CONFIG_FSL_CORENET
CONFIG_SYS_FLASH_QUIET_TEST
CONFIG_SYS_MAX_FLASH_SECT
CONFIG_SYS_FLASH_EMPTY_INFO
CONFIG_SYS_CACHE_STASHING
- Migrate more CONFIG options to Kconfig and remove some unused code
while we're at it.
CONFIG_SYS_FSL_CPC
CONFIG_SYS_CPC_REINIT_F
CONFIG_SYS_BOOK3E_HV
CONFIG_PCIE1
CONFIG_PCIE2
CONFIG_PCIE3
CONFIG_PCIE4
CONFIG_PCI1
CONFIG_ENABLE_36BIT_PHYS
CONFIG_USB_MAX_CONTROLLER_COUNT
CONFIG_FSL_SATA_V2
CONFIG_SYS_PBSIZE
removed sec_init() call from board files.
sec is initialized based on job ring information processed
from device tree.
Signed-off-by: Gaurav Jain <gaurav.jain@nxp.com>
Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
CONFIG_ETHPRIME
This is also done by adding a gating Kconfig option, CONFIG_USE_ETHPRIME
similar to other options that are not always set and control environment
variables.
CONFIG_BOOTFILE
CONFIG_SCSI_AHCI_PLAT
CONFIG_SYS_SCSI_MAX_SCSI_ID
CONFIG_SYS_SCSI_MAX_LUN
CONFIG_SYS_SATA_MAX_DEVICE
Drop CONFIG_SCSI for everything except the sandbox build. We only need
one build for tests.
Use moveconfig.py script to convert define CONFIG_SYS_MAX_FLASH_BANKS
and CONFIG_SYS_MAX_FLASH_BANKS_DETECT to Kconfig and move these entries
to defconfigs.
Signed-off-by: Patrick Delaunay <patrick.delaunay@foss.st.com>
[trini: Re-switch to IS_ENABLED check in spi-nor-core.c, re-run migration]
CONFIG_VID
CONFIG_VOL_MONITOR_INA220
CONFIG_VOL_MONITOR_IR36021_READ
CONFIG_VOL_MONITOR_IR36021_SET
CONFIG_VOL_MONITOR_LTC3882_READ
CONFIG_VOL_MONITOR_LTC3882_SET
To finish this migration, we first need to introduce CONFIG_SPL_VID as
some platforms only use this code in full U-Boot while others use it in
SPL as well. To make the Kconfig logic clearer, guard all of the
sub-options with a if VID || SPL_VID check. Finally, add Kconfig
options for the remaining related options that did not previously have
one.
CONFIG_CONS_INDEX
CONFIG_DEBUG_UART_CLOCK
CONFIG_FSL_TZPC_BP147
CONFIG_GENERIC_ATMEL_MCI
CONFIG_IDENT_STRING
CONFIG_LIBATA
CONFIG_LNX_KRNL_IMG_TEXT_OFFSET_BASE
CONFIG_LPC32XX_GPIO
CONFIG_MP
CONFIG_MPC8XXX_GPIO
CONFIG_MTD_PARTITIONS
CONFIG_MVGBE
CONFIG_MXC_GPIO
CONFIG_NR_DRAM_BANKS
CONFIG_OF_BOARD_SETUP
CONFIG_OF_STDOUT_VIA_ALIAS
CONFIG_OF_SYSTEM_SETUP
CONFIG_PREBOOT
CONFIG_ROCKCHIP_SERIAL
CONFIG_RTC_ENABLE_32KHZ_OUTPUT
CONFIG_RTC_MV
CONFIG_SCSI_AHCI
CONFIG_SF_DEFAULT_BUS
CONFIG_SF_DEFAULT_CS
CONFIG_SF_DEFAULT_SPEED
CONFIG_SOFT_SPI
CONFIG_SPI_FLASH_EON
CONFIG_SPI_FLASH_MACRONIX
CONFIG_SPI_FLASH_MTD
CONFIG_SPI_FLASH_SPANSION
CONFIG_SPI_FLASH_SST
CONFIG_SPI_FLASH_STMICRO
CONFIG_SUPPORT_RAW_INITRD
CONFIG_SYS_ARCH_TIMER
CONFIG_SYS_BOARD
CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE
CONFIG_SYS_DCACHE_OFF
CONFIG_SYS_FDT_SAVE_ADDRESS
CONFIG_SYS_FLASH_CFI
CONFIG_SYS_FSL_ERRATUM_ESDHC135
CONFIG_SYS_HAS_SERDES
CONFIG_SYS_L2CACHE_OFF
CONFIG_SYS_LITTLE_ENDIAN
CONFIG_SYS_LOAD_ADDR
CONFIG_SYS_MMCSD_FS_BOOT_PARTITION
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR
CONFIG_SYS_NS16550
CONFIG_SYS_PLLFIN
CONFIG_SYS_SPI_U_BOOT_OFFS
CONFIG_TIMER_SYS_TICK_CH
CONFIG_USB_EHCI_FSL
CONFIG_U_QE
CONFIG_VERSION_VARIABLE
CONFIG_USE_BOOTCOMMAND
CONFIG_BOOTCOMMAND
CONFIG_RAMBOOTCOMMAND
CONFIG_NFSBOOTCOMMAND
Use moveconfig.py script to convert CONFIG_SYS_FMAN_FW_ADDR,
CONFIG_SYS_QE_FW_ADDR and CONFIG_SYS_QE_FMAN_FW_LENGTH to Kconfig and
move these entries to defconfigs.
Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com>
[Rebased]
Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
Resync all defconfig files using moveconfig.py
- Guard most of the options in drivers/ddr/fsl/Kconfig with
SYS_FSL_DDR || SYS_FSL_MMDC.
- Migrate FSL_DMA, DDR_ECC, DDR_ECC_CMD, and ECC_INIT_VIA_DDRCONTROLLER
to Kconfig.
- Clean up the logic for including the DDR_ECC_CMD code.
As this symbol can either be a fixed value or the function
get_board_ddr_clk, migration is tricky. Introduce a choice of DYNAMIC
or STATIC_DDR_CLK_FREQ. If DYNAMIC, we continue to use the board
defined get_board_ddr_clk function. If STATIC, set CONFIG_DDR_CLK_FREQ
to that value and now include/clock_legacy.h contains the function
prototype or defines get_board_ddr_clk() to that static value. Update
callers to test for DYNAMIC or STATIC.
CONFIG_I2C_SET_DEFAULT_BUS_NUM
CONFIG_I2C_DEFAULT_BUS_NUMBER
- As there are no boards that use different values for speed / slave on
different buses, use a single option.
- Switch to using the common SYS_I2C_SPEED / SYS_I2C_SLAVE options.
- Introduce _HAS_ options for additional buses as only the first one is
common to all users.
- Convert all remaining symbols to Kconfig.
First, we convert CONFIG_SYS_I2C_LEGACY to Kconfig. Next, as you cannot
have SYS_I2C_LEGACY and DM_I2C at the same time, introduce
CONFIG_SPL_SYS_I2C_LEGACY so that we can enable the legacy option only
in SPL. Finally, for some PowerPC cases we also need
CONFIG_TPL_SYS_I2C_LEGACY support. Convert all of the existing users to
one or more symbols.
Use moveconfig.py script to convert below defines to Kconfig and move
CONFIG_CORTINA_FW_ADDR
CONFIG_CORTINA_FW_LENGTH
Signed-off-by: Kuldeep Singh <kuldeep.singh@nxp.com>
Enable DM_ETH and DM_MDIO for the T4240RDB.
Signed-off-by: Camelia Groza <camelia.groza@nxp.com>
commit 0cfccb54014b ("configs: Resync with savedefconfig")
removed CONFIG_USB_STORAGE from some powerpc platforms' defconfig
files, whicih would block the use case of system loading rootfs
from USB drives, add them back.
Signed-off-by: Ran Wang <ran.wang_1@nxp.com>
Enable the DM ESPI driver in T4240RDB defconfig.
Signed-off-by: Xiaowei Bao <xiaowei.bao@nxp.com>
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com>
[Rebased]
CONFIG_ENV_OVERWRITE
[trini: Rerun migration, remove some comments]
Move ADDR_MAP related config options from include/configs/*.h to the
proper place in lib/Kconfig. This has been done using
./tools/moveconfig.py and manual inspection of the generated changes.
This is a preparation to use ADDR_MAP helper on ARM 32bit Raspberry Pi4
board for mapping the PCIe XHCI MMIO, which is above the 4GiB identity
mapping limit.
This enable DM_I2C in T4240RDB defconfigs
Signed-off-by: Biwen Li <biwen.li@nxp.com>
CONFIG_PHYLIB
CONFIG_BITBANGMII
CONFIG_MV88E6352_SWITCH
CONFIG_MV88E61XX_SWITCH
CONFIG_PHYLIB_10G
CONFIG_PHY_AQUANTIA
CONFIG_PHY_ATHEROS
CONFIG_PHY_BROADCOM
CONFIG_PHY_CORTINA
CONFIG_PHY_DAVICOM
CONFIG_PHY_ET1011C
CONFIG_PHY_LXT
CONFIG_PHY_MARVELL
CONFIG_PHY_MICREL
CONFIG_PHY_NATSEMI
CONFIG_PHY_REALTEK
CONFIG_RTL8211X_PHY_FORCE_MASTER
CONFIG_PHY_SMSC
CONFIG_PHY_TERANETICS
CONFIG_PHY_TI
CONFIG_PHY_VITESSE
CONFIG_PHY_XILINX
MTD must be enabled when there is a SPI NOR flash using the
SPI_FLASH_MTD config entry.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
CONFIG_PHY_CORTINA
Enable eSDHC device module for T4240RDB board
Signed-off-by: Yinbo Zhu <yinbo.zhu@nxp.com>
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
