path: root/configs/T1042RDB_defconfig
2016-10-23Convert SILENT_CONSOLE options to KconfigSimon Glass
Move these option to Kconfig and tidy up existing uses. The Power PC boards don't have a suitable common element: the common header files don't appear to line up with the Kconfig files as far as I can tell. This results in a lot of defconfig changes. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jteki@openedev.com> [trini: Re-migrate, update common/console.c logic] Signed-off-by: Tom Rini <trini@konsulko.com>
2014-09-24powerpc/t104xrdb: Add T1042RDB board supportvijay rai
T1042RDB is a Freescale reference board that hosts the T1042 SoC (and variants). The board is similar to T1040RDB, T1042 is a reduced personality of T1040 SoC without Integrated 8-port Gigabit(L2 Switch). T1042RDB is configured with serdes protocol 0x86 which can support following interfaces - 2 RGMII's on DTSEC4, DTSEC5 - 1 SGMII on DTSEC3 DTSEC1, DTSEC2 are not connected on board. This Patch - add T1042RDB support - updates README file for T1042RDB details and update commands for switching to alternate banks from vBank0 to vBank4 and vice versa This patch also does minor clean ups for fdt defines for T1042RDB and T1042RDB_PI board Signed-off-by: Vijay Rai <vijay.rai@freescale.com> Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
