path: root/configs/T2080QDS_SECURE_BOOT_defconfig
2019-11-08freescale/powerpc: Rename the config CONFIG_SECURE_BOOT nameUdit Agarwal
Rename the CONFIG_SECURE_BOOT name to CONFIG_NXP_ESBC to avoid conflicts with UEFI secure boot. Signed-off-by: Udit Agarwal <udit.agarwal@nxp.com> Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
2019-06-20configs: T2080QDS: Enable PCIe driverHou Zhiqiang
Enable the DM PCIe driver in T2080QDS defconfig. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-05-26configs: Resync with savedefconfigTom Rini
2019-05-26configs: Migrate CONFIG_FMAN_ENET and some related options to KconfigTom Rini
Move the main symbol for Freescale Fman Ethernet controller option to Kconfig. Also migrate the CONFIG_SYS_QE_FMAN_FW_IN_xxx macros and rename the SPIFLASH one to follow the same format as all of the others. To do this fully we need to migrate CONFIG_QC, do so. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-05-23configs: enable sata, eSDHC, USB device module in T2080QDSPeng Ma
Enable eSDHC, SATA and USB DM for T2080QDS in uboot Signed-off-by: Peng Ma <peng.ma@nxp.com> Signed-off-by: Yinbo Zhu <yinbo.zhu@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-05-23configs: T2080QDS: enable device tree support for pcieboot & secure bootYinbo Zhu
2018-10-24configs: migrate CONFIG_PHY_AQUANTIA to KconfigJeremy Gebben
The aquantia driver requires both CONFIG_PHY_GIGE and CONFIG_PHYLIB_10G. Signed-off-by: Jeremy Gebben <jgebben@sweptlaser.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-07-22Convert CONFIG_MTD_PARTITIONS et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_MTD_PARTITIONS CONFIG_MTD_DEVICE Signed-off-by: Adam Ford <aford173@gmail.com>
2017-07-24configs: Migrate RBTREE, LZO, CMD_MTDPARTS, CMD_UBI and CMD_UBIFSTom Rini
The above CONFIG options are in Kconfig, and now have correct depends and inter-dependencies. Migrate these to configs/ from include/configs/. In the case of CMD_UBIFS also change it to be a default y if CMD_UBI. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-12-02powerpc: mpc85xx: Move SECURE_BOOT to KconfigYork Sun
Move from CONFIG_SYS_EXTRA_OPTIONS to Kconfig option. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: T2080, T2081: Remove macro CONFIG_PPC_T2080 and CONFIG_PPC_T2081York Sun
Use CONFIG_ARCH_T2080 and CONFIG_ARCH_T2081 instead. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: T208XQDS: Split as T2080QDS and T2081QDSYork Sun
Use two separated targets in Kconfig to simplify configurations. Signed-off-by: York Sun <york.sun@nxp.com>
2016-09-16Move existing use of CONFIG_SPL_RSA to KconfigSimon Glass
A few boards define this in a header file which is incorrect. It means that Kconfig options that rely on this cannot be used. Move it. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-03-14freescale: Remove CONFIG_DM from header filesSimon Glass
Kconfig options must defined in the defconfig files. Since RSA_SOFTWARE_EXP relies on CONFIG_DM, unless it is set in kconfig we cannot enable RSA. Remove the hacks which enable CONFIG_DM in header files and update the defconfig. Signed-off-by: Simon Glass <sjg@chromium.org>
