path: root/configs/T1040D4RDB_SECURE_BOOT_defconfig
2019-05-26configs: Migrate CONFIG_FMAN_ENET and some related options to KconfigTom Rini
Move the main symbol for Freescale Fman Ethernet controller option to Kconfig. Also migrate the CONFIG_SYS_QE_FMAN_FW_IN_xxx macros and rename the SPIFLASH one to follow the same format as all of the others. To do this fully we need to migrate CONFIG_QC, do so. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-07-22Convert CONFIG_MTD_PARTITIONS et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_MTD_PARTITIONS CONFIG_MTD_DEVICE Signed-off-by: Adam Ford <aford173@gmail.com>
2017-05-22Convert CONFIG_CMD_ETHSW to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_ETHSW Also enable it for sandbox to increase build coverage. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-01-04fsl_ddr: Move DDR config options to driver KconfigYork Sun
Create driver/ddr/fsl/Kconfig and move existing options. Clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com> [trini: Migrate sbc8641d, xpedite537x and MPC8536DS, run a moveconfig.py -s] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-12-02powerpc: mpc85xx: Move SECURE_BOOT to KconfigYork Sun
Move from CONFIG_SYS_EXTRA_OPTIONS to Kconfig option. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: T104xRDB: Remove macro CONFIG_T104xRDB and T104xD4RDBYork Sun
CONFIG_T104xRDB is defined in T104xRDB.h, so it is always enabled for all T1040RDB, T1040D4RDB, T1042RDB, T1042D4RDB, T1042RDB_PI. CONFIG_T104XD4RDB is defined for all T1040D4RDB, T1042D4RDB. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: T1040D4RDB: Separate from T1040RDB in KconfigYork Sun
Use TARGET_T1040D4RDB in Kconfig to simplify config macros. Replace CONFIG_T1040D4RDB with TARGET_T1040D4RDB and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: T1040: Remove macro CONFIG_PPC_T1040York Sun
Replace CONFIG_PPC_T1040 with ARCH_T1040 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: T104XRDB: Split to T1040RDB and T1042RDB in KconfigYork Sun
Split ARCH_T104XRDB as ARCH_T1040RDB and ARCH_T1042RDB in Kconfig to simplify config options. Signed-off-by: York Sun <york.sun@nxp.com>
2016-10-23Convert SILENT_CONSOLE options to KconfigSimon Glass
Move these option to Kconfig and tidy up existing uses. The Power PC boards don't have a suitable common element: the common header files don't appear to line up with the Kconfig files as far as I can tell. This results in a lot of defconfig changes. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jteki@openedev.com> [trini: Re-migrate, update common/console.c logic] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-09-16Move existing use of CONFIG_SPL_RSA to KconfigSimon Glass
A few boards define this in a header file which is incorrect. It means that Kconfig options that rely on this cannot be used. Move it. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-03-14freescale: Remove CONFIG_DM from header filesSimon Glass
Kconfig options must defined in the defconfig files. Since RSA_SOFTWARE_EXP relies on CONFIG_DM, unless it is set in kconfig we cannot enable RSA. Remove the hacks which enable CONFIG_DM in header files and update the defconfig. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-08-21Tidy up some defconfig filesSimon Glass
Several files are out of order. This means that when the moveconfig tool moves CONFIG options to Kconfig it generates a large diff. To avoid this, reorder the files first. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-07-28powerpc/T104xD4: Add Secure boot support for T104xD4RDB platformsgaurav rana
defconfig files are added and SFP version for these platforms is updated. Signed-off-by: Gaurav Rana <gaurav.rana@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
