path: root/configs/T2080RDB_NAND_defconfig
2016-11-23powerpc: T2080, T2081: Remove macro CONFIG_PPC_T2080 and CONFIG_PPC_T2081York Sun
Use CONFIG_ARCH_T2080 and CONFIG_ARCH_T2081 instead. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: T2080RDB: Rename from T208XRDB in KconfigYork Sun
T208XRDB only has one target T2080RDB. Use TARGET_T2080RDB in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-09-20configs: Re-syncTom Rini
2016-09-16Convert CONFIG_SPL_ENV_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_DRIVERS_MISC_SUPPORT to KconfigSimon Glass
