path: root/configs/T4240QDS_defconfig
2016-11-23powerpc: T4240: Remove macro CONFIG_PPC_T4240York Sun
Use CONFIG_ARCH_T4240 from Kconfig instead. Signed-off-by: York Sun <york.sun@nxp.com>
