Enable DM_ETH and DM_MDIO for the T2080RDB.
Signed-off-by: Camelia Groza <camelia.groza@nxp.com>
Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
The T2080RDB has a ds1339 on i2c0. Add this to the devicetree and enable
the relevant support in the configs.
Signed-off-by: Chris Packham <judge.packham@gmail.com>
Bring in the assorted changes that have been staged in the 'next' branch
prior to release.
commit 0cfccb54014b ("configs: Resync with savedefconfig")
removed CONFIG_USB_STORAGE from some powerpc platforms' defconfig
files, whicih would block the use case of system loading rootfs
from USB drives, add them back.
Signed-off-by: Ran Wang <ran.wang_1@nxp.com>
Enable the DM ESPI driver in T2080RDB defconfig.
Signed-off-by: Xiaowei Bao <xiaowei.bao@nxp.com>
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com>
[Rebased]
Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
Setting CONFIG_ENV_ADDR to something other than 0 stops gd->env_addr
from being allocated dynamically. When the environment is in SPI we need
it to be allocated as we can't use a direct memory mapped address.
CONFIG_ENV_OVERWRITE
[trini: Rerun migration, remove some comments]
Move ADDR_MAP related config options from include/configs/*.h to the
proper place in lib/Kconfig. This has been done using
./tools/moveconfig.py and manual inspection of the generated changes.
This is a preparation to use ADDR_MAP helper on ARM 32bit Raspberry Pi4
board for mapping the PCIe XHCI MMIO, which is above the 4GiB identity
mapping limit.
Move below defines which are used by mtest utility to Kconfig.
CONFIG_SYS_MEMTEST_START
CONFIG_SYS_MEMTEST_END
Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com>
[trini: Fix kmcoge5ne board, re-run migration as well]
This enables DM_I2C in T2080 defconfigs
Signed-off-by: Biwen Li <biwen.li@nxp.com>
- Finish migration of CONFIG_PHYLIB and a number of related symbols to
defconfig files.
CONFIG_PHYLIB
CONFIG_BITBANGMII
CONFIG_MV88E6352_SWITCH
CONFIG_MV88E61XX_SWITCH
CONFIG_PHYLIB_10G
CONFIG_PHY_AQUANTIA
CONFIG_PHY_ATHEROS
CONFIG_PHY_BROADCOM
CONFIG_PHY_CORTINA
CONFIG_PHY_DAVICOM
CONFIG_PHY_ET1011C
CONFIG_PHY_LXT
CONFIG_PHY_MARVELL
CONFIG_PHY_MICREL
CONFIG_PHY_NATSEMI
CONFIG_PHY_REALTEK
CONFIG_RTL8211X_PHY_FORCE_MASTER
CONFIG_PHY_SMSC
CONFIG_PHY_TERANETICS
CONFIG_PHY_TI
CONFIG_PHY_VITESSE
CONFIG_PHY_XILINX
Both symbols must be enabled when there is a raw NAND driver
selected. Also enable them when CONFIG_CMD_NAND is selected to avoid
breaking things when we'll further rework the MTD dependency
description.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
[trini: Rebase and migrate a few more boards here]
CONFIG_SYS_CORTINA_FW_IN_MMC
CONFIG_SYS_CORTINA_FW_IN_NAND
CONFIG_SYS_CORTINA_FW_IN_NOR
CONFIG_SYS_CORTINA_FW_IN_REMOTE
CONFIG_SYS_CORTINA_FW_IN_SPIFLASH
CONFIG_PHY_CORTINA
Enable eSDHC device module for T2080RDB board
Signed-off-by: Yinbo Zhu <yinbo.zhu@nxp.com>
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Enable the DM PCIe driver in T2080RDB defconfig.
Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
Add device tree for T2080RDB board and enable CONFIG_OF_CONTROL
so that device tree can be compiled.
Update board README for device tree usage.
The non-CONFIG_SPL_FRAMEWORK SPL used on some PowerPC platforms have a
choice between CONFIG_SPL_NAND_BOOT, CONFIG_SPL_MMC_BOOT and
CONFIG_SPL_SPI_BOOT. Migrate this to Kconfig
Move the main symbol for Freescale Fman Ethernet controller option to
Kconfig. Also migrate the CONFIG_SYS_QE_FMAN_FW_IN_xxx macros and
rename the SPIFLASH one to follow the same format as all of the others.
To do this fully we need to migrate CONFIG_QC, do so.
Moved CONFIG_SPL_TEXT_BASE to common/spl/Kconfig and migrate existing
values.
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
[trini: Re-run migration]
CONFIG_SF_DEFAULT_BUS
CONFIG_SF_DEFAULT_CS
CONFIG_SF_DEFAULT_MODE
CONFIG_SF_DEFAULT_SPEED
I use moveconfig script and then manual check on generated u-boot.cfg
to solve the remaining issue.
Now that CMD_UBI does not select CMD_MTDPARTS we need to make platforms
that had been enabling it turn it on by hand. This exposed that we had
not yet migrated CMD_MTDPARTS fully, so do so now.
Fixes: 86dfa556d927 ("cmd: ubi: Remove useless call to mtdparts_init()")
The aquantia driver requires both CONFIG_PHY_GIGE and CONFIG_PHYLIB_10G.
Signed-off-by: Jeremy Gebben <jgebben@sweptlaser.com>
CONFIG_FLASH_CFI_DRIVER
CONFIG_SYS_FLASH_USE_BUFFER_WRITE
CONFIG_FLASH_CFI_MTD
CONFIG_SYS_FLASH_PROTECTION
CONFIG_SYS_FLASH_CFI
[trini: Re-migrate]
CONFIG_MII
CONFIG_DRIVER_TI_EMAC
Acked-by: Jagan Teki <jagan@amarulasolutions.com>
CONFIG_MTD_PARTITIONS
CONFIG_MTD_DEVICE
This patch moves CONFIG_MP to Kconfig
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
CONFIG_SPI
This partly involves updating code that assumes that CONFIG_SPI implies
things that are specific to the MPC8xx SPI driver. For now, just update
the CONFIG tests. This also involves reworking the default for
CONFIG_SYS_DEF_EEPROM_ADDR so that we don't set it when we cannot make a
reasonable default, as it does not cause any compile failures.
Migrate the CONFIG_FSL_ESDHC option to Kconfig.
Signed-off-by: Mario Six <mario.six@gdsys.cc>
Migrate the CONFIG_BOARD_EARLY_INIT_R option to Kconfig.
Migrate the CONFIG_SYS_ALT_MEMTEST option to Kconfig.
[trini: Re-run migration after also including CMD_MEMTEST]
Migrate the option CONFIG_SPL_FRAMEWORK and make this gate most of the
current set of options we have in Kconfig. We will need to have some
options available for SPL and !SPL_FRAMEWORK so this is important. In a
few cases we re-order existing options so that we have less escapes from
the SPL_FRAMEWORK guard.
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
We move all instances of CONFIG_MTDIDS_DEFAULT and
CONFIG_MTDPARTS_DEFAULT from the header files to the defconfig files.
There's a few cases here where we need to expand upon what was in the
header file.
Tested-by: Adam Ford <aford173@gmail.com> #omap3_logic
Having this as a 'default y' is rather annoying because it doesn't
actually compile unless other options are defined in the board header:
../cmd/bootm.c: In function 'do_imls_nor':
../cmd/bootm.c:330:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
Make it 'default n' so people who develop new boards that start from a
blank defconfig have one less compilation failure to debug.
