path: root/configs/T4160QDS_defconfig
2016-11-23powerpc: T4160: Remove macro CONFIG_PPC_T4160York Sun
Use CONFIG_ARCH_T4160 instead. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: T4160QDS: Separate from T4240QDS in KconfigYork Sun
Use TARGET_T4160QDS to simplify Kconfig options. Signed-off-by: York Sun <york.sun@nxp.com>
