path: root/configs/Wexler_TAB7200_defconfig
2015-10-20sunxi: Kconfig-ify CONFIG_AXP152_POWER and _AXP209_POWERHans de Goede
Kconfig-ify CONFIG_AXP152_POWER and _AXP209_POWER settings, removing them from CONFIG_SYS_EXTRA_OPTIONS. Note that sun5i boards can have either an AXP209 or an AXP152 pmic, the Kconfig default is AXP209, boards with an AXP152 must explicitly select this. Likewise boards without a pmic must explicitly select SUNXI_NO_PMIC in their defconfig. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-08-08sunxi: Enable USB DRC on Wexler TAB7200Aleksei Mamlin
Enable the otg/drc usb controller on the Wexler TAB7200 tablet. Signed-off-by: Aleksei Mamlin <mamlinav@gmail.com> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-03-10sunxi: Add Wexler TAB7200 supportAleksei Mamlin
This patch add support for Wexler TAB7200 tablet. The Wexler TAB7200 is a A20 based tablet with 7 inch display(800x480), capacitive touchscreen(5 fingers), 1G RAM, 4G NAND, micro SD card slot, mini HDMI port, 3.5mm audio plug, 1 USB OTG port and 1 USB 2.0 port. Signed-off-by: Aleksei Mamlin <mamlinav@gmail.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
