path: root/configs/ae350_rv32_defconfig
2019-05-09riscv: configs: AE350 will use CONFIG_OF_PRIOR_STAGE when boots from ramRick Chen
When AE350 boots from ram, use CONFIG_OF_PRIOR_STAGE instead of CONFIG_OF_BOARD. Signed-off-by: Rick Chen <rick@andestech.com> Cc: Greentime Hu <greentime@andestech.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Lukas Auer <lukas.auer@aisec.fraunhofer.de>
2019-04-08riscv: ax25: Add platform-specific Kconfig optionsRick Chen
Add ax25 RISC-V platform-specific Kconfig options, to include CPU and timer drivers. Also disable ATCPIT100 SoC timer and replace by PLMT. Signed-off-by: Rick Chen <rick@andestech.com> Cc: Greentime Hu <greentime@andestech.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Lukas Auer <lukas.auer@aisec.fraunhofer.de>
2018-12-18riscv: configs: Rename ax25-ae350 defconfigRick Chen
Remove cpu name from the defconfig naming. Because other cpus maybe run on AE350 platform. So only use platfrom name in defconfig naming will be better. Also sync MAINTAINERS: Rename a25-ae350_32_defconfig as ae350_rv32_defconfig ax25-ae350_64_defconfig as ae350_rv64_defconfig Signed-off-by: Rick Chen <rick@andestech.com> Cc: Greentime Hu <greentime@andestech.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
