There are already Kconfig options for SPI flash drivers, but we
have not moved them from config.h to defconfig files. This commit
does this in a batch.
Add CMD_GPIO to Kconfig and run tools/moveconfig.py .
them from include/configs.
Some archs/boards specify their own default by pre-defining the config
which causes the Kconfig system to mix up the order of the configs in
the defconfigs... This will cause merge pain if allowed to proliferate.
Remove the configs that behave this way from the archs.
A few configs still remain, but that is because they only exist as
defaults and do not have a proper Kconfig entry. Those appear to be:
SPIFLASH
DISPLAY_BOARDINFO
[trini: rastaban, am43xx_evm_usbhost_boot, am43xx_evm_ethboot updates,
drop DM_USB from MSI_Primo81 as USB_MUSB_SUNXI isn't converted yet to DM]
This also selects CONFIG_NET for any CONFIG_CMD_NET board.
Remove the imx default for CONFIG_NET.
This moves the config that was defined by 60296a8 (commands: add more
command entries in Kconfig).
In order to reduce merge conflicts and to maintain the simplest possible
defconfig files, we should be using the savedefconfig feature of Kconfig
every time a new feature is added. This keeps the defconfig settings to
a minimum (only those things not default) and keeps them in the same
order as the Kconfig options.
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
Since commit e02ee2548afe (kconfig: switch to single .config
configuration), the prefixes in defconfig files such as "+S:",
"+ST:", etc., are meaningless.
This commit was generated by the following command:
find configs -name '*_defconfig' | xargs sed -i 's/^+*S*T*://'
Currently in some cases SDRAM init requires global_data to be available
and soon this will not be available prior to board_init_f(). Adjust the
code paths in these cases to be correct. In some cases we had the SPL
stack be in DDR as we might have large stacks (due to Falcon Mode +
Environment). In these cases switch to CONFIG_SPL_STACK_R. In other
cases we had simply been setting CONFIG_SPL_STACK into SRAM. In these
cases we no longer need to (CONFIG_SYS_INIT_SP_ADDR is used and is also
in SRAM) so drop those lines.
Tested on Beagleboard, Beagleboard xM
Tested-by: Matt Porter <mporter@konsulko.com>
Tested on Beaglebone Black, AM43xx GP EVM, OMAP5 uEVM, OMAP4 Pandaboard
Tested-by: Tom Rini <trini@konsulko.com>
Make enabling support for NOR (and describe where it's seen) be done via
Kconfig.
- Drop CONFIG_SERIAL[1-6] and use CONFIG_CONS_INDEX tests instead
- Add choice and help text to board/ti/am335x/Kconfig
- Correct comment about IDK in board/ti/am335x/mux.c
- Remove am335x_evm_uart* defconfig files as they're just variations
on a config option now.
This commit adds:
- arch/${ARCH}/Kconfig
provide a menu to select target boards
- board/${VENDOR}/${BOARD}/Kconfig or board/${BOARD}/Kconfig
set CONFIG macros to the appropriate values for each board
- configs/${TARGET_BOARD}_defconfig
default setting of each board
(This commit was automatically generated by a conversion script
based on boards.cfg)
In Linux Kernel, defconfig files are located under
arch/${ARCH}/configs/ directory.
It works in Linux Kernel since ARCH is always given from the
command line for cross compile.
But in U-Boot, ARCH is not given from the command line.
Which means we cannot know ARCH until the board configuration is done.
That is why all the "*_defconfig" files should be gathered into a
single directory ./configs/.
