path: root/configs/am335x_evm_nor_defconfig
2015-03-04ti: armv7: Move SPL SDRAM init to the right place, drop unused CONFIG_SPL_STACKSimon Glass
Currently in some cases SDRAM init requires global_data to be available and soon this will not be available prior to board_init_f(). Adjust the code paths in these cases to be correct. In some cases we had the SPL stack be in DDR as we might have large stacks (due to Falcon Mode + Environment). In these cases switch to CONFIG_SPL_STACK_R. In other cases we had simply been setting CONFIG_SPL_STACK into SRAM. In these cases we no longer need to (CONFIG_SYS_INIT_SP_ADDR is used and is also in SRAM) so drop those lines. Signed-off-by: Simon Glass <sjg@chromium.org> Tested on Beagleboard, Beagleboard xM Tested-by: Matt Porter <mporter@konsulko.com> Tested on Beaglebone Black, AM43xx GP EVM, OMAP5 uEVM, OMAP4 Pandaboard Tested-by: Tom Rini <trini@konsulko.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-11-05am335x_evm: Add NOR to KconfigTom Rini
Make enabling support for NOR (and describe where it's seen) be done via Kconfig. Signed-off-by: Tom Rini <trini@ti.com>
2014-08-25am335x_evm: Convert CONFIG_CONS_INDEX into a menu choiceTom Rini
- Drop CONFIG_SERIAL[1-6] and use CONFIG_CONS_INDEX tests instead - Add choice and help text to board/ti/am335x/Kconfig - Correct comment about IDK in board/ti/am335x/mux.c - Remove am335x_evm_uart* defconfig files as they're just variations on a config option now. Signed-off-by: Tom Rini <trini@ti.com>
