CONFIG_GATEWAYIP
CONFIG_HOSTNAME
CONFIG_IPADDR
CONFIG_NETMASK
CONFIG_ROOTPATH
CONFIG_SERVERIP
CONFIG_UBOOTPATH
To do this, we introduce a CONFIG_USE_ form of each of the above and
change include/env_default.h to test for that to be set before setting a
value. Further, we don't want to stringify the IP address related values
as they are now properly strings via Kconfig.
CONFIG_SPL_NS16550_MIN_FUNCTIONS
CONFIG_SYS_NS16550_MEM32
CONFIG_SYS_NS16550_PORT_MAPPED
CONFIG_SYS_NS16550_REG_SIZE
CONFIG_SYS_NS16550_SERIAL
To do this we also introduce CONFIG_SPL_SYS_NS16550_SERIAL so that
platforms can enable the legacy driver here for SPL.
CONFIG_SYS_MONITOR_LEN
To do this, we set a default of 0 for everyone because there are a
number of cases where we define CONFIG_SYS_MONITOR_LEN but the only
impact is that we set TOTAL_MALLOC_LEN to be CONFIG_SYS_MALLOC_LEN +
CONFIG_ENV_SIZE, so we must continue to allow all boards to set this
value. Update the SPL code to use 200 KB as the default raw U-Boot size
directly, if we don't have a real CONFIG_SYS_MONITOR_LEN value.
CONFIG_SYS_LOADS_BAUD_CHANGE
CONFIG_LOADS_ECHO
As part of this, we move CMD_SAVES to be after CMD_LOADS as they are
logically related (load or save an s-record format file) and this makes
grouping of CONFIG_SYS_LOADS_BAUD_CHANGE easier.
CONFIG_SYS_INIT_RAM_LOCK
The current name is inconsistent with SPL which uses CONFIG_SPL_TEXT_BASE
and this makes it imposible to use CONFIG_VAL().
Rename it to resolve this problem.
CONFIG_SYS_FSL_NUM_CC_PLLS
CONFIG_FSL_CORENET
CONFIG_SYS_FLASH_QUIET_TEST
CONFIG_SYS_MAX_FLASH_SECT
CONFIG_SYS_FLASH_EMPTY_INFO
CONFIG_SYS_CACHE_STASHING
- Migrate more CONFIG options to Kconfig and remove some unused code
while we're at it.
CONFIG_SYS_FSL_CPC
CONFIG_SYS_CPC_REINIT_F
CONFIG_SYS_BOOK3E_HV
CONFIG_PCIE1
CONFIG_PCIE2
CONFIG_PCIE3
CONFIG_PCIE4
CONFIG_PCI1
CONFIG_ENABLE_36BIT_PHYS
CONFIG_USB_MAX_CONTROLLER_COUNT
CONFIG_SYS_MPC85XX_NO_RESETVEC
CONFIG_FSL_SATA_V2
Currently CONFIG_SPL_TEXT_BASE and CONFIG_SYS_TEXT_BASE addresses are
manually increased by 0x1000 due to .bootpg section. This section has size
of 0x1000 bytes and is manually put by linker script before .text section
(and therefore before base address) when CONFIG_SYS_MPC85XX_NO_RESETVEC is
set. Due to this fact lot of other config options are manually increased by
0x1000 value to make correct layout. Note that entry point is not on
CONFIG_SPL_TEXT_BASE (image+0x1000) but it is really on address
CONFIG_SPL_TEXT_BASE-0x1000 (means at the start of the image).
Cleanup handling of .bootpg section when CONFIG_SYS_MPC85XX_NO_RESETVEC is
set. Put .bootpg code directly into .text section and move text base
address to the start of .bootpg code. And finally remove +0x1000 value from
lot of config options. With this removal custom PHDRS is not used anymore,
so remove it too.
After this change entry point would be at CONFIG_SPL_TEXT_BASE and not at
address -0x1000 anymore.
Tested on P2020 board with SPL and proper U-Boot.
Signed-off-by: Pali Rohár <pali@kernel.org>
CONFIG_SPL_GD_ADDR
CONFIG_SPL_RELOC_TEXT_BASE
CONFIG_SPL_RELOC_STACK
CONFIG_SPL_RELOC_MALLOC_ADDR
CONFIG_SPL_RELOC_MALLOC_SIZE
A number of PowerPC platforms define this, for SPL. To move this to
Kconfig, it needs to be CONFIG_SPL_SYS_CCSR_DO_NOT_RELOCATE, so use
CONFIG_IS_ENABLED() to check for usage. A number of layerscape
platforms bring this logic from PowerPC, but only need a small part of
it, for the fman driver. Remove their unused portion at least.
CONFIG_SPL_PAD_TO
CONFIG_SPL_MAX_SIZE
CONFIG_TPL_PAD_TO
CONFIG_TPL_MAX_SIZE
Note that we need to make TPL_MAX_SIZE be hex, and so move and convert the
existing places.
CONFIG_SPL_INIT_MINIMAL
CONFIG_SPL_FLUSH_IMAGE
CONFIG_SPL_SKIP_RELOCATE
CONFIG_SYS_PBSIZE
removed sec_init() call from board files.
sec is initialized based on job ring information processed
from device tree.
Signed-off-by: Gaurav Jain <gaurav.jain@nxp.com>
Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
CONFIG_SDCARD
CONFIG_SPIFLASH
CONFIG_ETHPRIME
This is also done by adding a gating Kconfig option, CONFIG_USE_ETHPRIME
similar to other options that are not always set and control environment
variables.
CONFIG_BOOTFILE
CONFIG_SCSI_AHCI_PLAT
CONFIG_SYS_SCSI_MAX_SCSI_ID
CONFIG_SYS_SCSI_MAX_LUN
CONFIG_SYS_SATA_MAX_DEVICE
Drop CONFIG_SCSI for everything except the sandbox build. We only need
one build for tests.
Use moveconfig.py script to convert define CONFIG_SYS_MAX_FLASH_BANKS
and CONFIG_SYS_MAX_FLASH_BANKS_DETECT to Kconfig and move these entries
to defconfigs.
Signed-off-by: Patrick Delaunay <patrick.delaunay@foss.st.com>
[trini: Re-switch to IS_ENABLED check in spi-nor-core.c, re-run migration]
CONFIG_VID
CONFIG_VOL_MONITOR_INA220
CONFIG_VOL_MONITOR_IR36021_READ
CONFIG_VOL_MONITOR_IR36021_SET
CONFIG_VOL_MONITOR_LTC3882_READ
CONFIG_VOL_MONITOR_LTC3882_SET
To finish this migration, we first need to introduce CONFIG_SPL_VID as
some platforms only use this code in full U-Boot while others use it in
SPL as well. To make the Kconfig logic clearer, guard all of the
sub-options with a if VID || SPL_VID check. Finally, add Kconfig
options for the remaining related options that did not previously have
one.
CONFIG_CONS_INDEX
CONFIG_DEBUG_UART_CLOCK
CONFIG_FSL_TZPC_BP147
CONFIG_GENERIC_ATMEL_MCI
CONFIG_IDENT_STRING
CONFIG_LIBATA
CONFIG_LNX_KRNL_IMG_TEXT_OFFSET_BASE
CONFIG_LPC32XX_GPIO
CONFIG_MP
CONFIG_MPC8XXX_GPIO
CONFIG_MTD_PARTITIONS
CONFIG_MVGBE
CONFIG_MXC_GPIO
CONFIG_NR_DRAM_BANKS
CONFIG_OF_BOARD_SETUP
CONFIG_OF_STDOUT_VIA_ALIAS
CONFIG_OF_SYSTEM_SETUP
CONFIG_PREBOOT
CONFIG_ROCKCHIP_SERIAL
CONFIG_RTC_ENABLE_32KHZ_OUTPUT
CONFIG_RTC_MV
CONFIG_SCSI_AHCI
CONFIG_SF_DEFAULT_BUS
CONFIG_SF_DEFAULT_CS
CONFIG_SF_DEFAULT_SPEED
CONFIG_SOFT_SPI
CONFIG_SPI_FLASH_EON
CONFIG_SPI_FLASH_MACRONIX
CONFIG_SPI_FLASH_MTD
CONFIG_SPI_FLASH_SPANSION
CONFIG_SPI_FLASH_SST
CONFIG_SPI_FLASH_STMICRO
CONFIG_SUPPORT_RAW_INITRD
CONFIG_SYS_ARCH_TIMER
CONFIG_SYS_BOARD
CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE
CONFIG_SYS_DCACHE_OFF
CONFIG_SYS_FDT_SAVE_ADDRESS
CONFIG_SYS_FLASH_CFI
CONFIG_SYS_FSL_ERRATUM_ESDHC135
CONFIG_SYS_HAS_SERDES
CONFIG_SYS_L2CACHE_OFF
CONFIG_SYS_LITTLE_ENDIAN
CONFIG_SYS_LOAD_ADDR
CONFIG_SYS_MMCSD_FS_BOOT_PARTITION
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR
CONFIG_SYS_NS16550
CONFIG_SYS_PLLFIN
CONFIG_SYS_SPI_U_BOOT_OFFS
CONFIG_TIMER_SYS_TICK_CH
CONFIG_USB_EHCI_FSL
CONFIG_U_QE
CONFIG_VERSION_VARIABLE
CONFIG_USE_BOOTCOMMAND
CONFIG_BOOTCOMMAND
CONFIG_RAMBOOTCOMMAND
CONFIG_NFSBOOTCOMMAND
Use moveconfig.py script to convert CONFIG_SYS_FMAN_FW_ADDR,
CONFIG_SYS_QE_FW_ADDR and CONFIG_SYS_QE_FMAN_FW_LENGTH to Kconfig and
move these entries to defconfigs.
Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com>
[Rebased]
Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
Resync all defconfig files using moveconfig.py
Rename these options so that CONFIG_IS_ENABLED can be used with them.
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
[trini: Fixup some incorrect renames]
CONFIG_RAMBOOT_PBL
CONFIG_SYS_FSL_PBL_PBI
CONFIG_SYS_FSL_PBL_RCW
- Guard most of the options in drivers/ddr/fsl/Kconfig with
SYS_FSL_DDR || SYS_FSL_MMDC.
- Migrate FSL_DMA, DDR_ECC, DDR_ECC_CMD, and ECC_INIT_VIA_DDRCONTROLLER
to Kconfig.
- Clean up the logic for including the DDR_ECC_CMD code.
As this symbol can either be a fixed value or the function
get_board_ddr_clk, migration is tricky. Introduce a choice of DYNAMIC
or STATIC_DDR_CLK_FREQ. If DYNAMIC, we continue to use the board
defined get_board_ddr_clk function. If STATIC, set CONFIG_DDR_CLK_FREQ
to that value and now include/clock_legacy.h contains the function
prototype or defines get_board_ddr_clk() to that static value. Update
callers to test for DYNAMIC or STATIC.
CONFIG_I2C_SET_DEFAULT_BUS_NUM
CONFIG_I2C_DEFAULT_BUS_NUMBER
- As there are no boards that use different values for speed / slave on
different buses, use a single option.
- Switch to using the common SYS_I2C_SPEED / SYS_I2C_SLAVE options.
- Introduce _HAS_ options for additional buses as only the first one is
common to all users.
- Convert all remaining symbols to Kconfig.
