The am335x_evm_defconfig supports all am335x_boneblack variants. Remove
the redundant am335x_boneblack_defconfig.
Signed-off-by: Faiz Abbas <faiz_abbas@ti.com>
CONFIG_MII
CONFIG_DRIVER_TI_EMAC
Acked-by: Jagan Teki <jagan@amarulasolutions.com>
Convert USB fastboot code to use shared fastboot protocol.
Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
Separate CMD_FASTBOOT from FASTBOOT and move code and configuration to
drivers/fastboot.
Switch dependencies on FASTBOOT to USB_FUNCTION_FASTBOOT as anyone who wants
FASTBOOT before this series wants USB_FUNCTION_FASTBOOT. Split
USB_FUNCTION_FASTBOOT from FASTBOOT so they retain their existing
behaviour.
CONFIG_SPI
This partly involves updating code that assumes that CONFIG_SPI implies
things that are specific to the MPC8xx SPI driver. For now, just update
the CONFIG tests. This also involves reworking the default for
CONFIG_SYS_DEF_EEPROM_ADDR so that we don't set it when we cannot make a
reasonable default, as it does not cause any compile failures.
Convert CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG to Kconfig
Reviewed-by: Lukasz Majewski <lukma@denx.de>
Reviewed-by: Petr Vorel <petr.vorel@gmail.com>
Reviewed-by: Petr Vorel <petr.vorel at gmail.com>
This converts CONFIG_DRIVER_TI_CPSW to Kconfig
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
Acked-by: Lukasz Majewski <lukma@denx.de>
CONFIG_BOOTCOUNT_LIMIT
Signed-off-by: Lukasz Majewski <lukma@denx.de>
Tested-by: Alex Kiernan <alex.kiernan@gmail.com>
Reviewed-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
Acked-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
CONFIG_USB_MUSB_OMAP2PLUS
CONFIG_USB_MUSB_AM35X
CONFIG_USB_MUSB_DSPS
CONFIG_USB_MUSB_PIO_ONLY
Commit b6251db8c3f0 ("Kconfig: Introduce USE_BOOTCOMMAND and migrate
BOOTCOMMAND") removed CONFIG_BOOTCOMMAND option from
include/configs/am335x_evm.h file. But that option wasn't added to
defconfig files for BeagleBone Black board.
Because of this we can't boot Linux from SD card using just
"run bootcmd", getting next error:
** File not found /boot/undefined **
That's because "fdtfile" variable has "undefined" value by default, and
"bootcmd" doesn't call "run findfdt" command, which assigns "fdtfile" to
correct device tree file for current board name (obtained from EEPROM).
So we are forced to either call "run findfdt" command manually, or
assign manually "fdtfile=am335x-boneblack.dtb" (e.g. in uEnv.txt file).
Bring back CONFIG_BOOTCOMMAND to BBB defconfigs so that we can boot
Linux rootfs from SD card automatically without any addition actions.
Having this as a 'default y' is rather annoying because it doesn't
actually compile unless other options are defined in the board header:
../cmd/bootm.c: In function 'do_imls_nor':
../cmd/bootm.c:330:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
Make it 'default n' so people who develop new boards that start from a
blank defconfig have one less compilation failure to debug.
Fastboot need a bunch of options to be operating properly, such as the
g_dnl gadget, the fastboot command, and some options that make sense. Since
fastboot is now part of Kconfig, make sure we have them right.
That will also reduce the boilerplate in the defconfigs.
Reviewed-by: Łukasz Majewski <lukma@denx.de>
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
The g_dnl USB settings for the vendor ID, product ID and manufacturer are
actually common settings that can and should be shared by all the gadgets.
Make them common by renaming them, and convert all the users.
The USB Ethernet gadget option has not yet been moved to Kconfig, let's
deal with that.
While the USB Ethernet device address is already defined in Kconfig, the
host address isn't. Convert it.
On ARCH_OMAP2PLUS platforms we know what the DDR layout is going to be,
and that it is safe to use SPL_STACK_R and provide a default value for
it. select this and re-sync the defconfigs.
- Move ANDROID_IMAGE_SUPPORT to top level Kconfig under images as it's
not strictly part of fastboot.
- Add some defaults for the fastboot buffer location and size
- Migrate all options listed in cmd/fastboot/Kconfig
- Cleanup the README
CONFIG_OMAP3_SPI
[trini: Minor comment tweaks]
CONFIG_CMD_SPL
Note that trats does not actually use SPL, so this option can no-longer be
set.
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Signed-off-by: Alexandru Gagniuc <alex.g@adaptrum.com>
When we have MMC available we assume that we want to put the env as a
file on FAT.
Cc: Lokesh Vutla <lokeshvutla@ti.com>
CONFIG_ENV_IS_IN_MMC
CONFIG_ENV_IS_IN_NAND
CONFIG_ENV_IS_IN_UBI
CONFIG_ENV_IS_NOWHERE
In fact this already exists for sunxi as a 'choice' config. However not
all the choices are available in Kconfig yet so we cannot use that. It
would lead to more than one option being set.
In addition, one purpose of this series is to allow the environment to be
stored in more than one place. So the existing choice is converted to a
normal config allowing each option to be set independently.
There are not many opportunities for Kconfig updates to reduce the size of
this patch. This was tested with
./tools/moveconfig.py -i CONFIG_ENV_IS_IN_MMC
And then manual updates. This is because for CHAIN_OF_TRUST boards they
can only have ENV_IS_NOWHERE set, so we enforce that via Kconfig logic
now.
The above CONFIG options are in Kconfig, and now have correct depends and
inter-dependencies. Migrate these to configs/ from include/configs/. In the
case of CMD_UBIFS also change it to be a default y if CMD_UBI.
When CONFIG_CMD_FASTBOOT or CONFIG_USB_FUNCTION_FASTBOOT are defined
in am335x_evm.h, a dependency on g_dnl.c is created. This in turn
creates a dependency on having USB gadget enabled.
As a result we can't create configs with USB gadget disabled.
Since these CONFIG_ variables are now part of kconfig, move them to
the board defconfigs, and out of am335x_evm.h. This both preserves
current defaults, and allows creating configs with USB gadget off.
TI am33xx devices such as the BeagleBone devices have numerous cape options such
as screens some of which need overlays from the beginning so it makes sense to
enable evice tree overlays.
Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
Enable TI_COMMON_CMD_OPTIONS on all am335x platforms.
Also sync with savedefconfig.
[trini: Re-sync, add in boneblack*, evm_hs_{norboot,spiboot,usbspl} configs]
In Linux, CONFIG_ARCH_OMAP2PLUS is used for OMAP2 or later SoCs.
Rename CONFIG_ARCH_OMAP2 to CONFIG_ARCH_OMAP2PLUS to follow this
naming.
Move the OMAP2+ board/SoC choice down to mach-omap2/Kconfig to slim
down the arch/arm/Kconfig level.
Almost all TI defconfigs enable this already, add this as a default
and remove the explicit assignment.
Signed-off-by: Andrew F. Davis <afd@ti.com>
We convert CONFIG_PARTITION_UUIDS to Kconfig first. But in order to cleanly
update all of the config files we must also update CMD_PART and CMD_GPT to also
be in Kconfig in order to avoid complex logic elsewhere to update all of the
config files.
Signed-off-by: Patrick Delaunay <patrick.delaunay73@gmail.com>
CONFIG_ARCH_MISC_INIT
This option should not really be user selectable. Note that on PowerPC
we currently only need BOARD_LATE_INIT when CHAIN_OF_TRUST is enabled so be
conditional on that.
Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com> (for UniPhier)
Signed-off-by: Jagan Teki <jagan@openedev.com>
Move (and rename) the following CONFIG options to Kconfig:
CONFIG_DAVINCI_MMC (renamed to CONFIG_MMC_DAVINCI)
CONFIG_OMAP_HSMMC (renamed to CONFIG_MMC_OMAP_HS)
CONFIG_MXC_MMC (renamed to CONFIG_MMC_MXC)
CONFIG_MXS_MMC (renamed to CONFIG_MMC_MXS)
CONFIG_TEGRA_MMC (renamed to CONFIG_MMC_SDHCI_TEGRA)
CONFIG_SUNXI_MMC (renamed to CONFIG_MMC_SUNXI)
They are the same option names as used in Linux.
This commit was created as follows:
[1] Rename the options with the following command:
find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \
-type f -print | xargs sed -i -e '
s/CONFIG_DAVINCI_MMC/CONFIG_MMC_DAVINCI/g
s/CONFIG_OMAP_HSMMC/CONFIG_MMC_OMAP_HS/g
s/CONFIG_MXC_MMC/CONFIG_MMC_MXC/g
s/CONFIG_MXS_MMC/CONFIG_MMC_MXS/g
s/CONFIG_TEGRA_MMC/CONFIG_MMC_SDHCI_TEGRA/g
s/CONFIG_SUNXI_MMC/CONFIG_MMC_SUNXI/g
[2] Commit the changes
[3] Create entries in driver/mmc/Kconfig.
(copied from Linux)
[4] Move the options with the following command
tools/moveconfig.py -y -r HEAD \
MMC_DAVINCI MMC_OMAP_HS MMC_MXC MMC_MXS MMC_SDHCI_TEGRA MMC_SUNXI
[5] Sort and align drivers/mmc/Makefile for readability
A number of platforms had been using the distro default feature before
it was moved to Kconfig but did not enable the new Kconfig option when
it was enabled. This caused a regression in terms of features and this
introduces breakage when more things move to Kconfig.
CONFIG_SYS_CONSOLE_INFO_QUIET
[trini: Make this default n, re-run the migration]
Move SPL_OS_BOOT to Kconfig and cleanup existing
uses.
The config option AM33XX is used in several boards and should be
defined as a stand-alone option for this SOC. We break this out
from target boards that use this SoC and common headers then enable
AM33XX on in all the boards that used these targets to eliminate any
functional change with this patch.
This is similar to what has already been done in
9de852642cae ("arm: Kconfig: Add support for AM43xx SoC specific Kconfig")
and is done for the same reasons.
Acked-by: Lokesh Vutla <lokeshvutla@ti.com>
Introduce a hidden USB_FUNCTION_DFU Kconfig option and select it for
CMD_DFU (as we must have the DFU command enabled to do anything DFU).
Make all of the entries in drivers/dfu/Kconfig depend on CMD_DFU and add
options for all of the back end choices that DFU can make use of.
Cc: Lukasz Majewski <l.majewski@samsung.com>
Acked-by: Lukasz Majewski <l.majewski@samsung.com>
Move this option to Kconfig and tidy up existing uses.
