CONFIG_VIDEO
Reviewed-by: Jagan Teki <jteki@openedev.com>
Move these option to Kconfig and tidy up existing uses.
The Power PC boards don't have a suitable common element: the common header
files don't appear to line up with the Kconfig files as far as I can tell.
This results in a lot of defconfig changes.
[trini: Re-migrate, update common/console.c logic]
In some cases we were missing CONFIG_USB=y so enable that when needed.
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
move CONFIG_BOOTDELAY into a Kconfig option. Used for this
purpose the moveconfig.py tool in tools.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
There are already two FIT options in Kconfig but the CONFIG options are
still in the header files. We need to do a proper move to fix this.
Move these options to Kconfig and tidy up board configuration:
CONFIG_FIT
CONFIG_OF_BOARD_SETUP
CONFIG_OF_SYSTEM_SETUP
CONFIG_FIT_SIGNATURE
CONFIG_FIT_BEST_MATCH
CONFIG_FIT_VERBOSE
CONFIG_OF_STDOUT_VIA_ALIAS
CONFIG_RSA
Unfortunately the first one is a little complicated. We need to make sure
this option is not enabled in SPL by this change. Also this option is
enabled automatically in the host builds by defining CONFIG_FIT in the
image.h file. To solve this, add a new IMAGE_USE_FIT #define which can
be used in files that are built on the host but must also build for U-Boot
and SPL.
Note: Masahiro's moveconfig.py script is amazing.
[trini: Add microblaze change, various configs/ re-applies]
There are already Kconfig options for SPI flash drivers, but we
have not moved them from config.h to defconfig files. This commit
does this in a batch.
There are already Kconfig options for SPI drivers, but we
commit does this in a batch.
Move config for the E1000 Ethernet driver to Kconfig and tidy up affected
boards.
Several files are out of order. This means that when the moveconfig tool
moves CONFIG options to Kconfig it generates a large diff. To avoid this,
reorder the files first.
T1040D4RDB is a Freescale reference board that hosts the T1040 SoC.
T1040D4RDB is re-designed T1040RDB board with following changes :
- Support of DDR4 memory
- Support of 0x66 serdes protocol which can support following interfaces
- 2 RGMII's on DTSEC4, DTSEC5
- 1 SGMII on DTSEC3
- Support of QE-TDM
Similarily T1042D4RDB is a Freescale reference board that hosts the T1040
SoC. T1042D4RDB is re-designed T1042RDB board with following changes :
- Support for 0x86 serdes protocol which can support following interfaces
- 3 SGMII on DTSEC1, DTSEC2 & DTSEC3
- Support of DIU
Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com>
Signed-off-by: Codrin Ciubotariu <codrin.ciubotariu@freescale.com>
Signed-off-by: Wang Dongsheng <dongsheng.wang@freescale.com>
Reviewed-by: York Sun <yorksun@freescale.com>
