commit 0cfccb54014b ("configs: Resync with savedefconfig")
removed CONFIG_USB_STORAGE from some powerpc platforms' defconfig
files, whicih would block the use case of system loading rootfs
from USB drives, add them back.
Signed-off-by: Ran Wang <ran.wang_1@nxp.com>
Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
Enable the DM ESPI driver in T1042D4RDB defconfig.
Signed-off-by: Xiaowei Bao <xiaowei.bao@nxp.com>
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com>
[Rebased]
Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
CONFIG_ENV_OVERWRITE
[trini: Rerun migration, remove some comments]
Move ADDR_MAP related config options from include/configs/*.h to the
proper place in lib/Kconfig. This has been done using
./tools/moveconfig.py and manual inspection of the generated changes.
This is a preparation to use ADDR_MAP helper on ARM 32bit Raspberry Pi4
board for mapping the PCIe XHCI MMIO, which is above the 4GiB identity
mapping limit.
This enables DM_I2C and DM_RTC in T1042D4RDB defconfigs,
except T1042D4RDB SECURE_BOOT defconfig
Signed-off-by: Biwen Li <biwen.li@nxp.com>
CONFIG_PHYLIB
CONFIG_BITBANGMII
CONFIG_MV88E6352_SWITCH
CONFIG_MV88E61XX_SWITCH
CONFIG_PHYLIB_10G
CONFIG_PHY_AQUANTIA
CONFIG_PHY_ATHEROS
CONFIG_PHY_BROADCOM
CONFIG_PHY_CORTINA
CONFIG_PHY_DAVICOM
CONFIG_PHY_ET1011C
CONFIG_PHY_LXT
CONFIG_PHY_MARVELL
CONFIG_PHY_MICREL
CONFIG_PHY_NATSEMI
CONFIG_PHY_REALTEK
CONFIG_RTL8211X_PHY_FORCE_MASTER
CONFIG_PHY_SMSC
CONFIG_PHY_TERANETICS
CONFIG_PHY_TI
CONFIG_PHY_VITESSE
CONFIG_PHY_XILINX
Both symbols must be enabled when there is a raw NAND driver
selected. Also enable them when CONFIG_CMD_NAND is selected to avoid
breaking things when we'll further rework the MTD dependency
description.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
[trini: Rebase and migrate a few more boards here]
Enable eSDHC device module for T1042D4RDB board
Signed-off-by: Yinbo Zhu <yinbo.zhu@nxp.com>
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Enable the DM PCIe driver in T1042D4RDB defconfig.
Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
Add device tree for T1042D4RDB board and enable CONFIG_OF_CONTROL
so that device tree can be compiled.
Update board README for device tree usage.
Move the main symbol for Freescale Fman Ethernet controller option to
Kconfig. Also migrate the CONFIG_SYS_QE_FMAN_FW_IN_xxx macros and
rename the SPIFLASH one to follow the same format as all of the others.
To do this fully we need to migrate CONFIG_QC, do so.
CONFIG_SF_DEFAULT_BUS
CONFIG_SF_DEFAULT_CS
CONFIG_SF_DEFAULT_MODE
CONFIG_SF_DEFAULT_SPEED
I use moveconfig script and then manual check on generated u-boot.cfg
to solve the remaining issue.
Now that CMD_UBI does not select CMD_MTDPARTS we need to make platforms
that had been enabling it turn it on by hand. This exposed that we had
not yet migrated CMD_MTDPARTS fully, so do so now.
Fixes: 86dfa556d927 ("cmd: ubi: Remove useless call to mtdparts_init()")
CONFIG_FLASH_CFI_DRIVER
CONFIG_SYS_FLASH_USE_BUFFER_WRITE
CONFIG_FLASH_CFI_MTD
CONFIG_SYS_FLASH_PROTECTION
CONFIG_SYS_FLASH_CFI
[trini: Re-migrate]
CONFIG_MII
CONFIG_DRIVER_TI_EMAC
Acked-by: Jagan Teki <jagan@amarulasolutions.com>
CONFIG_MTD_PARTITIONS
CONFIG_MTD_DEVICE
This patch moves CONFIG_MP to Kconfig
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
CONFIG_SPI
This partly involves updating code that assumes that CONFIG_SPI implies
things that are specific to the MPC8xx SPI driver. For now, just update
the CONFIG tests. This also involves reworking the default for
CONFIG_SYS_DEF_EEPROM_ADDR so that we don't set it when we cannot make a
reasonable default, as it does not cause any compile failures.
Migrate the CONFIG_FSL_ESDHC option to Kconfig.
Signed-off-by: Mario Six <mario.six@gdsys.cc>
Migrate the CONFIG_BOARD_EARLY_INIT_R option to Kconfig.
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
We move all instances of CONFIG_MTDIDS_DEFAULT and
CONFIG_MTDPARTS_DEFAULT from the header files to the defconfig files.
There's a few cases here where we need to expand upon what was in the
header file.
Tested-by: Adam Ford <aford173@gmail.com> #omap3_logic
Having this as a 'default y' is rather annoying because it doesn't
actually compile unless other options are defined in the board header:
../cmd/bootm.c: In function 'do_imls_nor':
../cmd/bootm.c:330:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
Make it 'default n' so people who develop new boards that start from a
blank defconfig have one less compilation failure to debug.
Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
Signed-off-by: Alexandru Gagniuc <alex.g@adaptrum.com>
CONFIG_ENV_IS_IN_FLASH
CONFIG_CMD_BMP
[trini: Add depends on LCD || DM_VIDEO || VIDEO]
In some cases this is absolutely required, so select this for some secure
features. This also requires migration of RSA_FREESCALE_EXP
Cc: Ruchika Gupta <ruchika.gupta@nxp.com>
Cc: Poonam Aggrwal <poonam.aggrwal@freescale.com>
Cc: Naveen Burmi <NaveenBurmi@freescale.com>
Cc: Po Liu <po.liu@freescale.com>
Cc: Shengzhou Liu <Shengzhou.Liu@freescale.com>
Cc: Priyanka Jain <Priyanka.Jain@freescale.com>
Cc: Sumit Garg <sumit.garg@nxp.com>
Cc: Shaohui Xie <Shaohui.Xie@freescale.com>
Cc: Chunhe Lan <Chunhe.Lan@freescale.com>
Cc: Feng Li <feng.li_2@nxp.com>
Cc: Alison Wang <alison.wang@freescale.com>
Cc: Mingkai Hu <Mingkai.Hu@freescale.com>
Cc: York Sun <york.sun@nxp.com>
Cc: Saksham Jain <saksham.jain@nxp.freescale.com>
Cc: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
We repeated partial moves for CONFIG_SYS_NO_FLASH, but this is
not completed. Finish this work by the tool.
During this move, let's rename it to CONFIG_MTD_NOR_FLASH.
Actually, we have more instances of "#ifndef CONFIG_SYS_NO_FLASH"
than those of "#ifdef CONFIG_SYS_NO_FLASH". Flipping the logic will
make the code more readable. Besides, negative meaning symbols do
not fit in obj-$(CONFIG_...) style Makefiles.
This commit was created as follows:
[1] Edit "default n" to "default y" in the config entry in
common/Kconfig.
[2] Run "tools/moveconfig.py -y -r HEAD SYS_NO_FLASH"
[3] Rename the instances in defconfigs by the following:
find . -path './configs/*_defconfig' | xargs sed -i \
-e '/CONFIG_SYS_NO_FLASH=y/d' \
-e 's/# CONFIG_SYS_NO_FLASH is not set/CONFIG_MTD_NOR_FLASH=y/'
[4] Change the conditionals by the following:
find . -name '*.[ch]' | xargs sed -i \
-e 's/ifndef CONFIG_SYS_NO_FLASH/ifdef CONFIG_MTD_NOR_FLASH/' \
-e 's/ifdef CONFIG_SYS_NO_FLASH/ifndef CONFIG_MTD_NOR_FLASH/' \
-e 's/!defined(CONFIG_SYS_NO_FLASH)/defined(CONFIG_MTD_NOR_FLASH)/' \
-e 's/defined(CONFIG_SYS_NO_FLASH)/!defined(CONFIG_MTD_NOR_FLASH)/'
[5] Modify the following manually
- Rename the rest of instances
- Remove the description from README
- Create the new Kconfig entry in drivers/mtd/Kconfig
- Remove the old Kconfig entry from common/Kconfig
- Remove the garbage comments from include/configs/*.h
CONFIG_BOARD_EARLY_INIT_F
Create driver/ddr/fsl/Kconfig and move existing options. Clean up
existing macros.
Signed-off-by: York Sun <york.sun@nxp.com>
[trini: Migrate sbc8641d, xpedite537x and MPC8536DS, run a moveconfig.py -s]
CONFIG_T104xRDB is defined in T104xRDB.h, so it is always enabled for
all T1040RDB, T1040D4RDB, T1042RDB, T1042D4RDB, T1042RDB_PI.
CONFIG_T104XD4RDB is defined for all T1040D4RDB, T1042D4RDB.
Use TARGET_T1042D4RDB in Kconfig to simplify config options.
Remove macro CONFIG_T1042D4RDB.
Replace CONFIG_PPC_T1042 with ARCH_T1024 in Kconfig and clean up
existing macros.
Split ARCH_T104XRDB as ARCH_T1040RDB and ARCH_T1042RDB in Kconfig to
CONFIG_CFB_CONSOLE_ANSI
CONFIG_SYS_CONSOLE_IS_IN_ENV
CONFIG_CONSOLE_MUX
[trini: Re-order, re-migrate]
CONFIG_VIDEO
Reviewed-by: Jagan Teki <jteki@openedev.com>
Move these option to Kconfig and tidy up existing uses.
The Power PC boards don't have a suitable common element: the common header
files don't appear to line up with the Kconfig files as far as I can tell.
This results in a lot of defconfig changes.
[trini: Re-migrate, update common/console.c logic]
In some cases we were missing CONFIG_USB=y so enable that when needed.
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
