path: root/configs/am335x_evm_defconfig
2018-02-15Convert CONFIG_BOOTCOUNT_LIMIT to KconfigLukasz Majewski
This converts the following to Kconfig: CONFIG_BOOTCOUNT_LIMIT Signed-off-by: Lukasz Majewski <lukma@denx.de> Tested-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com> Acked-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
2018-02-14configs: am335x_evm: Add DYNAMIC_CRC_TABLEFaiz Abbas
Add CONFIG_DYNAMIC_CRC_TABLE to am335x_evm_defconfig to reduce the size of the image. Signed-off-by: Faiz Abbas <faiz_abbas@ti.com>
2018-02-14configs: am335x_evm: Disable ISO and EFI partitions in SPLFaiz Abbas
ISO and EFI partition configs in SPL are selected by default. However, they are not being used. Therefore, remove ISO and EFI partition support in SPL. Signed-off-by: Faiz Abbas <faiz_abbas@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-01-22Convert CONFIG_USB_MUSB_OMAP2PLUS et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_USB_MUSB_OMAP2PLUS CONFIG_USB_MUSB_AM35X CONFIG_USB_MUSB_DSPS CONFIG_USB_MUSB_PIO_ONLY Signed-off-by: Adam Ford <aford173@gmail.com>
2017-12-18configs: Resync with savedefconfigTom Rini
2017-11-17Kconfig: Introduce USE_BOOTCOMMAND and migrate BOOTCOMMANDTom Rini
We first introduce CONFIG_USE_BOOTCOMMAND, similar to CONFIG_USE_BOOTARGS. We then migrate CONFIG_BOOTCOMMAND for most CONFIG_DISTRO_DEFAULT users. In some cases platforms have a complex scheme around this usage, and these have been defered for the moment so that platform maintainers can work on a migration plan. Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2017-10-20Convert CONFIG_NAND_OMAP_GPMC et al and CONFIG_NAND_MXC to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_NAND_MXC CONFIG_NAND_OMAP_GPMC CONFIG_NAND_OMAP_GPMC_PREFETCH CONFIG_NAND_OMAP_ELM CONFIG_SPL_NAND_AM33XX_BCH CONFIG_SPL_NAND_SIMPLE CONFIG_SYS_NAND_BUSWIDTH_16BIT Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> [trini: Finish migration of CONFIG_SPL_NAND_SIMPLE, fix some build issues, add CONFIG_NAND_MXC so we can do CONFIG_SYS_NAND_BUSWIDTH_16BIT] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-10-03cmd: fastboot: Rework fastboot dependencyMaxime Ripard
Fastboot need a bunch of options to be operating properly, such as the g_dnl gadget, the fastboot command, and some options that make sense. Since fastboot is now part of Kconfig, make sure we have them right. That will also reduce the boilerplate in the defconfigs. Reviewed-by: Łukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-10-03usb: gadget: Make g_dnl USB settings commonMaxime Ripard
The g_dnl USB settings for the vendor ID, product ID and manufacturer are actually common settings that can and should be shared by all the gadgets. Make them common by renaming them, and convert all the users. Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Lukasz Majewski <lukma@denx.de> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-10-03usb: gadget: Convert USB_ETHER to KconfigMaxime Ripard
The USB Ethernet gadget option has not yet been moved to Kconfig, let's deal with that. Reviewed-by: Łukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-09-29TI: ARCH_OMAP2PLUS: Enable SPL_STACK_R and provide default valueTom Rini
On ARCH_OMAP2PLUS platforms we know what the DDR layout is going to be, and that it is safe to use SPL_STACK_R and provide a default value for it. select this and re-sync the defconfigs. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-09-01Kconfig: Migrate all of cmd/fastboot/Kconfig to defconfigsTom Rini
- Move ANDROID_IMAGE_SUPPORT to top level Kconfig under images as it's not strictly part of fastboot. - Add some defaults for the fastboot buffer location and size - Migrate all options listed in cmd/fastboot/Kconfig - Cleanup the README Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-13Convert CONFIG_OMAP3_SPI to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_OMAP3_SPI Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Minor comment tweaks] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-12Convert CONFIG_NAND to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_NAND Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Sync up a few more, add imply's] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-11Convert CONFIG_CMD_SPL_NAND_OFS to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_SPL_NAND_OFS Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-08-11Convert CONFIG_CMD_SPL to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_SPL Note that trats does not actually use SPL, so this option can no-longer be set. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-07-31ti: Default to ENV_IS_IN_FAT if MMC_OMAP_HSTom Rini
When we have MMC available we assume that we want to put the env as a file on FAT. Cc: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-07-25Convert CONFIG_ENV_IS_IN_FAT to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_ENV_IS_IN_FAT Signed-off-by: Simon Glass <sjg@chromium.org>
2017-07-24configs: Migrate RBTREE, LZO, CMD_MTDPARTS, CMD_UBI and CMD_UBIFSTom Rini
The above CONFIG options are in Kconfig, and now have correct depends and inter-dependencies. Migrate these to configs/ from include/configs/. In the case of CMD_UBIFS also change it to be a default y if CMD_UBI. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-07-11configs: am335x_evm: Enable FASTBOOT based on kconfigAlexandru Gagniuc
When CONFIG_CMD_FASTBOOT or CONFIG_USB_FUNCTION_FASTBOOT are defined in am335x_evm.h, a dependency on g_dnl.c is created. This in turn creates a dependency on having USB gadget enabled. As a result we can't create configs with USB gadget disabled. Since these CONFIG_ variables are now part of kconfig, move them to the board defconfigs, and out of am335x_evm.h. This both preserves current defaults, and allows creating configs with USB gadget off. Signed-off-by: Alexandru Gagniuc <alex.g@adaptrum.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-07-10configs: Resync defconfigsTom Rini
2017-07-06am335x: beagle/evm: add device tree overlay supportPeter Robinson
TI am33xx devices such as the BeagleBone devices have numerous cape options such as screens some of which need overlays from the beginning so it makes sense to enable evice tree overlays. Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2017-05-17Kconfig: fix SPL_FIT dependencyAndre Przywara
SPL_FIT obviously requires libfdt in SPL, so let Kconfig express that by selecting SPL_OF_LIBFDT. Also make the actual options that users want (SPL signature and SPL FIT loading) visible in the menu and let them select the SPL_FIT as a requirement. Also remove the now redundant SPL_OF_LIBFDT from those Kconfigs that had it in for the SPL FIT loading feature. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Simon Glass <sjg@chromium.org> [Remove change from configs/evb-rk3399_defconfig] Signed-off-by: Jagan Teki <jagan@openedev.com>
2017-05-08configs: am335x: Enable TI_COMMON_CMD_OPTIONSLokesh Vutla
Enable TI_COMMON_CMD_OPTIONS on all am335x platforms. Also sync with savedefconfig. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> [trini: Re-sync, add in boneblack*, evm_hs_{norboot,spiboot,usbspl} configs] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-27ARM: omap2+: rename config to ARCH_OMAP2PLUS and consolidate KconfigMasahiro Yamada
In Linux, CONFIG_ARCH_OMAP2PLUS is used for OMAP2 or later SoCs. Rename CONFIG_ARCH_OMAP2 to CONFIG_ARCH_OMAP2PLUS to follow this naming. Move the OMAP2+ board/SoC choice down to mach-omap2/Kconfig to slim down the arch/arm/Kconfig level. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-04-27Kconfig: Enable FIT support by default for TI platformsAndrew F. Davis
Almost all TI defconfigs enable this already, add this as a default and remove the explicit assignment. Signed-off-by: Andrew F. Davis <afd@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-02-08net: phy: MSCC Add Support for VSC8530-VSC8531-VSC8540-VSC8541John Haechten
Signed-off-by: John Haechten <john.haechten@microsemi.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2017-01-25Convert CONFIG_ARCH_MISC_INIT to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_ARCH_MISC_INIT Signed-off-by: Simon Glass <sjg@chromium.org>
2017-01-11mmc: move more driver config options to KconfigMasahiro Yamada
Move (and rename) the following CONFIG options to Kconfig: CONFIG_DAVINCI_MMC (renamed to CONFIG_MMC_DAVINCI) CONFIG_OMAP_HSMMC (renamed to CONFIG_MMC_OMAP_HS) CONFIG_MXC_MMC (renamed to CONFIG_MMC_MXC) CONFIG_MXS_MMC (renamed to CONFIG_MMC_MXS) CONFIG_TEGRA_MMC (renamed to CONFIG_MMC_SDHCI_TEGRA) CONFIG_SUNXI_MMC (renamed to CONFIG_MMC_SUNXI) They are the same option names as used in Linux. This commit was created as follows: [1] Rename the options with the following command: find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \ -type f -print | xargs sed -i -e ' s/CONFIG_DAVINCI_MMC/CONFIG_MMC_DAVINCI/g s/CONFIG_OMAP_HSMMC/CONFIG_MMC_OMAP_HS/g s/CONFIG_MXC_MMC/CONFIG_MMC_MXC/g s/CONFIG_MXS_MMC/CONFIG_MMC_MXS/g s/CONFIG_TEGRA_MMC/CONFIG_MMC_SDHCI_TEGRA/g s/CONFIG_SUNXI_MMC/CONFIG_MMC_SUNXI/g ' [2] Commit the changes [3] Create entries in driver/mmc/Kconfig. (copied from Linux) [4] Move the options with the following command tools/moveconfig.py -y -r HEAD \ MMC_DAVINCI MMC_OMAP_HS MMC_MXC MMC_MXS MMC_SDHCI_TEGRA MMC_SUNXI [5] Sort and align drivers/mmc/Makefile for readability Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Marek Vasut <marex@denx.de>
2017-01-09defconfig: am335x_evm: enable usb driver modelMugunthan V N
enable usb driver model for am335x bbb as musb supports driver model Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-12-03Enable DISTRO_DEFAULT on platforms that missed it beforeTom Rini
A number of platforms had been using the distro default feature before it was moved to Kconfig but did not enable the new Kconfig option when it was enabled. This caused a regression in terms of features and this introduces breakage when more things move to Kconfig. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-14spl: move SPL_OS_BOOT to KconfigHeiko Schocher
Move SPL_OS_BOOT to Kconfig and cleanup existing uses. Signed-off-by: Heiko Schocher <hs@denx.de>
2016-10-11dm: mmc: Enable DM_MMC_OPS by default with DM_MMCSimon Glass
These two options go together and it is best to do the conversion in one step. So enable DM_MMC_OPS by default if DM_MMC is enabled. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-11dm: blk: Enable CONFIG_BLK if DM_MMC is enabledSimon Glass
To speed up conversion to CONFIG_BLK, enable it by default when DM_MMC is enabled. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-02Kconfig: Separate AM33XX SOC config from target board configAndrew F. Davis
The config option AM33XX is used in several boards and should be defined as a stand-alone option for this SOC. We break this out from target boards that use this SoC and common headers then enable AM33XX on in all the boards that used these targets to eliminate any functional change with this patch. This is similar to what has already been done in 9de852642cae ("arm: Kconfig: Add support for AM43xx SoC specific Kconfig") and is done for the same reasons. Signed-off-by: Andrew F. Davis <afd@ti.com> Acked-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-09-27dfu: Migrate to KconfigTom Rini
Introduce a hidden USB_FUNCTION_DFU Kconfig option and select it for CMD_DFU (as we must have the DFU command enabled to do anything DFU). Make all of the entries in drivers/dfu/Kconfig depend on CMD_DFU and add options for all of the back end choices that DFU can make use of. Cc: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com>
2016-09-16Convert CONFIG_SPL_POWER_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_MUSB_NEW_SUPPORT to KconfigSimon Glass
