CONFIG_TIMESTAMP
CONFIG_SYS_NAND_U_BOOT_LOCATIONS
CONFIG_SYS_NAND_U_BOOT_OFFS
CONFIG_SYS_NAND_ONFI_DETECTION
CONFIG_SPL_NAND_LOAD
CONFIG_SYS_NAND_BLOCK_SIZE
CONFIG_SYS_NAND_PAGE_SIZE
CONFIG_SYS_NAND_OOBSIZE
Prepare v2021.10-rc4
# gpg: Signature made Tue 14 Sep 2021 06:58:32 PM EDT
# gpg: using RSA key 1A3C7F70E08FAB1707809BBF147C39FF9634B72C
# gpg: Good signature from "Thomas Rini <trini@konsulko.com>" [ultimate]
# Conflicts:
# board/Arcturus/ucp1020/spl.c
# cmd/mvebu/Kconfig
# common/Kconfig.boot
# common/image-fit.c
# configs/UCP1020_defconfig
# configs/sifive_unmatched_defconfig
# drivers/pci/Kconfig
# include/configs/UCP1020.h
# include/configs/sifive-unmatched.h
# lib/Makefile
# scripts/config_whitelist.txt
Both am335x_boneblack_vboot and am335x_evm_spiboot require
SPL_OF_CONTROL to function but are currently missing this option. Add
it.
Rename these options so that CONFIG_IS_ENABLED can be used with them.
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
[trini: Fixup some incorrect renames]
- Rename usages of CONFIG_SYS_DEF_EEPROM_ADDR to CONFIG_SYS_I2C_EEPROM_ADDR
based on current usage.
- Convert CONFIG_SYS_I2C_EEPROM_ADDR, CONFIG_SYS_I2C_EEPROM_ADDR_LEN,
CONFIG_SYS_I2C_EEPROM_BUS, CONFIG_CONFIG_SYS_EEPROM_SIZE
CONFIG_SYS_EEPROM_PAGE_WRITE_BITS and CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS
to Kconfig. We move these symbols around a bit and add appropriate
dependencies to them. In some cases, we now add a correct default value
as well.
Remove the environment support for various legacy boot methods. With
this, we will now default to booting any distribution that follows the
generic distro boot framework and no longer attempt to boot various
legacy (to this SoC) scripts/etc.
Link: https://lore.kernel.org/r/20210610230147.22475-1-trini@konsulko.com
am335x internal SRAM is too small to support the addition of
SPI bootmode to the default defconfig. Add a separate spiboot_defconfig
Signed-off-by: Faiz Abbas <faiz_abbas@ti.com>
These defconfigs don't seem be actively used any more, and have not been
moved to adapt DM or DT. Therefore delete them.
Signed-off-by: Vignesh R <vigneshr@ti.com>
CONFIG_MII
CONFIG_DRIVER_TI_EMAC
Acked-by: Jagan Teki <jagan@amarulasolutions.com>
CONFIG_MTD_PARTITIONS
CONFIG_MTD_DEVICE
Separate CMD_FASTBOOT from FASTBOOT and move code and configuration to
drivers/fastboot.
Switch dependencies on FASTBOOT to USB_FUNCTION_FASTBOOT as anyone who wants
FASTBOOT before this series wants USB_FUNCTION_FASTBOOT. Split
USB_FUNCTION_FASTBOOT from FASTBOOT so they retain their existing
behaviour.
Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
CONFIG_SPI
This partly involves updating code that assumes that CONFIG_SPI implies
things that are specific to the MPC8xx SPI driver. For now, just update
the CONFIG tests. This also involves reworking the default for
CONFIG_SYS_DEF_EEPROM_ADDR so that we don't set it when we cannot make a
reasonable default, as it does not cause any compile failures.
Add Kconfig entry for CONFIG_SPL_SPI_LOAD symbol and move all
configurations using it to Kconfig.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Convert CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG to Kconfig
Reviewed-by: Lukasz Majewski <lukma@denx.de>
Reviewed-by: Petr Vorel <petr.vorel@gmail.com>
Reviewed-by: Petr Vorel <petr.vorel at gmail.com>
This converts CONFIG_DRIVER_TI_CPSW to Kconfig
CONFIG_BOOTCOUNT_LIMIT
Signed-off-by: Lukasz Majewski <lukma@denx.de>
Tested-by: Alex Kiernan <alex.kiernan@gmail.com>
Reviewed-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
Acked-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
CONFIG_USB_MUSB_OMAP2PLUS
CONFIG_USB_MUSB_AM35X
CONFIG_USB_MUSB_DSPS
CONFIG_USB_MUSB_PIO_ONLY
We first introduce CONFIG_USE_BOOTCOMMAND, similar to
CONFIG_USE_BOOTARGS. We then migrate CONFIG_BOOTCOMMAND for most
CONFIG_DISTRO_DEFAULT users. In some cases platforms have a complex
scheme around this usage, and these have been defered for the moment so
that platform maintainers can work on a migration plan.
We move all instances of CONFIG_MTDIDS_DEFAULT and
CONFIG_MTDPARTS_DEFAULT from the header files to the defconfig files.
There's a few cases here where we need to expand upon what was in the
header file.
Tested-by: Adam Ford <aford173@gmail.com> #omap3_logic
Having this as a 'default y' is rather annoying because it doesn't
actually compile unless other options are defined in the board header:
../cmd/bootm.c: In function 'do_imls_nor':
../cmd/bootm.c:330:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
Make it 'default n' so people who develop new boards that start from a
blank defconfig have one less compilation failure to debug.
Fastboot need a bunch of options to be operating properly, such as the
g_dnl gadget, the fastboot command, and some options that make sense. Since
fastboot is now part of Kconfig, make sure we have them right.
That will also reduce the boilerplate in the defconfigs.
Reviewed-by: Łukasz Majewski <lukma@denx.de>
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
The g_dnl USB settings for the vendor ID, product ID and manufacturer are
actually common settings that can and should be shared by all the gadgets.
Make them common by renaming them, and convert all the users.
The USB Ethernet gadget option has not yet been moved to Kconfig, let's
deal with that.
On ARCH_OMAP2PLUS platforms we know what the DDR layout is going to be,
and that it is safe to use SPL_STACK_R and provide a default value for
it. select this and re-sync the defconfigs.
- Move ANDROID_IMAGE_SUPPORT to top level Kconfig under images as it's
not strictly part of fastboot.
- Add some defaults for the fastboot buffer location and size
- Migrate all options listed in cmd/fastboot/Kconfig
- Cleanup the README
CONFIG_OMAP3_SPI
[trini: Minor comment tweaks]
Signed-off-by: Alexandru Gagniuc <alex.g@adaptrum.com>
When we have MMC available we assume that we want to put the env as a
file on FAT.
Cc: Lokesh Vutla <lokeshvutla@ti.com>
CONFIG_ENV_IS_IN_SPI_FLASH
The above CONFIG options are in Kconfig, and now have correct depends and
inter-dependencies. Migrate these to configs/ from include/configs/. In the
case of CMD_UBIFS also change it to be a default y if CMD_UBI.
When CONFIG_CMD_FASTBOOT or CONFIG_USB_FUNCTION_FASTBOOT are defined
in am335x_evm.h, a dependency on g_dnl.c is created. This in turn
creates a dependency on having USB gadget enabled.
As a result we can't create configs with USB gadget disabled.
Since these CONFIG_ variables are now part of kconfig, move them to
the board defconfigs, and out of am335x_evm.h. This both preserves
current defaults, and allows creating configs with USB gadget off.
TI am33xx devices such as the BeagleBone devices have numerous cape options such
as screens some of which need overlays from the beginning so it makes sense to
enable evice tree overlays.
Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
Enable TI_COMMON_CMD_OPTIONS on all am335x platforms.
Also sync with savedefconfig.
[trini: Re-sync, add in boneblack*, evm_hs_{norboot,spiboot,usbspl} configs]
In Linux, CONFIG_ARCH_OMAP2PLUS is used for OMAP2 or later SoCs.
Rename CONFIG_ARCH_OMAP2 to CONFIG_ARCH_OMAP2PLUS to follow this
naming.
Move the OMAP2+ board/SoC choice down to mach-omap2/Kconfig to slim
down the arch/arm/Kconfig level.
