path: root/configs/TQM5200_B_defconfig
2016-10-23Convert CONFIG_CONSOLE_EXTRA_INFO to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CONSOLE_EXTRA_INFO Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
