path: root/configs/alt_defconfig
2019-05-14net: phy: micrel: Allow KSZ8xxx and KSZ90x1 to be used togetherJames Byrne
Commit d397f7c45b0b ("net: phy: micrel: Separate KSZ9000 drivers from KSZ8000 drivers") separated the KSZ8xxx and KSZ90x1 drivers and warns that you shouldn't select both of them due to a device ID clash between the KSZ9021 and the KS8721, asserting that "it is highly unlikely for a system to contain both a KSZ8000 and a KSZ9000 PHY". Unfortunately boards like the SAMA5D3xEK do contain both types of PHY, but fortunately the Linux Micrel PHY driver provides a solution by using different PHY ID and mask values to distinguish these chips. This commit contains the following changes: - The PHY ID and mask values for the KSZ9021 and the KS8721 now match those used by the Linux driver. - The warnings about not enabling both drivers have been removed. - The description for PHY_MICREL_KSZ8XXX has been corrected (these are 10/100 PHYs, not GbE PHYs). - PHY_MICREL_KSZ9021 and PHY_MICREL_KSZ9031 no longer select PHY_GIGE since this is selected by PHY_MICREL_KSZ90X1. - All of the relevant defconfig files have been updated now that PHY_MICREL_KSZ8XXX does not default to 'Y'. Signed-off-by: James Byrne <james.byrne@origamienergy.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2019-03-30ARM: rmobile: alt: Synchronize defconfigMarek Vasut
Synchronize the R8A7794 Alt defconfig, enable DM SPI, DM SPI FLASH and I2C driver support. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2019-02-25ARM: rmobile: Convert Gen2 to OF_SEPARATEMarek Vasut
Convert R-Car Gen2 from OF_EMBED to OF_SEPARATE, thus getting rid of one of the deprecation warnings. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2019-02-07configs: Don't use SPI_FLASH_BAR as defaultVignesh R
Now that new SPI NOR layer uses stateless 4 byte opcodes by default, don't enable SPI_FLASH_BAR. For SPI controllers that cannot support 4-byte addressing, (stm32_qspi.c, fsl_qspi.c, mtk_qspi.c, ich.c, renesas_rpc_spi.c) add an imply clause to enable SPI_FLASH_BAR so as to not break functionality. Signed-off-by: Vignesh R <vigneshr@ti.com> Tested-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Tested-by: Stefan Roese <sr@denx.de> Tested-by: Horatiu Vultur <horatiu.vultur@microchip.com> Reviewed-by: Jagan Teki <jagan@openedev.com> Tested-by: Jagan Teki <jagan@amarulasolutions.com> #zynq-microzed
2018-11-13configs: Resync with savedefconfigTom Rini
2018-07-22Convert CONFIG_MTD_PARTITIONS et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_MTD_PARTITIONS CONFIG_MTD_DEVICE Signed-off-by: Adam Ford <aford173@gmail.com>
2018-06-01ARM: rmobile: Represent SF partitioning with mtdparts on AltMarek Vasut
Add mtdparts description for the board. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-05-02ARM: rmobile: Convert CONFIG_ARCH_RMOBILE_BOARD_STRING to KconfigMarek Vasut
Convert the symbol to Kconfig, no functional change. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-04-26ARM: rmobile: Update E2 AltMarek Vasut
The E2 Alt port was broken since some time. This patch updates the E2 Alt port to use modern frameworks, DM, DT probing, SPL for the preloading and puts it on par with the M2 Porter board. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-04-21mmc: sh_mmcif: Migrate configs to CONFIG_SH_MMCIFMarek Vasut
Migrate the U-Boot configs to Kconfig CONFIG_SH_MMCIF . Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Cc: Jaehoon Chung <jh80.chung@samsung.com>
2018-02-13spi: Migrate CONFIG_SH_QSPI to KconfigTuomas Tynkkynen
2018-02-10configs: Resync with savedefconfigTom Rini
2018-01-27ARM: rmobile: Enable OF_CONTROL on RCar Gen2Marek Vasut
Since the DTs are now in place, enable OF control so that they get bundled into the U-Boot. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-01-24ARM: rmobile: Convert CONFIG_R8A77xx to KconfigMarek Vasut
Convert these configuration options to Kconfig, update board defconfigs and drop them from whitelist. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-01-15net: sh-eth: Add to Kconfig and convertNobuhiro Iwamatsu
This adds SH_ETHER to drivers/net/Kconfig and convert to Kconfig. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2017-08-11Convert CONFIG_CMD_SDRAM to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_SDRAM Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-08-07Move PHY_MICREL and PHY_MICREL_KSZ90X1 to KconfigAlexandru Gagniuc
2017-08-03serial: sh: Convert to KconfigMarek Vasut
Convert the SH Serial to Kconfig using tools/moveconfig.py tool and a bit of manual adjustment to cater for failed conversions. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-04-08arm: rmobile: Remove default value of Kconfig from defconfigNobuhiro Iwamatsu
This removes CONFIG_BOOTSTAGE_USER_COUNT, CONFIG_BOOTSTAGE_STASH_ADDR and CONFIG_BOOTSTAGE_STASH_SIZE from defconfig following boards: - Alt - Gose - Koelsh - Lager - Porter - Silk - Stout - Blanche - Salvator-x Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2016-08-17arm: rmobile: Update defconfigNobuhiro Iwamatsu
This updated defconfig following boards: - Alt - Gose - Koelsh - Lager - Porter - Silk - Stout - Blanche Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2016-08-17ARM: Rmobile: Rename CONFIG_RMOBILE to CONFIG_ARCH_RMOBILENobuhiro Iwamatsu
2015-07-01defconfig: Move CONFIG_SPI_FLASH_BAR from configsJagan Teki
This commit moves: - CONFIG_SPI_FLASH_BAR from include/configs/*.h into configs/*_defconfigs Signed-off-by: Jagan Teki <jteki@openedev.com>
2015-04-18ARM: rmobile: use "select" instead of default value in defconfigMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Simon Glass <sjg@chromium.org>
