path: root/configs/T4240QDS_SRIO_PCIE_BOOT_defconfig
2017-07-25Convert CONFIG_ENV_IS_IN_REMOTE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_ENV_IS_IN_REMOTE Signed-off-by: Simon Glass <sjg@chromium.org>
2016-11-23powerpc: T4240: Remove macro CONFIG_PPC_T4240York Sun
Use CONFIG_ARCH_T4240 from Kconfig instead. Signed-off-by: York Sun <york.sun@nxp.com>
