path: root/configs/am335x_boneblack_defconfig
2015-03-04ti: armv7: Move SPL SDRAM init to the right place, drop unused CONFIG_SPL_STACKSimon Glass
Currently in some cases SDRAM init requires global_data to be available and soon this will not be available prior to board_init_f(). Adjust the code paths in these cases to be correct. In some cases we had the SPL stack be in DDR as we might have large stacks (due to Falcon Mode + Environment). In these cases switch to CONFIG_SPL_STACK_R. In other cases we had simply been setting CONFIG_SPL_STACK into SRAM. In these cases we no longer need to (CONFIG_SYS_INIT_SP_ADDR is used and is also in SRAM) so drop those lines. Signed-off-by: Simon Glass <sjg@chromium.org> Tested on Beagleboard, Beagleboard xM Tested-by: Matt Porter <mporter@konsulko.com> Tested on Beaglebone Black, AM43xx GP EVM, OMAP5 uEVM, OMAP4 Pandaboard Tested-by: Tom Rini <trini@konsulko.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-10-23dm: am335x: Remove serial options from CONFIG_SYS_EXTRA_OPTIONSSimon Glass
With these options in place it is not possible to change the serial port using 'make menuconfig' or similar. It seems to result in duplicate defines. For example: In file included from include/linux/kconfig.h:4:0, from <command-line>:0: include/generated/autoconf.h:20:0: note: this is the location of the previous definition #define CONFIG_CONS_INDEX 2 ^ The default option seems to be 1 anyway, in board/ti/am335x/Kconfig. Remove the options so that we can adjust the serial port if required. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Tom Rini <trini@ti.com>
