path: root/configs/T2080RDB_SRIO_PCIE_BOOT_defconfig
2019-05-26configs: Migrate CONFIG_FMAN_ENET and some related options to KconfigTom Rini
Move the main symbol for Freescale Fman Ethernet controller option to Kconfig. Also migrate the CONFIG_SYS_QE_FMAN_FW_IN_xxx macros and rename the SPIFLASH one to follow the same format as all of the others. To do this fully we need to migrate CONFIG_QC, do so. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-10-24configs: migrate CONFIG_PHY_AQUANTIA to KconfigJeremy Gebben
The aquantia driver requires both CONFIG_PHY_GIGE and CONFIG_PHYLIB_10G. Signed-off-by: Jeremy Gebben <jgebben@sweptlaser.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-04-08treewide: Migrate CONFIG_SYS_ALT_MEMTEST to KconfigMario Six
Migrate the CONFIG_SYS_ALT_MEMTEST option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc> [trini: Re-run migration after also including CMD_MEMTEST] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-07-25Convert CONFIG_ENV_IS_IN_REMOTE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_ENV_IS_IN_REMOTE Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_IRQ to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_IRQ Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-11-23powerpc: T2080, T2081: Remove macro CONFIG_PPC_T2080 and CONFIG_PPC_T2081York Sun
Use CONFIG_ARCH_T2080 and CONFIG_ARCH_T2081 instead. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: T2080RDB: Rename from T208XRDB in KconfigYork Sun
T208XRDB only has one target T2080RDB. Use TARGET_T2080RDB in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
