path: root/configs/am335x_baltos_defconfig
2015-07-08arm: baltos: enable CMD_NET and FIT support in defconfigYegor Yefremov
Signed-off-by: Yegor Yefremov <yegorslists@googlemail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-06-15board: add support for Vision System's Baltos Industrial PCYegor Yefremov
Vision Systems's Baltos is based on AM335x SoC from Texas Instruments. This patch adds support such Industrial PCs in mainline u-boot. [ balbi@ti.com: updated original patch to current u-boot ] Signed-off-by: Yegor Yefremov <yegorslists@googlemail.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
