path: root/configs/T2081QDS_SRIO_PCIE_BOOT_defconfig
2017-07-25Convert CONFIG_ENV_IS_IN_REMOTE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_ENV_IS_IN_REMOTE Signed-off-by: Simon Glass <sjg@chromium.org>
2016-11-23powerpc: T2080, T2081: Remove macro CONFIG_PPC_T2080 and CONFIG_PPC_T2081York Sun
Use CONFIG_ARCH_T2080 and CONFIG_ARCH_T2081 instead. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: T208XQDS: Split as T2080QDS and T2081QDSYork Sun
Use two separated targets in Kconfig to simplify configurations. Signed-off-by: York Sun <york.sun@nxp.com>
