path: root/configs/am335x_evm_defconfig
2016-04-25configs: Re-sync CONFIG_USB_MUSB_HOSTTom Rini
Now that CONFIG_USB_MUSB_HOST is part of Kconfig, migrate that over to the defconfig files. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-04-20usb: gadget Move: CONFIG_G_DNL_* to KconfigSam Protsenko
And also reformat defconfigs using "make savedefconfig" rule. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DOWNLOAD to KconfigSam Protsenko
While at it, remove obsolete CONFIG_USBDOWNLOAD_GADGET option from some config headers. This is also probably fixes am335x_baltos board. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DUALSPEED to KconfigSam Protsenko
Move CONFIG_USB_GADGET_DUALSPEED option to Kconfig and make all UDC controllers select USB_GADGET_DUALSPEED: - add next options to Kconfig selecting USB_GADGET_DUALSPEED: - USB_GADGET_ATMEL_USBA - USB_GADGET_DWC2_OTG - USB_DWC3 - CI_UDC - make USB_MUSB_GADGET select USB_GADGET_DUALSPEED While at it, make some related fixes: - remove DUALSPEED from configs that don't enable gadget support: - kwb.h - tseries.h - add missing USB_GADGET option to next configs: - novena_defconfig - pcm051_rev*_defconfig - xfi3_defconfig Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-03-25usb: gadget: Move CONFIG_USB_GADGET to KconfigSam Protsenko
The description was borrowed from kernel. "tristate" type was changed to "bool" (I believe we don't support modules for u-boot yet, right?). CONFIG_USB_GADGET requires CONFIG_USB to be defined too, so add it along as well. Definitions were added to defconfig files in a way that "make savedefconfig" generates exactly the same file as used defconfig. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> [trini: Add zynq_zc702 conversion] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-01-20am335x: BeagleBones enable CONFIG_AUTOBOOT_KEYEDrobertcnelson@gmail.com
On startup, the BeagleBone family of boards can occationally halt at the U-Boot prompt. Due to U-Boot receiving random data on the usart. Migrate BeagleBone based boards to use CONFIG_AUTOBOOT_KEYED, user will now have to enter the <SPACE> key to get to U-Boot prompt Signed-off-by: Robert Nelson <robertcnelson@gmail.com> CC: Craig McQueen <craig.mcqueen@innerrange.com> CC: Tom Rini <trini@konsulko.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-03-04ti: armv7: Move SPL SDRAM init to the right place, drop unused CONFIG_SPL_STACKSimon Glass
Currently in some cases SDRAM init requires global_data to be available and soon this will not be available prior to board_init_f(). Adjust the code paths in these cases to be correct. In some cases we had the SPL stack be in DDR as we might have large stacks (due to Falcon Mode + Environment). In these cases switch to CONFIG_SPL_STACK_R. In other cases we had simply been setting CONFIG_SPL_STACK into SRAM. In these cases we no longer need to (CONFIG_SYS_INIT_SP_ADDR is used and is also in SRAM) so drop those lines. Signed-off-by: Simon Glass <sjg@chromium.org> Tested on Beagleboard, Beagleboard xM Tested-by: Matt Porter <mporter@konsulko.com> Tested on Beaglebone Black, AM43xx GP EVM, OMAP5 uEVM, OMAP4 Pandaboard Tested-by: Tom Rini <trini@konsulko.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-08-25am335x_evm: Convert CONFIG_CONS_INDEX into a menu choiceTom Rini
- Drop CONFIG_SERIAL[1-6] and use CONFIG_CONS_INDEX tests instead - Add choice and help text to board/ti/am335x/Kconfig - Correct comment about IDK in board/ti/am335x/mux.c - Remove am335x_evm_uart* defconfig files as they're just variations on a config option now. Signed-off-by: Tom Rini <trini@ti.com>
