path: root/configs/am335x_hs_evm_defconfig
2019-11-07configs: Resync with savedefconfigTom Rini
2019-08-25Convert CONFIG_ARCH_CPU_INIT to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_ARCH_CPU_INIT Signed-off-by: Adam Ford <aford173@gmail.com> Acked-by: Chris Packham <chris.packham@alliedtelesis.co.nz> Tested-by: Felix Brack <fb@ltec.ch>
2019-04-19usb: Select USB_MUSB_DSPS with USB_MUSB_TIAlex Kiernan
USB_MUSB_TI requires USB_MUSB_DSPS, failing at link time if it's not selected: drivers/usb/musb-new/built-in.o: In function `ti_musb_host_ofdata_to_platdata': drivers/usb/musb-new/ti-musb.c:193: undefined reference to `musb_dsps_ops' or if OF_CONTROL is not selected: arch/arm/mach-omap2/built-in.o:(.data.usb0+0x24): undefined reference to `musb_dsps_ops' Reviewed-by: Hannes Schmelzer <oe5hpm@oevsv.at> Tested-by: Hannes Schmelzer <oe5hpm@oevsv.at> Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
2019-03-22configs: am335x_evm: Add CONFIG_BLKFaiz Abbas
With DM_MMC and DM_USB enabled, enable CONFIG_BLK. Signed-off-by: Faiz Abbas <faiz_abbas@ti.com>
2019-02-01spl: Kconfig: Replace CONFIG_SPL_EXT_SUPPORT to CONFIG_SPL_FS_EXT4Tien Fong Chee
Replace CONFIG_SPL_EXT_SUPPORT to CONFIG_SPLY_FS_EXT4 so both obj-$(CONFIG_$(SPL_)FS_EXT4) and CONFIG_IS_ENABLED(FS_EXT4) can be used to control the build in both SPL and U-Boot. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-01-18configs: am335x_evm: Enable DM_SPI and DM_SPI_FLASHVignesh R
Enable DM_SPI and DM_SPI_FLASH for actively used defconfigs for am335x_evm. Signed-off-by: Vignesh R <vigneshr@ti.com>
2018-12-12defconfigs: am335x_hs_evm: Sync HS and non-HS defconfigsAndrew F. Davis
Sync new additions to non-HS defconfig with HS defconfig. Signed-off-by: Andrew F. Davis <afd@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-11-13configs: Resync with savedefconfigTom Rini
2018-04-08Migrate CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG to KconfigAlex Kiernan
Convert CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG to Kconfig Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Petr Vorel <petr.vorel@gmail.com> Reviewed-by: Petr Vorel <petr.vorel at gmail.com>
2018-04-08Migrate CONFIG_DRIVER_TI_CPSW to KconfigAlex Kiernan
This converts CONFIG_DRIVER_TI_CPSW to Kconfig Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-03-22configs: am335x_evm: Increase SPL_SYS_MALLOC_F_LEN to accomodate gpio_devicesFaiz Abbas
With gpio devices getting created in SPL, the size of the heap is no longer sufficient. Therefore, increase SPL_SYS_MALLOC_F_LEN to 0x1000. Signed-off-by: Faiz Abbas <faiz_abbas@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-02-15Convert CONFIG_BOOTCOUNT_LIMIT to KconfigLukasz Majewski
This converts the following to Kconfig: CONFIG_BOOTCOUNT_LIMIT Signed-off-by: Lukasz Majewski <lukma@denx.de> Tested-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com> Acked-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
2018-01-22Convert CONFIG_USB_MUSB_OMAP2PLUS et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_USB_MUSB_OMAP2PLUS CONFIG_USB_MUSB_AM35X CONFIG_USB_MUSB_DSPS CONFIG_USB_MUSB_PIO_ONLY Signed-off-by: Adam Ford <aford173@gmail.com>
2018-01-12am335x_hs_evm: Trim options in SPL to reduce binary sizeTom Rini
The am335x_hs_evm runs into size constraint problems at times with various toolchains as changes come in due to the config have a large number of options in SPL (to showcase what is possible) while also having rather constrained binary limits. Gain some of this room back by lowering the loglevel, disabling HW partition support and switching over to the tiny FIT image support. Cc: Andrew F. Davis <afd@ti.com> Signed-off-by: Tom Rini <trini@konsulko.com> --- I'd really appreciate a run-time test of this patch if at all possible as I'm a little worried about TINY_FIT being incompatible with all of the security options. Thanks!
2017-12-18configs: Resync with savedefconfigTom Rini
2017-11-27spl: TI: Do not default to SPL_FIT_IMAGE_TINY being enabledTom Rini
This option prevents booting on am335x_evm at least along with most likely other platforms. Fixes: 337bbb629777 ("spl: fit: add SPL_FIT_IMAGE_TINY config to reduce code-size") Signed-off-by: Tom Rini <trini@konsulko.com>
2017-10-20Convert CONFIG_NAND_OMAP_GPMC et al and CONFIG_NAND_MXC to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_NAND_MXC CONFIG_NAND_OMAP_GPMC CONFIG_NAND_OMAP_GPMC_PREFETCH CONFIG_NAND_OMAP_ELM CONFIG_SPL_NAND_AM33XX_BCH CONFIG_SPL_NAND_SIMPLE CONFIG_SYS_NAND_BUSWIDTH_16BIT Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> [trini: Finish migration of CONFIG_SPL_NAND_SIMPLE, fix some build issues, add CONFIG_NAND_MXC so we can do CONFIG_SYS_NAND_BUSWIDTH_16BIT] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-10-03usb: gadget: Make g_dnl USB settings commonMaxime Ripard
The g_dnl USB settings for the vendor ID, product ID and manufacturer are actually common settings that can and should be shared by all the gadgets. Make them common by renaming them, and convert all the users. Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Lukasz Majewski <lukma@denx.de> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-10-03usb: gadget: Convert USB_ETHER to KconfigMaxime Ripard
The USB Ethernet gadget option has not yet been moved to Kconfig, let's deal with that. Reviewed-by: Ɓukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-09-29TI: ARCH_OMAP2PLUS: Enable SPL_STACK_R and provide default valueTom Rini
On ARCH_OMAP2PLUS platforms we know what the DDR layout is going to be, and that it is safe to use SPL_STACK_R and provide a default value for it. select this and re-sync the defconfigs. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-09-01Kconfig: Migrate all of cmd/fastboot/Kconfig to defconfigsTom Rini
- Move ANDROID_IMAGE_SUPPORT to top level Kconfig under images as it's not strictly part of fastboot. - Add some defaults for the fastboot buffer location and size - Migrate all options listed in cmd/fastboot/Kconfig - Cleanup the README Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-13Convert CONFIG_OMAP3_SPI to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_OMAP3_SPI Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Minor comment tweaks] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-12Convert CONFIG_NAND to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_NAND Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Sync up a few more, add imply's] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-07-31ti: Default to ENV_IS_IN_FAT if MMC_OMAP_HSTom Rini
When we have MMC available we assume that we want to put the env as a file on FAT. Cc: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-07-31am335x_hs_evm: Disable CONFIG_SPL_ENV_SUPPORTTom Rini
The main uses of CONFIG_SPL_ENV_SUPPORT are for network support and for disabling "Falcon Mode" support at run-time. As this build enables neither, remove this feature. Cc: Andrew F. Davis <afd@ti.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-25Convert CONFIG_ENV_IS_IN_FAT to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_ENV_IS_IN_FAT Signed-off-by: Simon Glass <sjg@chromium.org>
2017-07-24configs: Migrate RBTREE, LZO, CMD_MTDPARTS, CMD_UBI and CMD_UBIFSTom Rini
The above CONFIG options are in Kconfig, and now have correct depends and inter-dependencies. Migrate these to configs/ from include/configs/. In the case of CMD_UBIFS also change it to be a default y if CMD_UBI. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-07-11configs: am335x_evm: Enable FASTBOOT based on kconfigAlexandru Gagniuc
When CONFIG_CMD_FASTBOOT or CONFIG_USB_FUNCTION_FASTBOOT are defined in am335x_evm.h, a dependency on g_dnl.c is created. This in turn creates a dependency on having USB gadget enabled. As a result we can't create configs with USB gadget disabled. Since these CONFIG_ variables are now part of kconfig, move them to the board defconfigs, and out of am335x_evm.h. This both preserves current defaults, and allows creating configs with USB gadget off. Signed-off-by: Alexandru Gagniuc <alex.g@adaptrum.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-05-08configs: am335x: Enable TI_COMMON_CMD_OPTIONSLokesh Vutla
Enable TI_COMMON_CMD_OPTIONS on all am335x platforms. Also sync with savedefconfig. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> [trini: Re-sync, add in boneblack*, evm_hs_{norboot,spiboot,usbspl} configs] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-27ARM: omap2+: rename config to ARCH_OMAP2PLUS and consolidate KconfigMasahiro Yamada
In Linux, CONFIG_ARCH_OMAP2PLUS is used for OMAP2 or later SoCs. Rename CONFIG_ARCH_OMAP2 to CONFIG_ARCH_OMAP2PLUS to follow this naming. Move the OMAP2+ board/SoC choice down to mach-omap2/Kconfig to slim down the arch/arm/Kconfig level. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-04-27Kconfig: Enable FIT support by default for TI platformsAndrew F. Davis
Almost all TI defconfigs enable this already, add this as a default and remove the explicit assignment. Signed-off-by: Andrew F. Davis <afd@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-04-08defconfigs: am335x_hs_evm: Sync HS and non-HS defconfigsAndrew F. Davis
Sync new additions to non-HS defconfig with HS defconfig. Also add SPL NAND support, this was disabled before due to size constraints, enable this now at the expense of the less used GPT partition support. Signed-off-by: Andrew F. Davis <afd@ti.com>
2017-01-28defconfig: Add a config for AM335x High Security EVMAndrew F. Davis
Add a new defconfig file for the AM335x High Security EVM. This config is specific for the case of memory device booting. Memory device booting is handled separatly from peripheral booting on HS devices as the load address changes. This defconfig is the same as for the non-secure part, except for: CONFIG_TI_SECURE_DEVICE option set to 'y' CONFIG_ISW_ENTRY_ADDR updated for secure images. CONFIG_FIT_IMAGE_POST_PROCESS option set to 'y' CONFIG_SPL_FIT_IMAGE_POST_PROCESS option set to 'y' CONFIG_USE_TINY_PRINTF option set to 'y' to reduce SPL size CONFIG_SPL_SYS_MALLOC_SIMPLE set to 'y' to reduce SPL size Signed-off-by: Andrew F. Davis <afd@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
