path: root/configs/T1042D4RDB_defconfig
2018-07-22Convert CONFIG_MTD_PARTITIONS et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_MTD_PARTITIONS CONFIG_MTD_DEVICE Signed-off-by: Adam Ford <aford173@gmail.com>
2017-10-30configs: Resync with savedefconfigTom Rini
2017-01-04fsl_ddr: Move DDR config options to driver KconfigYork Sun
Create driver/ddr/fsl/Kconfig and move existing options. Clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com> [trini: Migrate sbc8641d, xpedite537x and MPC8536DS, run a moveconfig.py -s] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-11-23powerpc: T104xRDB: Remove macro CONFIG_T104xRDB and T104xD4RDBYork Sun
CONFIG_T104xRDB is defined in T104xRDB.h, so it is always enabled for all T1040RDB, T1040D4RDB, T1042RDB, T1042D4RDB, T1042RDB_PI. CONFIG_T104XD4RDB is defined for all T1040D4RDB, T1042D4RDB. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: T1042D4RDB: Separate from T1042RDB in KconfigYork Sun
Use TARGET_T1042D4RDB in Kconfig to simplify config options. Remove macro CONFIG_T1042D4RDB. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: T1042: Remove macro CONFIG_PPC_T1042York Sun
Replace CONFIG_PPC_T1042 with ARCH_T1024 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: T104XRDB: Split to T1040RDB and T1042RDB in KconfigYork Sun
Split ARCH_T104XRDB as ARCH_T1040RDB and ARCH_T1042RDB in Kconfig to simplify config options. Signed-off-by: York Sun <york.sun@nxp.com>
2016-10-23Convert CONFIG_CFB_CONSOLE_ANSI to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CFB_CONSOLE_ANSI Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert SILENT_CONSOLE options to KconfigSimon Glass
Move these option to Kconfig and tidy up existing uses. The Power PC boards don't have a suitable common element: the common header files don't appear to line up with the Kconfig files as far as I can tell. This results in a lot of defconfig changes. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jteki@openedev.com> [trini: Re-migrate, update common/console.c logic] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-08-21Tidy up some defconfig filesSimon Glass
Several files are out of order. This means that when the moveconfig tool moves CONFIG options to Kconfig it generates a large diff. To avoid this, reorder the files first. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-07-28powerpc/T104xD4RDB: Add T104xD4RDB boards supportPriyanka Jain
T1040D4RDB is a Freescale reference board that hosts the T1040 SoC. T1040D4RDB is re-designed T1040RDB board with following changes : - Support of DDR4 memory - Support of 0x66 serdes protocol which can support following interfaces - 2 RGMII's on DTSEC4, DTSEC5 - 1 SGMII on DTSEC3 - Support of QE-TDM Similarily T1042D4RDB is a Freescale reference board that hosts the T1040 SoC. T1042D4RDB is re-designed T1042RDB board with following changes : - Support of DDR4 memory - Support for 0x86 serdes protocol which can support following interfaces - 2 RGMII's on DTSEC4, DTSEC5 - 3 SGMII on DTSEC1, DTSEC2 & DTSEC3 - Support of DIU Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> Signed-off-by: Codrin Ciubotariu <codrin.ciubotariu@freescale.com> Signed-off-by: Wang Dongsheng <dongsheng.wang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
