path: root/configs/T1042D4RDB_SDCARD_defconfig
2015-08-21Tidy up some defconfig filesSimon Glass
Several files are out of order. This means that when the moveconfig tool moves CONFIG options to Kconfig it generates a large diff. To avoid this, reorder the files first. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-07-28powerpc/T104xD4RDB: Add T104xD4RDB boards supportPriyanka Jain
T1040D4RDB is a Freescale reference board that hosts the T1040 SoC. T1040D4RDB is re-designed T1040RDB board with following changes : - Support of DDR4 memory - Support of 0x66 serdes protocol which can support following interfaces - 2 RGMII's on DTSEC4, DTSEC5 - 1 SGMII on DTSEC3 - Support of QE-TDM Similarily T1042D4RDB is a Freescale reference board that hosts the T1040 SoC. T1042D4RDB is re-designed T1042RDB board with following changes : - Support of DDR4 memory - Support for 0x86 serdes protocol which can support following interfaces - 2 RGMII's on DTSEC4, DTSEC5 - 3 SGMII on DTSEC1, DTSEC2 & DTSEC3 - Support of DIU Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> Signed-off-by: Codrin Ciubotariu <codrin.ciubotariu@freescale.com> Signed-off-by: Wang Dongsheng <dongsheng.wang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
