path: root/configs/am335x_hs_evm_uart_defconfig
2019-04-19usb: Select USB_MUSB_DSPS with USB_MUSB_TIAlex Kiernan
USB_MUSB_TI requires USB_MUSB_DSPS, failing at link time if it's not selected: drivers/usb/musb-new/built-in.o: In function `ti_musb_host_ofdata_to_platdata': drivers/usb/musb-new/ti-musb.c:193: undefined reference to `musb_dsps_ops' or if OF_CONTROL is not selected: arch/arm/mach-omap2/built-in.o:(.data.usb0+0x24): undefined reference to `musb_dsps_ops' Reviewed-by: Hannes Schmelzer <oe5hpm@oevsv.at> Tested-by: Hannes Schmelzer <oe5hpm@oevsv.at> Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
2019-03-22configs: am335x_evm: Add CONFIG_BLKFaiz Abbas
With DM_MMC and DM_USB enabled, enable CONFIG_BLK. Signed-off-by: Faiz Abbas <faiz_abbas@ti.com>
2019-02-01spl: Kconfig: Replace CONFIG_SPL_EXT_SUPPORT to CONFIG_SPL_FS_EXT4Tien Fong Chee
Replace CONFIG_SPL_EXT_SUPPORT to CONFIG_SPLY_FS_EXT4 so both obj-$(CONFIG_$(SPL_)FS_EXT4) and CONFIG_IS_ENABLED(FS_EXT4) can be used to control the build in both SPL and U-Boot. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-02-01spl: Kconfig: Replace CONFIG_SPL_FAT_SUPPORT with CONFIG_SPL_FS_FATTien Fong Chee
Replace CONFIG_SPL_FAT_SUPPORT with CONFIG_SPL_FS_FAT so obj-$(CONFIG_$(SPL_)FS_FAT) can be used to control the build in both SPL and U-Boot. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com> Reviewed-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-01-18configs: am335x_evm: Enable DM_SPI and DM_SPI_FLASHVignesh R
Enable DM_SPI and DM_SPI_FLASH for actively used defconfigs for am335x_evm. Signed-off-by: Vignesh R <vigneshr@ti.com>
2018-12-12defconfigs: am335x_hs_evm: Sync HS and non-HS defconfigsAndrew F. Davis
Sync new additions to non-HS defconfig with HS defconfig. Signed-off-by: Andrew F. Davis <afd@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-12-07configs: am335x_hs_evm_uart: Add YMODEM SPL support for UART bootAndrew F. Davis
UART booting requires YMODEM support. Add this here. Signed-off-by: Andrew F. Davis <afd@ti.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-11-13configs: Resync with savedefconfigTom Rini
2018-04-08Migrate CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG to KconfigAlex Kiernan
Convert CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG to Kconfig Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Petr Vorel <petr.vorel@gmail.com> Reviewed-by: Petr Vorel <petr.vorel at gmail.com>
2018-04-08Migrate CONFIG_DRIVER_TI_CPSW to KconfigAlex Kiernan
This converts CONFIG_DRIVER_TI_CPSW to Kconfig Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-02-15Convert CONFIG_BOOTCOUNT_LIMIT to KconfigLukasz Majewski
This converts the following to Kconfig: CONFIG_BOOTCOUNT_LIMIT Signed-off-by: Lukasz Majewski <lukma@denx.de> Tested-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com> Acked-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
2018-01-22Convert CONFIG_USB_MUSB_OMAP2PLUS et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_USB_MUSB_OMAP2PLUS CONFIG_USB_MUSB_AM35X CONFIG_USB_MUSB_DSPS CONFIG_USB_MUSB_PIO_ONLY Signed-off-by: Adam Ford <aford173@gmail.com>
2017-12-18configs: Resync with savedefconfigTom Rini
2017-10-20Convert CONFIG_NAND_OMAP_GPMC et al and CONFIG_NAND_MXC to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_NAND_MXC CONFIG_NAND_OMAP_GPMC CONFIG_NAND_OMAP_GPMC_PREFETCH CONFIG_NAND_OMAP_ELM CONFIG_SPL_NAND_AM33XX_BCH CONFIG_SPL_NAND_SIMPLE CONFIG_SYS_NAND_BUSWIDTH_16BIT Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> [trini: Finish migration of CONFIG_SPL_NAND_SIMPLE, fix some build issues, add CONFIG_NAND_MXC so we can do CONFIG_SYS_NAND_BUSWIDTH_16BIT] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-10-16configs: Resync with savedefconfigTom Rini
2017-09-29defconfigs: Add a config for AM335x High Security EVM with UART Boot supportAndrew F. Davis
Add a new defconfig file for the AM335x High Security EVM. This config is specific for the case of UART booting Signed-off-by: Andrew F. Davis <afd@ti.com>
