFIG_MV88E6352_SWITCH
CONFIG_MV88E61XX_SWITCH
CONFIG_PHYLIB_10G
CONFIG_PHY_AQUANTIA
CONFIG_PHY_ATHEROS
CONFIG_PHY_BROADCOM
CONFIG_PHY_CORTINA
CONFIG_PHY_DAVICOM
CONFIG_PHY_ET1011C
CONFIG_PHY_LXT
CONFIG_PHY_MARVELL
CONFIG_PHY_MICREL
CONFIG_PHY_NATSEMI
CONFIG_PHY_REALTEK
CONFIG_RTL8211X_PHY_FORCE_MASTER
CONFIG_PHY_SMSC
CONFIG_PHY_TERANETICS
CONFIG_PHY_TI
CONFIG_PHY_VITESSE
CONFIG_PHY_XILINX
MTD support must be enabled when using mtdparts. Indeed, functions
like get_mtd_info(), get_mtd_device() and put_mtd_device() are in
drivers/mtd/mtd_uboot.c and are built only with CONFIG_MTD.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
UBI must be enabled when using fastmap, reflect this is defconfigs.
Both symbols must be enabled when there is a raw NAND driver
selected. Also enable them when CONFIG_CMD_NAND is selected to avoid
breaking things when we'll further rework the MTD dependency
description.
[trini: Rebase and migrate a few more boards here]
Add more clarity by changing the Kconfig entry name.
[trini: Re-run migration, update a few more cases]
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
Move this symbol to Kconfig. As part of this we can drop a UBI-specific
symbol that was a stop-gap for not having this particular symbol in
Kconfig.
CONFIG_ARCH_CPU_INIT
Acked-by: Chris Packham <chris.packham@alliedtelesis.co.nz>
Tested-by: Felix Brack <fb@ltec.ch>
Migrate the ubispl configuration for the omap3_igep00x0 and
am335x_igep003x boards to KConfig. Both boards were built with
SOURCE_DATE_EPOCH=0 and found to be equal before and after.
Signed-off-by: Markus Klotzbuecher <markus.klotzbuecher@kistler.com>
Cc: Kyungmin Park <kmpark@infradead.org>
Cc: Enric Balletbo i Serra <eballetbo@gmail.com>
Acked-by: Enric Balletbo i Serra <eballetbo@gmail.com>
Enable the extended ENV options for AT91 and OMAP2PLUS in order to be
able to use CONFIG_ENV_UBI_* on these architectures.
As this change also makes the configs ENV_SIZE, ENV_SECT_SIZE,
ENV_OFFSET visible to AT91 and OMAP2PLUS, migrate users of these to
KConfig.
This migration was run using an extended moveconfig.py which evaluates
expressions such as "(512 << 10)". See patch ("moveconfig: expand
simple expressions").
All modified boards were built with SOURCE_DATE_EPOCH=0 before and
after the change and successfully confirmed that the identical binary
is generated (the only exception was igep00x0, which does not define
CONFIG_ENV_IS_IN_UBI in the original board header. Once that is
defined, the test passes too).
hs: rebased patch to:
68b90e57bc: "configs: tinker-rk3288 disable CONFIG_SPL_I2C_SUPPORT"
Cc: Eugen Hristev <eugen.hristev@microchip.com>
Replace CONFIG_SPL_EXT_SUPPORT to CONFIG_SPLY_FS_EXT4 so both
obj-$(CONFIG_$(SPL_)FS_EXT4) and CONFIG_IS_ENABLED(FS_EXT4) can be
used to control the build in both SPL and U-Boot.
Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com>
Replace CONFIG_SPL_FAT_SUPPORT with CONFIG_SPL_FS_FAT so
obj-$(CONFIG_$(SPL_)FS_FAT) can be used to control the build in both
SPL and U-Boot.
This adds device tree and the DM_MMC driver for the AM335x IGEP based
boards.
Signed-off-by: Enric Balletbo i Serra <enric.balletbo@collabora.com>
Now that CMD_UBI does not select CMD_MTDPARTS we need to make platforms
that had been enabling it turn it on by hand. This exposed that we had
not yet migrated CMD_MTDPARTS fully, so do so now.
Fixes: 86dfa556d927 ("cmd: ubi: Remove useless call to mtdparts_init()")
CONFIG_MII
CONFIG_DRIVER_TI_EMAC
Acked-by: Jagan Teki <jagan@amarulasolutions.com>
CONFIG_SPI
This partly involves updating code that assumes that CONFIG_SPI implies
things that are specific to the MPC8xx SPI driver. For now, just update
the CONFIG tests. This also involves reworking the default for
CONFIG_SYS_DEF_EEPROM_ADDR so that we don't set it when we cannot make a
reasonable default, as it does not cause any compile failures.
Convert CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG to Kconfig
Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
Reviewed-by: Lukasz Majewski <lukma@denx.de>
Reviewed-by: Petr Vorel <petr.vorel@gmail.com>
Reviewed-by: Petr Vorel <petr.vorel at gmail.com>
This converts CONFIG_DRIVER_TI_CPSW to Kconfig
Signed-off-by: Petr Vorel <petr.vorel@gmail.com>
Introduce another difference from upstream (kernel) source in
fs/ubifs/super.c: adding preprocessor condition as y variable in
mount_ubifs() depends on CONFIG_UBIFS_SILENCE_MSG:
fs/ubifs/super.c:1337:15: error: variable ?y? set but not used [-Werror=unused-but-set-variable]
long long x, y;
Not setting CONFIG_UBIFS_SILENCE_MSG in am335x_igep003x_defconfig and
igep0032_defconfig. Although it was defined in their config headers, it
depends on CMD_UBIFS which is not set for them.
A number of platforms include config_distro_defaults.h but do not enable
CONFIG_DISTRO_DEFAULTS. As they plainly intended to, set that flag and
re-sync config files.
We move all instances of CONFIG_MTDIDS_DEFAULT and
CONFIG_MTDPARTS_DEFAULT from the header files to the defconfig files.
There's a few cases here where we need to expand upon what was in the
header file.
Tested-by: Adam Ford <aford173@gmail.com> #omap3_logic
Having this as a 'default y' is rather annoying because it doesn't
actually compile unless other options are defined in the board header:
../cmd/bootm.c: In function 'do_imls_nor':
../cmd/bootm.c:330:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
Make it 'default n' so people who develop new boards that start from a
blank defconfig have one less compilation failure to debug.
On ARCH_OMAP2PLUS platforms we know what the DDR layout is going to be,
and that it is safe to use SPL_STACK_R and provide a default value for
it. select this and re-sync the defconfigs.
CONFIG_OMAP3_SPI
[trini: Minor comment tweaks]
CONFIG_NAND
[trini: Sync up a few more, add imply's]
CONFIG_CMD_SPL
Note that trats does not actually use SPL, so this option can no-longer be
set.
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Signed-off-by: Alexandru Gagniuc <alex.g@adaptrum.com>
Migrate all remaining instances of CMD_NAND, CMD_NAND_TRIMFFS
CMD_NAND_LOCK_UNLOCK and CMD_NAND_TORTURE from the headers into the
defconfig files.
CONFIG_ENV_IS_IN_MMC
CONFIG_ENV_IS_IN_NAND
CONFIG_ENV_IS_NOWHERE
In fact this already exists for sunxi as a 'choice' config. However not
all the choices are available in Kconfig yet so we cannot use that. It
would lead to more than one option being set.
In addition, one purpose of this series is to allow the environment to be
stored in more than one place. So the existing choice is converted to a
normal config allowing each option to be set independently.
There are not many opportunities for Kconfig updates to reduce the size of
this patch. This was tested with
./tools/moveconfig.py -i CONFIG_ENV_IS_IN_MMC
And then manual updates. This is because for CHAIN_OF_TRUST boards they
can only have ENV_IS_NOWHERE set, so we enforce that via Kconfig logic
now.
The above CONFIG options are in Kconfig, and now have correct depends and
inter-dependencies. Migrate these to configs/ from include/configs/. In the
case of CMD_UBIFS also change it to be a default y if CMD_UBI.
Implement spl_start_uboot to let Falcon mode work.
Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
Acked-by: Heiko Schocher <hs@denx.de>
