path: root/configs/ae350_rv32_spl_xip_defconfig
2020-04-28configs: Resync with savedefconfigTom Rini
2020-01-22configs: Resync with savedefconfigTom Rini
2019-12-10riscv: ax25-ae350: add SPL configurationRick Chen
This patch provides four configurations which can support U-Boot SPL to boot from RAM or FLASH and then boot FIT image including OpenSBI FW_DYNAMIC firmware and U-Boot proper images from RAM or MMC boot devices. With ae350_rv[32|64]_spl_defconfigs: U-Boot SPL will be loaded by gdb or FSBL and runs in RAM in machine mode and then load FIT image from RAM device on AE350. With ae350_rv[32|64]_spl_xip_defconfigs: U-Boot SPL can be burned into SPI flash and run in flash in machine mode and then load FIT image from SPI flash or MMC device on AE350. Signed-off-by: Rick Chen <rick@andestech.com> Cc: KC Lin <kclin@andestech.com> Cc: Alan Kao <alankao@andestech.com>
